> Speed signal wire & Reverse wire, Help me find them!
post Jan 7, 2006 - 10:17 AM
djultimate
Joined Dec 1, '05
From South Windsor, CT
Finishing up the installation of my navigation and I need to tap into the speed signal wire and reverse wire. These wires help the accuracy of the GPS. I'm searching through the wiring diagrams but I'm having trouble finding it. Any help?
post Jan 7, 2006 - 10:55 AM
Cutrara
Joined May 6, '05
From PA
Locate the ECU. It sits underneath and in front of the console. Peel back the carpet from the center passenger side of the vehicle and you'll see the ECU connectors as pictured above. Locate the E7 pug. It should be the forward most plug of the three (you may have to disconnect the others to gain access to it). Locate the #11 terminal on the plug. Thats the speed signal wire.
And for the reverse wire, click "Back-up Lights"
http://www.celicatech.com/imagearchive/bgb...ewd/circuit.htm
post Jan 7, 2006 - 11:19 AM
djultimate
Joined Dec 1, '05
Thanks Alex!
post Jan 7, 2006 - 1:34 PM
Cutrara
Joined May 6, '05
From PA
Always happy to help a fellow celican.
post Jan 23, 2006 - 12:28 PM
eliaz
Joined Dec 28, '05
From Norway
Would this apply for a 95 GT also? (3S-GE)
post Jan 23, 2006 - 12:57 PM
Cutrara
Joined May 6, '05
From PA
The speed sensor wire, no. That is a 7A-FE ECU. The reverse wire will work for you.
post Jan 23, 2006 - 4:15 PM
eliaz
Joined Dec 28, '05
From Norway
Oh, well..I'm installing the same navigation system and need to locate the speed signal. Do you know where it is?
post Jan 23, 2006 - 8:11 PM
Cutrara
Joined May 6, '05
From PA
Sorry, I don't have a 3S-GE diagram. Maybe WannbeGT4 will see this topic and reply, he knows his stuff when it comes to car electrical.
post Jan 29, 2006 - 4:20 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
eliaz, check here:
http://www.6gc.net/forums/index.php?showto...14&#entry386114
Lo-Fi Version Time is now: February 19th, 2025 - 11:19 PM
