> New speakers don't fit!!, i KNOW someone else must have had this problem
post Dec 30, 2005 - 12:49 AM
blaque_6thGen
Joined Jun 18, '04
From Rio Grande Valley, TX
the speakers in the doors are 6.5" circular speakers, right? so if you you buy 6.5" aftermarket speakers, they should fit right? well, mine don't! toyota made their 6.5" speakers extended on the sides so that they could bolt onto the support thing that holds the speaker in place. this is a real pain in the @$$ for me because i took my whole door panel off to find out that i was not going to be able to put in my new speakers.
knowing that all our cars are pretty much the same, and that many of you have after market speakers in your doors...how did you get yours to fit? i'm desperate!
this is what happens when your little brother is better at photoshop than you are
post Dec 30, 2005 - 1:14 AM
this is very common as its happened to everyone.......do a search the information is there....i even think there is a HOW-TO in the HOW TO section....
easy way is go down to home depot or sumthing and buy a lexan/plastic type piece (should be hard and about 1/4" thick) (you can even steal a tray from taco bell).......cut out a 6.5" center hole
and then cut it to fit the stock bracket screw the speaker to the piece then screw the piece to the stock bracket wala!
post Dec 30, 2005 - 2:40 AM
djultimate
Joined Dec 1, '05
From South Windsor, CT
If you don't feel confident enough to make your own you can buy these from crutchfield.
$14.99 a pair
Item #142SAC656
post Dec 30, 2005 - 2:48 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
A better option is to have a piece of MDF as spacer.
post Dec 30, 2005 - 3:08 AM
celicaST
Joined Jun 23, '05
i wouldnt buy adapters, just make them like playr said and save some money. i know how you feel though, when i was installing mine and found out they didnt fit i was like WTF. it sucks but its not really a problem. at least the back pair fit fine.
post Dec 30, 2005 - 10:07 AM
blaque_6thGen
Joined Jun 18, '04
wow, thanks for the quick response guys! i'm gonna try going to home depot this afternoon to find some plastic that i can cut. and hopfully i don't screw things up, lol.
post Dec 30, 2005 - 11:44 AM
Cutrara
Joined May 6, '05
From PA
I bought them of eBay for about $7. They work for the 6GC and some years of the Corvette.
post Dec 31, 2005 - 3:19 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
Yeah, I did the same as Cutrara, bought them from ebay. Theyre plastic, and they say they fit the Celica, and Corvette. Just make sure to seal these with silicon or something when you install them.
post Dec 31, 2005 - 2:11 PM
Niskyspy
Joined Jan 21, '05
From NY
Had the same problem when installed my speakers, I think some one should make it a steaky!!!
<<AKA THA RUSSIAN>>
post Dec 31, 2005 - 10:00 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
I used 1/4" plywood and siliconed them into nice little boxes. Sound good car in general has good acoustics.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Jan 6, 2006 - 6:34 PM
yyet
Joined Jan 6, '06
From Oahu, Hawaii
Oh great... I got a 94 Gt-S and I just bought Alpine component speakers for the front? So you guys are all sure that they aren't going to fit without an adapter???
post Jan 6, 2006 - 7:34 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
QUOTE(djultimate @ Dec 30, 2005 - 2:40 AM) [snapback]372874[/snapback]
$14.99 a pair
Item #142SAC656
for some reason those didnt work for my polks.. but i made them work. I cut them a certain way in peices and mounted the speaker up. hard to explain.
FlickR
post Jan 6, 2006 - 7:39 PM
blaque_6thGen
Joined Jun 18, '04
QUOTE(yyet @ Jan 6, 2006 - 11:34 PM) [snapback]375366[/snapback]
yeah, i finally got mine in...thanks to these guys (fellow 6gc-ers). i bought my adapters at best buy for $13. they needed to be modified a little for them to work...but i got em in.
in the picture you can see the speaker mount, the new speaker, and the adapter.
post Jan 7, 2006 - 11:41 PM
TwistedmindZ
Joined Dec 21, '05
From SF Cali
i think that since it is a 8" hole a 8 inch sub running as a mid @ 4 ohms (not amped) would sound best with a component set of tweeters. that's what i am waiting on. also some of the higher end newer celicas come with 8 inch mids already included.
Lo-Fi Version Time is now: November 26th, 2024 - 4:41 PM
