![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
So the wheel bearing was bad after all for my celi's front passenger wheel. Anyways I thought a good new wheel bearing would do the trick, but as it turns out the hub was worn down to the core.
So ordering a new hub from toyota is gonna cost $125 after taxes and the bearing $45 and the mechanic who helped me tap out the old and put in the new $25. so after an alignment too = $45 the total comes out close to $250 for fixing the wheel bearing.....So long for a 3-point brace. Anyways it sucks not to drive the celi, and driving the camry just doesn't feel the same when your missing the 4age power and driving without P/S. I was driving around the corners with the camry, and I was like "Whoah! It felt like driving a boat" Seems like the celi will be out untill Tuesday when I get a new bolt to retain the lower ball joint, cause I over threaded it upon removal.. Stupid me! ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
i know how you feel.. .lost my celica the day after christmas... engine died and is knocking...
![]() -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) ![]() |
Did you already get stuff? I might have parts to help if you wanted...
-------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Enthusiast Joined Nov 21, '05 From New Mexico, USA Currently Offline Reputation: 0 (0%) ![]() |
I feel ya soulshadow. I know how it goes. My celica has been sitting for nearly a month now. The starter finally gave out and I already needed new tires and struts. Although it will be back up in a few days. I have to drive the tacoma around... I hate it, it's ride compaired to the celica is wierd. Anyway good luck with everything.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
QUOTE(Jaws4God @ Dec 30, 2005 - 3:52 AM) [snapback]372764[/snapback] i know how you feel.. .lost my celica the day after christmas... engine died and is knocking... ![]() Wow that sucks man, and it's even worse because you can't pull off ur front bumper and fix things -------------------- ![]() |
Lo-Fi Version | Time is now: April 24th, 2025 - 3:17 AM |
