> computer, 7gc
post May 18, 2003 - 11:45 PM
Dickster223
Joined Dec 5, '02
From West Virginia
would a 7gc computer fit in a 6gc and if so would it help on power any?
post May 19, 2003 - 12:09 AM
boosted_K2
Joined Aug 30, '02
From Michigan
it wouldnt help at all... its setup for an engine that runs higher RPMs and runs with vvt(L)-i, 2 things our engine doesnt have.
No but I don't buy it
Cause I'm...
post May 19, 2003 - 12:13 AM
Do you mean the car's ecu? If so, then no, there's no way it would work with a 7A-FE or 5S-FE engine at all, at least without lots of modification.
post May 19, 2003 - 12:18 AM
Dickster223
Joined Dec 5, '02
From West Virginia
ok thanx just was thinking
post May 19, 2003 - 4:15 PM
zigy
Joined Nov 6, '02
From Chicago, IL
how about......hmmmm....... NO ........
where did you get that idea! the enignes have nothing in common except displacement....
it's not that it wouldn't fit, IT WOULDN'T WORK!!!!!
post May 19, 2003 - 5:05 PM
ghostdog
From ny to philly
QUOTE (zigy @ May 19, 2003 - 1:29 PM)
come on now, take it easy on the newbie.
post May 19, 2003 - 6:10 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
actually, i think that many honda ecu's are interchangeable like when doing a vtec head swap and stuff like that.
as for toyota, they arent communists, everything they make does not have to be multi-purpose multi-function and interchangable
that being said, go for an aftermarket ecu or reprogrammed ecu, those will bring you some gains
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post May 19, 2003 - 6:33 PM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE (97sccelica @ May 19, 2003 - 5:24 PM)
thats because they swap the Vtech heads with the ECU. swapping a Vtech ECU into a non-vtech civic is just as dumb as swapping the VVt-i ECU into a non VVt-i engine. now if you were to swap the ZZ's head, then you could probably get away with using a tuned ZZ ECU.
Cause I'm...
post May 20, 2003 - 2:50 AM
zigy
Joined Nov 6, '02
From Chicago, IL
QUOTE (K2_Celica @ May 19, 2003 - 3:47 PM)
nice.....nice...... god job...... did some v-tec homework.....lol
post May 21, 2003 - 6:14 PM
Teyaku
Joined May 8, '03
From Key West, FL
Vtec is gayz0r...althogh Honda puts out descent engines. I know of a few hondas with b series engine swaps runnin 12's :-D...Can't wait...
Lo-Fi Version Time is now: December 1st, 2024 - 4:55 AM
