Code 52 - Knock Sensor, help. |
Jan 3, 2006 - 2:26 PM |
Enthusiast Joined Nov 20, '02 Currently Offline Reputation: 1 (100%) |
Just wondering... how tough is it to change this sensor? I have some basic tools with jack stands and a hydrolic jack...
Jan 3, 2006 - 10:30 PM |
Enthusiast Joined Dec 31, '04 From white hall, Maryland Currently Offline Reputation: 0 (0%) |
QUOTE(Tenchi @ Jan 3, 2006 - 2:26 PM) [snapback]374127[/snapback] Just wondering... how tough is it to change this sensor? I have some basic tools with jack stands and a hydrolic jack... its not hard at all if u look on ur motor if u have a 5sfe....go to the front of ur car, look at the motor's valve cover, on the driver side of the valve cover right below it is the knock sensor it screws into the head or the oil pressure sensor. in the book its the same thing. -------------------- [font=Comic Sans Ms][size=3]
SI VIS PACEM PARA BELLUM (if you wish for peace, prepare for war!) |
Jan 4, 2006 - 7:19 AM |
Thanks, I will give it a shot after I check the wiring.
Jan 4, 2006 - 2:32 PM |
QUOTE(spke719 @ Jan 3, 2006 - 10:30 PM) [snapback]374286[/snapback] QUOTE(Tenchi @ Jan 3, 2006 - 2:26 PM) [snapback]374127[/snapback] Just wondering... how tough is it to change this sensor? I have some basic tools with jack stands and a hydrolic jack... its not hard at all if u look on ur motor if u have a 5sfe....go to the front of ur car, look at the motor's valve cover, on the driver side of the valve cover right below it is the knock sensor it screws into the head or the oil pressure sensor. in the book its the same thing. this is totally wrong. thats the oil pressure sender, NOT the knock sensor, the knock sensor is located on the BACK of the block, under the intake manifold. jack the car up nice and high, put it on jackstands, climb underneath the car, and on the back of the block just under the intake manifold, is the knock sensor, youll need a 27mm socket to get it off. heres a pic of what it looks like once you get it off. good luck -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jan 5, 2006 - 7:18 AM |
Thanks for the correction. Hopefully I will get to it today after work since it's not raining. Quick question, if all I need are new wires, will any wires do?
Jan 5, 2006 - 12:42 PM |
Well, I was able to get someone to get my car on a lift, and it turns out that the wire was loose on the connector. He is trying to see if he can put another connector on there. I hope this solves the problem!
Oh and some prices: Knock Sensor at the dealer = $175 Knock Sensor at Autozone = $225 ??? wtf?? |
Jan 5, 2006 - 2:10 PM |
just get one from the bone yard, or from a member here, or celicatech parting out, or whatever. =)'
thats only if you NEED it tho..sounds like you have it fixed without replacing it. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: January 11th, 2025 - 1:48 PM |
