Maintenace? |
Maintenace? |
Jan 5, 2006 - 12:40 AM |
Enthusiast Joined Jul 14, '05 From Spring, Texas Currently Offline Reputation: 0 (0%) |
Does anyone have a compelete list of what maintenace needs to be done on what miles? If so please be spefic and detailed about it.
Im thinking my car needs a certain tune up cause its running pretty ****ty right now on my point of view. It has 160k on it. Engine was rebuild though. Im not exactly sure how many miles are on it. Is there a way to tell how many miles are on the engine? Thanks Guys |
Jan 5, 2006 - 4:58 AM |
SCHEDULED SERVICES - NON-TURBO
1994 Toyota Celica 1990-96 MAINTENANCE Toyota Maintenance & Service Intervals (Non-Turbo) Celica * PLEASE READ THIS FIRST * NOTE: All SERVICE SCHEDULES are listed for normal service vehicles. If vehicle is operated under severe service conditions, see SEVERE SERVICE REQUIREMENTS (PERFORM W/SERVICE SCHEDULES) for items requiring additional maintenance. NOTE: This article contains scheduled maintenance service information. Fluid types and capacities listed with each service in this article are only those necessary to perform that scheduled service. For specifications pertaining to fluid capacities for the entire vehicle, fuse and circuit breaker identification, wheel and tire size, battery type, warranty information, or model identification refer to the MAINTENANCE INFORMATION article in this section. CAUTIONS & WARNINGS SUPPLEMENTAL RESTRAINT SYSTEM (AIR BAG) NOTE: See the AIR BAGS article in the ACCESSORIES/SAFETY EQUIPMENT Section. Modifications or improper maintenance, including incorrect removal and installation of the Supplemental Restraint System (SRS), can adversely affect system performance. DO NOT cover, obstruct or change the steering wheel horn pad in any way, as such action could cause improper function of the system. Use only plain water when cleaning the horn pad. Solvents or cleaners could adversely affect the air bag cover and cause improper deployment of the system. WARNING: To avoid injury from accidental air bag deployment, read and carefully follow all warnings and service precautions. See appropriate AIR BAGS article in ACCESSORIES/SAFETY EQUIPMENT. CAUTION: Disconnect negative battery cable before servicing any air bag system, steering column or passenger side dash component. After any repair, turn ignition key to the ON position from passenger’s side of vehicle in case of accidental air bag inflation AIR CONDITIONING SERVICING CAUTION: Avoid breathing R-134a refrigerant and PAG lubricant vapors, exposure may irritate eyes, nose and throat. To remove R-134a from system use R-134a recycling equipment that meets SAE J2210 specifications. If accidental system discharge occurs, ventilate work area before resuming service. WARNING: R-134a service equipment or vehicle A/C systems SHOULD NOT be pressure tested or leak tested with compressed air. Some mixtures of air/R134a have shown to be combustible at elevated pressures. These mixtures are dangerous and may cause fire and/or explosions. See AIR CONDITIONING SERVICE article in GENERAL INFORMATION section. ANTI-LOCK BRAKE SYSTEM The anti-lock brake system contains electronic equipment that can be susceptible to interference caused by improperly installed or high output radio transmitting equipment. Since this interference could cause the possible loss of the anti-lock braking capability, such equipment should be installed by qualified professionals. On models equipped with anti-lock brake systems, ALWAYS observe the following cautions: * DO NOT attempt to bleed hydraulic system without first referring to the appropriate ANTI-LOCK BRAKE SYSTEM article in the BRAKES Section. * DO NOT mix tire sizes. As long as tires remain close to the original diameter, increasing the width is acceptable. Rolling diameter must be identical for all 4 tires. Some manufacturers recommend tires of the same brand, style and type. Failure to follow this precaution may cause inaccurate wheel speed readings. * Use ONLY recommended brake fluids. DO NOT use silicone brake fluids in an ABS-equipped vehicle. BATTERY WARNING WARNING: When battery is disconnected, vehicles equipped with computers may lose memory data. When battery power is restored, driveability problems may exist on some vehicles. These vehicles may require a relearn procedure. See COMPUTER RELEARN PROCEDURES article in GENERAL INFORMATION section. REPLACING BLOWN FUSES Before replacing a blown fuse, remove ignition key, turn off all lights and accessories to avoid damaging the electrical system. Be sure to use fuse with the correct indicated amperage rating. The use of an incorrect amperage rating fuse may result in a dangerous electrical system overload. BRAKE PAD WEAR INDICATOR Indicator will cause a squealing or scraping noise, warning that brake pads need replacement. CATALYTIC CONVERTER Continued operation of vehicle with a severe malfunction could cause converter to overheat, resulting in possible damage to converter and vehicle. Any modification to the exhaust system on turbo models, which reduces exhaust backpressure, will lead to lean fuel mixtures and excessive spark advance. This could cause serious engine damage. ELECTROSTATIC DISCHARGE SENSITIVE (ESD) PARTS WARNING: Many solid state electrical components can be damaged by static electricity (ESD). Some will display a warning label, but many will not. Discharge personal static electricity by touching a metal ground point on the vehicle prior to servicing any ESD sensitive component. ENGINE OIL CAUTION: Never use non-detergent or straight mineral oil. FUEL SYSTEM SERVICE WARNING: Relieve fuel system pressure prior to servicing any fuel system component (fuel injection models). HALOGEN BULBS Halogen bulbs contain pressurized gas which may explode if overheated. DO NOT touch glass portion of bulb with bare hands. Eye protection should be worn when handling or working around halogen bulbs. RADIATOR CAP CAUTION: Always disconnect the fan motor when working near the radiator fan. The fan is temperature controlled and could start at any time even when the ignition key is in the OFF position. DO NOT loosen or remove radiator cap when cooling system is hot. RADIATOR FAN WARNING: Keep hands away from radiator fan. Fan is controlled by a thermostatic switch which may come on or run for up to 15 minutes even after engine is turned off. TURBOCHARGED MODELS CAUTION: Do not race engine immediately after starting. When stopping engine, allow engine to idle for approximately 60 seconds before shutting it off. Failure to do so may cause turbocharger damage due to lack of oil flowing to the turbocharger bearings. SERVICE POINT LOCATIONS Fig. 1: Service Point Locations (5S-FE Engine) Courtesy of Toyota Motor Sales, U.S.A., Inc. Fig. 2: Service Point Locations (4A-FE Engine) Courtesy of Toyota Motor Sales, U.S.A., Inc. CAMSHAFT TIMING BELT REPLACEMENT INFORMATION CAUTION: Failure to replace a faulty camshaft timing belt may result in serious engine damage. The condition of camshaft drive belts should always be checked on vehicles which have more than 50,000 miles. Although some manufacturers do not recommend belt replacement at a specified mileage, others require it at 60,000-100,000 miles. A camshaft drive belt failure may cause extensive damage to internal engine components on most engines, although some designs do not allow piston-to-valve contact. These designs are often called "Free Wheeling". Many manufacturers changed their maintenance and warranty schedules in the mid-1980’s to reflect timing belt inspection and/or replacement at 50,000-60,000 miles. Most service interval schedules in this manual reflect these changes. Belts or components should be inspected and replaced if any of the following conditions exist: * Cracks Or Tears In Belt Surface * Missing, Damaged, Cracked Or Rounded Teeth * Oil Contamination * Damaged Or Faulty Tensioners * Incorrect Tension Adjustment Replace the camshaft timing belt every 72 months or 60,000 miles if the vehicle is operated under Severe Service conditions such as frequent idling or extensive long distance driving at low speeds (taxi, police or door-to-door delivery). SEVERE & NORMAL SERVICE DEFINITIONS NOTE: Use the Severe Service schedule if the vehicle to be serviced is operated under ANY (one or more) of these conditions: Service is recommended at mileage intervals based on vehicle operation and engine type. Service schedules are based on the following primary operating conditions: Normal Service * Driven More Than 10 Miles Daily * No Operating Conditions From Severe Service Schedule Severe Service (Unique Driving Conditions) * Towing A Trailer, Using A Camper Or Car Top Carrier * Repeated Short Trips Less Than 5 Miles When Temperatures Are Below Freezing * Extensive Idling Conditions (Taxi Or Delivery Type Service) * Operating On Dusty, Rough, Muddy Or Salt Spread Roads SEVERE SERVICE REQUIREMENTS (PERFORM W/SERVICE SCHEDULES) NOTE: The following services are to be performed on vehicles subjected to severe service. See SEVERE & NORMAL SERVICE DEFINITIONS. This service is to be performed in addition to the normal services listed in the NORMAL MAINTENANCE SERVICE SCHEDULES. SEVERE SERVICE CONDITIONS/ACTIONS TABLE . Condition Action Item Perform Every (1) Towing A Trailer, Replace Engine Oil & 5,000 Miles or 6 Months . Using A Camper Or Filter Car Top Carrier . . Replace Transmission 20,000 Miles or 24 Months . Fluid Replace Differential 20,000 Miles or 24 Months Fluid Repeated Short Replace Engine Oil & 5,000 Miles or 6 Months Trips Less Than 5 Filter Miles When . Temperatures Are Replace Transmission 20,000 Miles or 24 Months Below Freezing Fluid Replace Differential 20,000 Miles or 24 Months Fluid Extensive Idling Replace Engine Oil & 5,000 Miles or 6 Months Conditions (Taxi Filter Or Delivery Type . Service) Replace Transmission 20,000 Miles or 24 Months Fluid Replace Differential 20,000 Miles or 24 Months Fluid Operating On Replace Engine Oil & 5,000 Miles or 6 Months Dusty, Rough, Filter Muddy Or Salt . Spread Roads Replace Transmission 20,000 Miles or 24 Months Fluid Replace Differential 20,000 Miles or 24 Months Fluid (1) - Perform these services at the mileage or number of months (since the last time), whichever comes first. NORMAL MAINTENANCE SERVICE SCHEDULES (NON-TURBO) The following service schedules refer to vehicles driven under normal operating conditions. For vehicles driven under severe conditions, additional services may be necessary. See SEVERE SERVICE REQUIREMENTS (PERFORM W/SERVICE SCHEDULES) above in this article for additional service requirements. 7500 MILE (12,000 KM) SERVICE 7500 MILE (12,000 KM) SERVICE Service Or Inspect Change Engine Oil Change Oil Filter Lubrication Specifications Application Specification Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG . Maximum Temperature . Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Fluid Capacities Application (1) Quantity Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. 15,000 MILE (24,000 KM) SERVICE 15,000 MILE (24,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Brake Lining & Drums Brake Pads & Discs Brake Line Pipes & Hoses Steering Linkage Drive Shaft Boots Ball Joints & Dust Covers Transaxle Fluid Steering Gear Housing Replace Engine Oil & Filter Lubrication Specifications Application Specification Automatic Transaxle .............................. Dexron-II ATF Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Manual Transaxle 2WD (1990) ......................................... Dexron-II . 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3 (1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used. (2) - If there are questions concerning the correct type of fluid for Celica 2WD Manual Transaxle, see Toyota Tech Service . Bulletin VOL. 10, 043 December 1991. Fluid Capacities Application (1) Quantity Automatic Transmission ......................... 3.5 Qts. (3.3L) Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) Manual Transmission ............................ 2.7 Qts. (2.6L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. (2) - Includes filter change. Service Labor Times Application Hours 1.6L 4A-FE ................................................. 1.5 2.2L 5S-FE EFI ............................................. 1.5 22,500 MILE (36,000 KM) SERVICE 22,500 MILE (36,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Replace Change Engine Oil Change Oil Filter Lubrication Specifications Application Specification Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Fluid Capacities Application (1) Quantity Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) . (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. 30,000 MILE (48,000 KM) SERVICE 30,000 MILE (48,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Exhaust Pipes & Mountings Idle Speed (4A-FE Engines) Fuel Line & Connections Brake Lining & Drums Brake Pads & Discs Brake Line Pipes & Hoses Steering Linkage Drive Shaft Boots Ball Joints & Dust Covers Transaxle Fluid Steering Gear Housing Replace Engine Oil & Filter Air Filter Spark Plugs Lubrication Specifications Application Specification Automatic Transaxle .............................. Dexron-II ATF Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Manual Transaxle 2WD (1990) ......................................... Dexron-II 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3 (1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used. (2) - If there are questions concerning the correct type of fluid for Celica 2WD Manual Transaxle, see Toyota Tech Service Bulletin VOL. 10, 043 December 1991. Fluid Capacities Application (1) Quantity Automatic Transmission ......................... 3.5 Qts. (3.3L) Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) Manual Transmission ............................ 2.7 Qts. (2.6L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. (2) - Includes filter change. Service Labor Times Application Hours 1.6L 4A-FE ................................................. 2.0 2.2L 5S-FE EFI ............................................. 2.0 37,500 MILE (60,000 KM) SERVICE 37,500 MILE (60,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Replace Change Engine Oil Change Oil Filter Lubrication Specifications Application Specification Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Fluid Capacities Application (1) Quantity Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. 45,000 MILE (72,000 KM) SERVICE 45,000 MILE (72,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Brake Lining & Drums Brake Pads & Discs Brake Line Pipes & Hoses Steering Linkage Drive Shaft Boots Ball Joints & Dust Covers Transaxle Fluid Steering Gear Housing Replace Engine Oil & Filter Lubrication Specifications Application Specification Automatic Transaxle .............................. Dexron-II ATF Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Manual Transaxle 2WD (1990) ......................................... Dexron-II 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3 (1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used. (2) - If there are questions concerning the correct type of fluid for Celica 2WD Manual Transaxle, see Toyota Tech Service Bulletin VOL. 10, 043 December 1991. Fluid Capacities Application (1) Quantity Automatic Transmission ......................... 3.5 Qts. (3.3L) Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) Manual Transmission ............................ 2.7 Qts. (2.6L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. 52,500 MILE (84,000 KM) SERVICE 52,500 MILE (84,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Replace Change Engine Oil Change Oil Filter Lubrication Specifications Application Specification Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature . Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Fluid Capacities Application (1) Quantity Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. 60,000 MILE (96,000 KM) SERVICE 60,000 MILE (96,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Valve Clearance Drive Belts Exhaust Pipes & Mountings Idle Speed Fuel Line & Connections Charcoal Canister Brake Lining & Drums Brake Pads & Discs Brake Line Pipes & Hoses Steering Linkage Drive Shaft Boots Ball Joints & Dust Covers Transaxle Fluid Steering Gear Housing Replace Engine Oil & Filter Air Filter Fuel Tank Cap Gasket Camshaft Timing Belt (Severe Service) Spark Plugs Lubrication Specifications Application Specification Automatic Transaxle .............................. Dexron-II ATF Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Manual Transaxle 2WD (1990) ......................................... Dexron-II 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3 (1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used. (2) - If there are questions concerning the correct type of fluid for Celica 2WD Manual Transaxle, see Toyota Tech Service . Bulletin VOL. 10, 043 December 1991. Fluid Capacities Application (1) Quantity Automatic Transmission ......................... 3.5 Qts. (3.3L) Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) Manual Transmission ............................ 2.7 Qts. (2.6L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. Service Labor Times Application (1) Hours . 1.6L 4A-FE ................................................. 4.5 2.2L 5S-FE EFI ............................................. 4.5 . (1) - Add 2.3 hours to replace camshaft timing belt. 67,500 MILE (108,000 KM) SERVICE 67,500 MILE (108,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Replace Change Engine Oil Change Oil Filter Lubrication Specifications Application Specification Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Fluid Capacities Application (1) Quantity Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. (2) - Includes filter change. 75,000 MILE (120,000 KM) SERVICE 75,000 MILE (120,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Brake Lining & Drums Brake Pads & Discs Brake Line Pipes & Hoses Steering Linkage Drive Shaft Boots Ball Joints & Dust Covers Steering Gear Housing Replace Engine Oil & Filter Lubrication Specifications Application Specification Automatic Transaxle .............................. Dexron-II ATF Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Manual Transaxle 2WD (1990) ......................................... Dexron-II 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3 (1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used. (2) - If there are questions concerning the correct type of fluid for Celica 2WD Manual Transaxle, see Toyota Tech Service Bulletin VOL. 10, 043 December 1991. Fluid Capacities Application (1) Quantity Automatic Transmission ......................... 3.5 Qts. (3.3L) Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) Manual Transmission ............................ 2.7 Qts. (2.6L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. Service Labor Times Application Hours 1.6L 4A-FE ................................................. 1.5 2.2L 5S-FE EFI ............................................. 1.5 82,500 MILE (132,000 KM) SERVICE 82,500 MILE (132,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Replace Change Engine Oil Change Oil Filter Lubrication Specifications Application Specification Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG . Maximum Temperature . Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Fluid Capacities Application (1) Quantity Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. 90,000 MILE (144,000 KM) SERVICE 90,000 MILE (144,000 KM) SERVICE Service Or Inspect Verify Last Major Service Was Performed Exhaust Pipes & Mountings Idle Speed (4A-FE Engines) Fuel Line & Connections Brake Lining & Drums Brake Pads & Discs Brake Line Pipes & Hoses Steering Linkage Drive Shaft Boots Ball Joints & Dust Covers Transaxle Fluid Steering Gear Housing Replace Engine Oil & Filter Air Filter Spark Plugs Lubrication Specifications Application Specification Automatic Transaxle .............................. Dexron-II ATF Engine Oil Minimum Temperature Greater Than 0 F (-18 C) .................. SAE 10W-30 API SG Maximum Temperature Less Than 0 F (-18 C) ...................... SAE 5W-30 API SG Manual Transaxle 2WD (1990) ......................................... Dexron-II 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3 (1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used. (2) - If there are questions concerning the correct type of fluid for Celica 2WD Manual Transaxle, see Toyota Tech Service . Bulletin VOL. 10, 043 December 1991. . Fluid Capacities Application (1) Quantity Automatic Transmission ......................... 3.5 Qts. (3.3L) Engine Oil (2) 4A-FE ........................................ 3.4 Qts. (3.2L) 5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L) 5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) Manual Transmission ............................ 2.7 Qts. (2.6L) (1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. . (2) - Includes filter change. Service Labor Times Application Hours 1.6L 4A-FE ................................................. 2.0 . 2.2L 5S-FE EFI ............................................. 2.0 97,500 MILE (156,000 KM) SERVICE 97,500 MILE (156,000 KM) SERVICE Service Or Inspect This post has been edited by macavely: Jan 5, 2006 - 5:25 AM -------------------- |
Jan 5, 2006 - 8:35 AM |
Awsome, thank you so much. Someone Sticky this!
Jan 5, 2006 - 12:48 PM |
Enthusiast Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
did it get cut off from being too long?
Jan 5, 2006 - 2:13 PM |
wow mac, if you could only type that well without copying outta a book!!!! hahahahaha j/k man. awesome stuff, if we can get all the info in here, ill merge the posts, and sticky it =)
13.6@108MPH, 5SFTE Powered |
Jan 6, 2006 - 4:20 PM |
Yeah I just noticed it cut if off
Lo-Fi Version | Time is now: November 24th, 2024 - 4:22 AM |
