> manual boost controllers, what do u guys recommend?
post Jan 7, 2006 - 6:18 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
well its time to boost just a little higher now...im planning on doing an 11-12 lbs daily driven on my 3s. theres a ton of MBCs out there...which ones do u guys recommend? i was thinking turboXS high performance...thoughts???
bboy
post Jan 7, 2006 - 6:36 PM
www.twosrus.com/ 50$ and works great, like i said in my pm.
and just to warn you...the difference in power when going from 10psi to 13 will be a nice surprise.
post Jan 7, 2006 - 6:42 PM
Or you can get the new Joe P boost controller for $35 (waiting period due to demand). Its an inline design and looks different from standard MBCs. Check it out at www.Joepmbc.com. I've used their standard XZ for several years w/o problem.
post Jan 7, 2006 - 10:51 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
twosrus is ur best bet
I will return one day.
post Jan 7, 2006 - 11:44 PM
BBoYRuGGeD
Joined Jun 4, '04
thnx for the replies guys...and sure enough i ordered my MBC from twosRus almost an hours ago after reading ur posts laugh.gif
oh btw i was reading on the install of these MBCs and i understand the TVSV has to be disabled...but i was jsut wondering would this disable the safe boost mode also, say from a knock or whatever...hopefully not im guessing kindasad.gif
bboy
post Jan 8, 2006 - 12:08 AM
QUOTE(BBoYRuGGeD @ Jan 7, 2006 - 11:44 PM) [snapback]375848[/snapback]
bboy
yes, you do loose that "safe mode". at least the part of it that limits your boost in cold weather, or because of some cel codes. the knock sensor still does its job tho
This post has been edited by lagos: Jan 8, 2006 - 12:15 AM
post Jan 8, 2006 - 3:58 PM
Insanity-74
Joined Jan 9, '05
From Under the car
I recomend not using a manual boost controller at all.....get an electronic one to be safe.
post Jan 8, 2006 - 4:39 PM
celiracer
Joined Oct 5, '05
From NE
One of my buddies with a talon said that he prefers a manual boost controler, he said its more accurate in readings, because electronic one can say its reading right, but really its not. But thats just what he told me. Me myself will probably be running a manual boost controler.
post Jan 8, 2006 - 4:51 PM
QUOTE(Insanity-74 @ Jan 8, 2006 - 3:58 PM) [snapback]376038[/snapback]
Justification?
EBC is convenience factor, and MAYBE slightly more accurate if you have a dual solenoid. Besides that they're both as reliable.
post Jan 8, 2006 - 5:39 PM
turboxs mbc can be found really cheap and they are great =)
Lo-Fi Version Time is now: December 3rd, 2024 - 9:01 PM
