> Importing a GT-4 to the U.S., What I've learned so far. Others please contribute...
post Dec 30, 2005 - 8:53 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
I must admit, I'm one of those dreamers who wants to get a GT-4 into the states. A lot of us probably are, so that's why I'm writing this post. There have been several (3 at least) of these posts that discuss importing but there were a lot of questions remaining so I'll try to answer them with what I've learned over the past week. If you can contribute to this thread, please do, or if you find some info that contradicts what I've found, please post that as well. I'll start by saying that doing this legitimately is nearly impossible, so there is some degree of shadiness to everything here.
1) Shipping a whole (not disassembled) GT-4 from anywhere in the world (besides Canada) to the U.S. and claiming it at the port.
This is the expensive and nearly impossible one. This means you would have to use a Registered Importer (they're the guys who do the conversion) and post a bond for the vehicle at 150% of it's value. If you've heard of the Nissan Skyline, that's what they do to make those legal in the U.S. None of this has anything to do with which side the steering wheel is on (RHD and LHD are equally legit in the U.S. provided there is crash test data). Basically reinforced beams have to be added to the doors, all glass has to be replaced, all seatbelts and airbags have to be replaced, all headlamps, tires, rims, reflectors, turn signals, wiring and so on and so forth. I can't even name all the parts, but if you'd like, look closesly at the parts on your celica and you'll see that a lot of them have DOT stamped on them. Euro or JDM models won't have that, and in order to be legal in the U.S. you'd need every last one of those parts. Several tens of thousands of dollars worth of work would have to be done just to make the body of the car legal not to mention the fact that the EPA is going to jump you for smog compliance. In short, if you've got the money it takes to do this, you're better off buying a skyline.
Here's the data off the NHTSA website that addresses this approach:
If the vehicle is less than 25 years old and was not originally manufactured to comply with all applicable FMVSS, and/or was not so certified by its original manufacturer, it cannot be lawfully imported into the U.S. on a permanent basis unless NHTSA determines it eligible for importation. The agency makes those determinations on its own initiative or the basis of a petition from a registered importer. These are business entities that are specifically approved by NHTSA to import nonconforming vehicles and to perform the necessary modifications on those vehicles so that they conform to all applicable FMVSS. The petitions must specify that the vehicle is substantially similar to a vehicle that was certified by its original manufacturer as conforming to all applicable FMVSS and is capable of being readily altered to conform to those standards, or, if there is no substantially similar U.S.-certified vehicle, that the vehicle has safety features that comply with, or are capable of being altered to comply with, the FMVSS based on destructive test information or other evidence the agency deems adequate. Import eligibility decisions are made on a make, model, and model year basis.
An additional requirement for the lawful importation of a nonconforming vehicle is that it be imported by a registered importer (RI) or by an individual who has contracted with an RI to bring the vehicle into conformity with all applicable FMVSS. A bond in an amount equivalent to 150 percent of the declared value of the vehicle must be given at the time of importation to ensure that the necessary modifications are completed within 120 days of entry. A list of RI's can be found on our web site at http://www.nhtsa.dot.gov/cars/rules/import/. You might want to contact one or more of the listed RIs to obtain their opinion on the feasibility of conforming the vehicle that you seek to import to the FMVSS, and the costs involved in petitioning the agency to determine that vehicle to be eligible for importation, as well as the costs for conforming the vehicle to the FMVSS.
But wait, why can't you just forgo the bond that you paid at the port and skip the modifications? If you can buy a decent GT-4 for around 4200 USD, another 6300 to customs then you've got a GT-4 for 10,500, right? That would definitely be cheaper than modifying it, but that's when titling screws you, which I'll talk about later.
2) Canada
Just as hard as the states, so if you get one there, you're home free, but you'll probably run into the same problems.
3) Mexico!
This has been the most promising one yet although it still has it's problems (and it's slightly scary due to corruption, etc). Let's start with port selection. Baja California is probably the cheapest place to ship a car to, assuming you bought it in Japan. Ensenada is the most northern shipping port they have and it's a little less than two hours from San Diego (about 110 miles). If you try the Gulf of Mexico side, the boat will have to go through the Panama canal (again assuming it came from Asia) so it will probably cost a lot more to ship it that way. Mexico, unlike our northern neighbor doesn't seem to discriminate as much against cars. It has been said that you can ship the car there and then drive it across the border. It is true that a car registered in Mexico can be driven across the border into the U.S. without a problem, but the gray area is that you would probably need a Mexican citizen to do it. Border patrol and customs will probably do more than raise an eyebrow if you show up in a RHD celica with Mexican license plates and you yourself are not a resident of Mexico. Maybe if you've got a friend with a timeshare in Cancun that you can register it to you can pull it off, but you better have a really good straight story to make that work. Here's my solution. Many states will issue license plates or paper temp tags to you without seeing the vehicle. You'll probably have to sweet talk them to do it without a VIN (non U.S. cars are not going to have a VIN that works with our U.S. 17 digit system) but assuming you pull it off the car should go through just fine even with maximum scrutiny from border patrol. What I don't recommend: Do not just take your current celica tags, registration and insurance card down there and slap them on a GT-4. If you get pulled randomly or because RHD cars freak the officer out, you'll be in a lot of trouble for what you've done when they see the Japanese ID number doesn't match the VIN on your registration. Oh, and don't forget even if you've insured the car for driving in the states, you'll need a Mexico driving insurance policy to be legal to drive it in Mexico no matter where it's license plates say it's from. I wouldn't recommend messing with this one because the policies are dirt cheap and you can print them out online and if you DON'T have the proper insurance, Mexico will throw you into Mexican jail until you have paid all damages for whatever accident you're in.
4) Okay, so now you've got your GT-4 in the states either by skipping out on the bond in example number one or driving it across the U.S./Mexico border in example 4. Let's use Oklahoma as an example. You drive your car over to OK without wrecking it (don't forget to get it insured for stateside driving!). Oklahoma and every other state that I have family or friends living in all have the same clause in their lawbooks about foreign cars. No I didn't check all 48 CONUS states, but I did check California, Colorado, Oklahoma, Nebraska, and Michigan. Every last one of them had the same clause buried in the lawbooks and it goes like this:
F. When registering for the first time in this state a vehicle which was not originally manufactured for sale in the United States, to obtain a certificate of title, the Tax Commission shall require the applicant to deliver:
1. As evidence of ownership, if the vehicle has not previously been titled in the United States, the documents constituting valid proof of ownership in the country in which the vehicle was originally purchased, together with a notarized translation of any such documents; and
2. As evidence of compliance with federal law, copies of the bond release letters for the vehicle issued by the United States Environmental Protection Agency and the United States Department of Transportation, together with a receipt issued by the Internal Revenue Service indicating that the applicable federal gas guzzler tax has been paid.
This is the clause that screws us. If you bypass the port either by skipping out on your 150% bond or by sneaking it up through Mexico, you're not going to have the documentation that the state needs to issue your vehicle a 17 digit U.S. vin number. Well, if you were thinking about parting out your US celica, now would probably be a good time, and that will solve your vin problem, but like I said at the beginning, it's shady and could get you in big trouble down the line especially if you are in an accident and your insurance company or their insurance company presses insurance fraud charges against you. Now like I said, I didn't check all 48 state laws, but I'm willing to bet every one of them has that same rule about VINs buried in there somewhere.
5) Become a race car driver and import it as an off-road race vehicle.
This one sounded promising, too, but the NHTSA is on to this one and they'll get you at the port. Here's the skinny:
If you want it in the country permanently it cannot be a vehicle that was manufactured for road use (GT-4s are roadworthy where they came from so that won't work).
If you want it in the country "temporarily" you've got to supply them with all kinds of crap. Racing league, race dates, locations, etc. They basically want to track your itinerary and make sure it's back out of the country in short order
Then they throw this clause at the end to make sure you don't try and convert it:
"A racing vehicle may not be registered or licensed for on-road use. A vehicle allowed entry for racing purposes cannot subsequently be converted for use on public roads."
Screwed again.
6) Military. I am and I've looked into it. No special treatment. You can bring a US conforming vehicle into the US duty free (no taxes) but that's it. If you know someone who brought a beemer back from Germany, then it says DOT on all the lights, glass, etc, because they bought it through AAFES. It's US spec sold at a nice discount because BMW doesn't have to pay the import/export taxes on it. Buy a beemer off a normal lot in Germany and try and ship it back and it will still get bonded at the U.S. port.
7) Import it as a parts only car.
This might be the big one guys. According to the rules you can bring it in as "parts only" if and only if you remove the "engine and drive train." In short, you've got to get someone in Japan to pull the engine and tranny for you crate them up separate and ship them separately. If they're shipped together (even though they're not installed), all bets are off, and customs considers it a full fledged car. In addition you have to remove the following non DOT approved stuff:
"Any items included in the assemblage that are subject to an FMVSS (brake hoses, brake fluid, glazing, lighting equipment, seat belt assemblies, tires, rims) that were not manufactured to comply with the applicable standard, and/or were not so certified by their original manufacturer, must be removed from the assemblage and exported or destroyed before entry."
Okay, so you ditch the rims scrap the brake lines, brake fluids, seat belts and glazing (what is glazing???) and ship those nice projector lamps, and jdm tail lights with your engine and tranny and you're good to go. Pick up some steel wheels from a junkyard that say DOT on them and use those to roll your GT-4 onto a trailer and you're home free. Wait for your tranny/engine/fancy lights to show up and start putting it back together. Oh yeah, still no vin number...
Well, if you'd like to make it semi legit, take your current celica, strip the hood, front bumper, engine, tranny, front and rear suspension and just swap all that stuff onto it and you've got a US AWD GT-4 with all the right DOT glass, headlights, etc. Sell the JDM projectors on Ebay or this site because you know someone will want them (along with the fenders, steering wheel, stereo, gauge cluster, moon roof, seats, and anything else you can part out. Might as well make some money). Why not just buy a front and rear clip and the JDM hood and bumper? It'll probably cost you more. Most people do the ST-185 swap and that front clip runs about 1900 shipped. I don't even know if you can do the AWD conversion using ST-185 clips (are the wheelbases identical?). If you do ST-185, that will probalby be less. If you really want a true GT-4 (and I mean ST-205 AWD 250ish HP) that front clip will run you around 3500 USD shipped, I'm not sure how much the rear clip would be because you'd have to get one of those clip importers to do it special since none of them list it, plus probably an even thousand for all the parts and shipping needed to do the full on GT-4 front end. In any case, I estimate that it'll cost roughly 7000 to get all the parts using clips and ordering the hood/bumper through your local dealer. Plus with a clip they've chopped the exhaust system so barring welding one together you'll probably spend some cash on one of those, too.
If you buy a celica in Japan, you can get a 1994/1995 for under 4,000 USD. Another 1000 to get it put on the boat and you've saved yourelf roughly two grand. Plus you've got all the extra JDM crap to sell on E-Bay and you can actually recoup some of your costs. By my count all you need now is to send your harnesses to Dr Tweak or DG Performance, and you'll have every part you could possibly need for a total GT-4 engine/AWD swap.
Finally, here's what I have not done yet:
Gotten a real shipping quote (I've heard 600, but since the motor will be pulled, "roll on roll off" won't work so it'll probably be more expensive)
Actually confirmed the list of stuff they want removed before customs will release it (tires, rims, brake hoses etc). All I need to do is figure out what port I'm using and start making phone calls. I'm stuck in Oklahoma for training for the next year, so I'll be getting more crazy with this when I'm back in Cali.
Here are some of the source websites that I used for info:
http://www.nhtsa.dot.gov/cars/rules/import...ages/page2.html
http://www.cbp.gov/xp/cgov/travel/clearing...automobiles.xml
Here are some other threads on 6GC that address this issue:
http://www.6gc.net/forums/index.php?showtopic=3216&hl=gt-4
http://www.6gc.net/forums/index.php?showtopic=17021&hl=
http://www.6gc.net/forums/index.php?showtopic=17951&hl=
As I do more to make this dream a reality I will continue to post. Please share the wealth if you find anything else.... Like a GT-4 for sale in the U.S. Can't believe I missed that e-bay opportunity!!!
post Dec 30, 2005 - 9:00 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
There is a GT4 for sale in my state. It's a 6th Gen and only $19,000. It can be registered and given a tag as well. How do you like them apples? I'm buying it biggrin.gif
post Dec 30, 2005 - 9:17 PM
JFrost9
Joined Aug 27, '05
From Texas
ive seen that one, its at that evolution imports or something like that...They have alot of good cars there. I recently went on a road trip to Mexico ( i live in Texas) and saw this place in South Texas that had quite a bit of imports. (mainly skylines) i assume they used your mexico border tactic...Me and some friends went to the place just to check it out, and the guys that ran the place were jerks. Anyways, im sure if you keep looking, you could find some already imported.
post Dec 30, 2005 - 11:09 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
QUOTE(JoKeRkId613 @ Dec 30, 2005 - 8:00 PM) [snapback]373117[/snapback]
Congrats, man! Wish we were all so lucky...
post Dec 31, 2005 - 2:33 AM
popstar
Joined Nov 24, '04
From Moscow, russia
QUOTE(JoKeRkId613 @ Dec 30, 2005 - 9:00 PM) [snapback]373117[/snapback]
Hey sorted fella smile.gif when willl you get your hands on her ????
once one or two get in the country the gates will open and the fun will begin
have you had a test drive yet ??
Life is for living, and you don't get a second chance
Take care now !!
post Dec 31, 2005 - 11:31 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I wish I could fastforward time a few months... If I got enough sponsors my parents would buy me the gt-4 in florida.... but by the time i foind out how much i get in scholarships it'll be gone
post Dec 31, 2005 - 7:28 PM
95celgt
Joined Oct 5, '03
From South TX.
i live on the border of mexico, and importation here is extremely lenient(sp?), a friend has an S15 silvia, one guy has a skyline, etc. i would get a GT-4 but aint got the cash......im sure I can get it legit being from mexico, and paying to make it legit.....
post Jan 1, 2006 - 9:26 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
It seems you guys have as much trouble importing GT-4 there like here.
But I've just founded one and I'm goin to the bank asap.
I've missed the last one for sale, I wont let this one slide easily smile.gif
6GC 4 Life Baby!!!
post Jan 1, 2006 - 9:35 AM
Driveby
Joined Sep 17, '05
From Newcastle / UK
By the sounds of it, it would be easier for some of you guys to move to another country where GT4's were readily available with no import headaches.
Good luck to anyone whos willing to go through (around) the red tape to get an ST205 GT4 smile.gif
On a side note though, why do you guys want GT4's so bad? is it because of the rarity? surely its not just the performance/handeling as you must have similar vehicles available with no hassle involved?
This post has been edited by Driveby: Jan 1, 2006 - 10:16 AM
1994 JDM GT4 WRC
post Jan 1, 2006 - 11:23 AM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
probley being I am the only one to ever get illegal cars in the US, Ill go over some of the guide lines I had to deal with. You can get any car you want into Canada for pretty cheap basicly its about 2k+ the cost of the car and depending on the car shipping can be more then the car. Once the car is in Cananda it is simple to get it into the US, IM me AIM and Ill share further details with you, if your serious. Out of all the cars I have made USDM legal its costs between 500-2k to get them VIN'd and all of that. Once its road legal you will have no issues's besides d*ck head cops, A buddy of mine driving a 1993 US legal JDM GT4 got a ticket just because the cop said he noticed him because of RHD.
Any questions tho, let me know on AIM, because not everything should be well known.
DTE
I am a thief.
do not buy anything from me.
post Jan 1, 2006 - 3:18 PM
ST-204
Joined Dec 21, '03
From Lynnwood, WA
I used to live in Seattle, and there is a tuning shop which belongs to my HK buddies.
For real, the main issue in importing a JDM GT4 is only a money problem, if u do have enough to spend it, I damn sure that u can get a JDM GT4 from Japan.
A year ago, I wanted to import a GT4 from Japan either, but I had to spend around $23000 for it, it includes all tax fees, shipping fee, and even the fee for legalizing.
But let's think in this way, do u think spending around 23k is worth for a 7-year-old car?
Coz I can use the same price to import a RHD JDM DC5-R either.....
Anyway, good luck to import the GT4 here!!
Good luck.
This post has been edited by ST-204: Jan 1, 2006 - 3:19 PM
post Jan 2, 2006 - 6:32 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Glazing refers to all the glass. (the question was in the first post)
post Jan 3, 2006 - 2:25 AM
popstar
Joined Nov 24, '04
From Moscow, russia
QUOTE(Driveby @ Jan 1, 2006 - 9:35 AM) [snapback]373438[/snapback]
but there not that good when you look at the scoobies and evos coming in legely
with 20lt lump pushing 350 + bhp.......
if you can get one for real money than go for it, but don't hold your breath when you
Take care now !!
post Jan 3, 2006 - 9:43 PM
pokemeintheeye
Joined Sep 27, '04
From Minnesota
QUOTE(JoKeRkId613 @ Dec 31, 2005 - 2:00 AM) [snapback]373117[/snapback]
I've told countless of people about that Celica and every single one thanked me then said they're going to buy it. I have yet to see it sold. $19,000 is a little pricey though. Then again, its not everyday you see one forsale in the US.
post Jan 3, 2006 - 11:57 PM
JFrost9
Joined Aug 27, '05
From Texas
scoobies and evos dont have the look of the celica. Which for me is the greatest aspect of the celica.
post Jan 4, 2006 - 1:30 AM
blackthunder
Joined Oct 21, '05
From Okinawa, Japan
personaly a GT4 would be nice but i kinda have to say one of my dream cars is a souped up Escort Cosworth...4wd stock 350hp and easily upgradable to over 600 :-D
-Dan
1998 SSII Beams, work in progress...
post Jan 4, 2006 - 7:05 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
If it can be done without too much hassle, it would be well worth it. A used 94/95 for around 4,000 or less (in Japan) plus 1,000 to ship it is only 5 grand. I looked at some chewed up all-tracs (91-93) and they're still commanding a higher price than that. And I REALLY mean chewed up... I looked at a '93 that was just trashed and the guy wanted 9 grand for it. I told him it was worth 2 but he wouldn't even budge on the price. The sad part is that it actually sold! Beside, like JFrost says, you can't compare the looks of a 6th gen...
post Jan 4, 2006 - 1:13 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(94GT @ Jan 4, 2006 - 6:05 AM) [snapback]374416[/snapback]
well that 4,000 to buy plus a 1,000 to ship is leavnig out the taxes and fees and conversions. Add maybe 10,000 or more to that price and then you'll be a little more accurate
1999 Celica GT
post Jan 8, 2006 - 10:58 PM
FORGMANN
Joined Dec 11, '04
From USA
ok i ignore these post as much as i can but clipstuner is right about canada it is easy .. i towed my st205 from calgary thru montana across america with zero issue .
if you can get it here the rest is easy part .. do want to point out you dont deal with DOT you deal with local DMV and cops .. there is no DOT cop .. you get thru state loop holes your fine ..
my buddy fixing my st205 has a 94 jdm rhd mr2 turbo at his shop as well and that guy who owns it is a friend of mine as well .. he has a horrible vin swap and has had zero and i mean zero issues even with being pulled over 7 times .. car has been inspected by cops and passed with flying colors.
the whole importing thing is way over blown on net .. i am old and stubborn and i got my st205 without issue ..
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Jan 11, 2007 - 5:44 PM
MasonF
Joined Dec 4, '06
From Ontario/Temecula, CA
Once I'm making good money, this will be my goal, to own a real GT-4. smile.gif
Bender: Blackmail is such an ugly word. I prefer "extortion." The "X" makes it sound cool.
Lo-Fi Version Time is now: April 24th, 2025 - 7:24 AM
