My progress on the swap., just to let people know. *pics* |
Jan 10, 2006 - 4:43 PM |
old rusted bolt suck. the dp mounts suck. ive rounded off like 3 bolts. with grease oil and using heat.
wtf mate. -------------------- |
Jan 10, 2006 - 5:13 PM |
PB Blaster is your friend. Coat whatever bolts you plan on working on the day before you actually do the work. Make sure to use only 6 point sockets and stay away from wrenches whenever possible. An impact is also nice since it doesn't put constant torque on the bolt head's corners and will not round them off... It may however snap the head off the bolt.
-------------------- Project ST204.5 99.88946% complete... |
Jan 10, 2006 - 5:18 PM |
QUOTE(WannabeGT4 @ Jan 10, 2006 - 5:13 PM) [snapback]376859[/snapback] PB Blaster is your friend. Coat whatever bolts you plan on working on the day before you actually do the work. Make sure to use only 6 point sockets and stay away from wrenches whenever possible. An impact is also nice since it doesn't put constant torque on the bolt head's corners and will not round them off... It may however snap the head off the bolt. X2 -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jan 10, 2006 - 8:08 PM |
using 6 point. using an impact. using a oil based bolt product. these bolts are just rusted bad. gunna spray more on and tackle it tomorow.
Jan 10, 2006 - 8:24 PM |
PB Blaster works where everything else fails. WD-40 can't touch it. Letting it soak is key so tomorrow should go better for you.
Jan 10, 2006 - 9:11 PM |
nice ill have to get some. thanks.
Jan 11, 2006 - 12:25 AM |
pb blaster helps, but it cant work magic on rounded bolts.
go to sears and but a set of craftsman bolt outs. get the full set that can do 10m- 17m. striped bolts will never be a problem again! -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 11, 2006 - 12:29 AM |
sweet ill check it out tommorow.
Jan 11, 2006 - 12:43 AM |
http://cgi.ebay.com/CRAFTSMAN-BOLT-OUT-DAM...1QQcmdZViewItem
thats what they look like... just get the full set (10piece? ) that covers all the metric sizes on the car -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 11, 2006 - 12:49 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(x_itchy_b_x @ Jan 11, 2006 - 1:08 AM) [snapback]376916[/snapback] using 6 point. using an impact. using a oil based bolt product. these bolts are just rusted bad. gunna spray more on and tackle it tomorow. ? How in the world did you manage that? I don't think I've EVER rounded off a nut or bolt using a 6-point socket. Do you have a breaker bar? -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 11, 2006 - 12:51 AM |
no clue man. just my luck i guess. i even re filed a nut 1mm smaller so i could use a fresh socket on it. 13mm. and it still just got all mashed up. in the end i grinded it out. just cut the head off.
Jan 11, 2006 - 6:37 AM |
arts right about those bolt outs, they are sweet john!
Jan 11, 2006 - 10:40 AM |
QUOTE(lagos @ Jan 10, 2006 - 11:25 PM) [snapback]377074[/snapback] pb blaster helps, but it cant work magic on rounded bolts. go to sears and but a set of craftsman bolt outs. get the full set that can do 10m- 17m. striped bolts will never be a problem again! I think it's obvious that spraying oil on a rounded off bolt isn't going to help it . The Craftsman Bolt-Out set is however, the best thing since sliced bread. -------------------- Project ST204.5 99.88946% complete... |
Jan 11, 2006 - 4:26 PM |
this is a pain to put on. i have to heat the oil lines and coolant lines to moved them almost an inch. sucky. -------------------- |
Jan 11, 2006 - 9:55 PM |
you know john, i REALLY woulda just stuck with the stock manifold.
your lucky if that manifold lasts 2 months. -------------------- Former Team 5SFTE pro member ;)
Jan 12, 2006 - 12:48 AM |
le sigh. i hope not. time will tell. if it does eh w/e i got it cheap. what can you expect.
i got the stock to fall back on. -------------------- |
Jan 12, 2006 - 12:57 AM |
Enthusiast Joined Dec 21, '03 From Lynnwood, WA Currently Offline Reputation: 0 (0%) |
Nice work, dude.
Jan 12, 2006 - 1:06 AM |
Enthusiast Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
Looks like everything is coming along really good, cant wait to see it all up and running, your gonna need to post a vid or something
Jan 12, 2006 - 11:40 AM |
Enthusiast Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Is that an SS Autochrome manifold? I hope not. =/
Jan 12, 2006 - 12:54 PM |
hells yes lol. i think. didnt buy it from ssauto chrome but i think it is either way.
Lo-Fi Version | Time is now: November 30th, 2024 - 2:26 PM |
