> Fuel Pump / Distributer, What you think?
post Jan 3, 2006 - 11:57 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
This morning when I set off for Morgantown, my car wouldn't start. I kind of had a little freak out, then I missed with it and fiddled with the gas untill I got it started. After I got it to start I had to keep hitting the gas to keep it from quitting. I didn't enjoy that because I know it's bad to rev a cold engine. After that start and warm up, it's ran fine. When I got home, I let the car sit for several hours while I unpacked and aranged my house, then when I go to start it up agian to get something to eat it starts fine. I still think something is wrong. I figure fuel pump or distributer. I know the distributers go out a good bit on these things. I've changed my plugs and fuel filter, so I know they aren't the problem. So were exactly is the fuel pump on a 94 GT? And what do you all think about what could be wrong? Thanks.
Live Free, Be Happy
post Jan 4, 2006 - 11:05 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Can anyone tell me were the fuel pump is or if they've ever changed it?
Live Free, Be Happy
post Jan 4, 2006 - 1:00 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
I would lean more toward the distributor than the fuel pump. If the fuel pump is going out it wouldn't have gotten better by warming the car up. If you have low fuel pressure it also would get worse the higher you reved the engine. Check the distributor for cracks which would let water in and kill the spark. Warming the car up burns off the moisture.
The fuel pump is in the gas tank. Not as easy to get to as the distributor.
post Jan 4, 2006 - 1:10 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I'm just going to switch out the intire disstibuter assimbly. I was leaning more twords it anyway. The thing that makes me think it was the fuel pump was because when I gave it more gas it finally started. The car has acted like this a little before. It'll start but it acts like it doesn't want to run, the rmps will stay low and I have to push on the gas. I thought it could have been a vacum leak that was causing a choke system to not work. That hasn't come up with anyone I've talked to though.
Live Free, Be Happy
post Jan 4, 2006 - 3:24 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(Bigmeanbulldog55 @ Jan 4, 2006 - 10:10 AM) [snapback]374487[/snapback]
I'd try replacing just the cap and rotor first. No need to throw the baby out with the bath water. Maybe the plug wires too. If the insulators are shot and water gets in there you'll have the same problem.
post Jan 4, 2006 - 3:38 PM
fuel pump is rather easy to get to and remove...
lift up your rear seat its right under there
few screws and it pops out
Lo-Fi Version Time is now: January 11th, 2025 - 2:03 AM
