> Battery and/or alternator problems...?, I'm just taking a guess at that.
post Jan 4, 2006 - 3:03 AM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
The first cold night here caused my car to not start the next morning. I had to roll-start it. This happened for about 2 more days. I eventually had the battery checked. It was fine. I haven't had any problems getting it started since then. Just tonight though, I was sitting idle for about 5 minutes with my headlights on (including brights), and my battery light in the gauge cluster started to flicker on and off. I had been noticing that my gauges and headlights were a lot dimmer than normal. I revved the engine up, and the problem was solved. The idle isn't below the normal operating idle, and I had the alternator replaced around a year ago.
post Jan 4, 2006 - 11:08 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
QUOTE(Delta_Phoenix @ Jan 4, 2006 - 8:03 AM) [snapback]374407[/snapback]
sounds like the alternator to me.
do you have an underdrive pulley or anything like that?
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Jan 4, 2006 - 11:15 AM
Alexander
Joined Nov 21, '05
From Franklin NJ
you mite even want to either tighten the belt or replace it before you replace the alternator
that mite make a difference
Alexander
-Silver 97 Celica ST
post Jan 4, 2006 - 11:38 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Alexander @ Jan 4, 2006 - 11:15 AM) [snapback]374445[/snapback]
Unless you hear it squeeking, this isn't going to help anything. Sometimes those guys at the auto parts stores who test batteries don't really know what they're doing, so you could have a battery that's not taking a charge. This would make the car run off the alternater, which puts a big strain on it and makes it go bad fast. If you get a voltage meter, you can check to see how many volts the alternater is putting out, and that should tell you if it's bad or not. I think it should put out around 15-16 somethings. I can't remember exactly what to turn the meter to. Someone more knowledgable can take you from there.
Live Free, Be Happy
Lo-Fi Version Time is now: January 11th, 2025 - 3:58 AM
