Parking/Signal Lights wont turn off, Please help |
Jan 4, 2006 - 4:13 PM |
Enthusiast Joined Jun 2, '04 From Salem/Corvallis, Oregon Currently Offline Reputation: 2 (100%) |
after fixing some wiring on my fogs, i reconnected the battery terminals and these lights will not turn off? ive check all the fuses and everything and cant figure it out. i also have an alarm so i dont know if that has anything to do with it. please help me asap. thanks.
Jan 4, 2006 - 5:02 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Is it wired to an imdependent switch or to your parking lights?
Jan 4, 2006 - 5:20 PM |
QUOTE(Cutrara @ Jan 4, 2006 - 2:02 PM) [snapback]374561[/snapback] Is it wired to an imdependent switch or to your parking lights? the fogs are independent, i just used the piaa wiring harness. |
Jan 4, 2006 - 7:03 PM |
Enthusiast Joined Dec 1, '05 From South Windsor, CT Currently Offline Reputation: 0 (0%) |
did u hook it up to a switch? or did u hook the lights directly to the battery?
Jan 4, 2006 - 7:30 PM |
QUOTE(djultimate @ Jan 4, 2006 - 4:03 PM) [snapback]374596[/snapback] did u hook it up to a switch? or did u hook the lights directly to the battery? yes its hooked to a switch, the harness connects a wire to each terminal and then another positive to power the switch. also its not just the sidemarkers and turn signals, its also the tail lights. when i turn the headlight switch i can see that the alreadly lit bulbs get alittle brighter. any input will help. This post has been edited by jermyd1: Jan 4, 2006 - 7:32 PM |
Jan 4, 2006 - 7:35 PM |
for now just disconnect the wires you ran to the battery in order to prevent draining it.
Draw up a diagram of how you wired it and post it up here. If you dont know how to post a picture... you can email it to me @ markbarbagallo@gmail.com and I will post it up for you. -------------------- |
Jan 4, 2006 - 8:11 PM |
just figured out the fogs have nothing to do with it. i must have a short somewhere because i took out the 15A TAIL fuse and the lights turned off. i was looking at the wiring diagram in my repair manual and am wondering if there might be something wrong with the relay.
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:43 AM |
