![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) ![]() |
I finally have some free time since I just quite my second job so i decided to do a small project with the interior - i want to paint it white - so I now have taken out most of the parts that will be painted except for the ac vents which I will do last . I'm using duplicolor white spray cans. Here's what I have done so far.
![]() ![]() ![]() i'll probably end up replacing the carpet too while i'm at it - and maybe replacing the seats - but i don't want to dip into my engine swap money This post has been edited by celicarus: Jan 9, 2006 - 2:47 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 12, '04 From Nj Team 6gc Currently Offline Reputation: 0 (0%) ![]() |
make sure you wipe the parts clean so that your paint don't bubble up. good luck and hope to see the results
-------------------- Team 6gc 2oo5
![]() Enthusiast ![]() Joined Dec 1, '05 From South Windsor, CT Currently Offline Reputation: 0 (0%) ![]() |
yeah, clean them well with rubbing alcohol
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) ![]() |
the pieces look good so far, if your looking to save money, just go buy some of that spray paint for fabric at Autozone. Its like 5 dollars a can, and will total to like 20-25 dollars. Its a cheap nice fix if your looking to save money for that swap.
-------------------- ![]() I am now a part of the ihavemorethen16gc club! |
we'll it was kinda windy and chilly this morning so didn't have time to paint anything ouside - but i decided to do something else - i copied the idea from another member on here but forgot who it was - once i find out i'll give credit to where credit is due - or if any one knows feel free to say so --
here are some pics ![]() ![]() ![]() i'm a fan of anime so unless i find better pics - they'll stay for now i wonder what it'll look like at night - i'll take some pictures tonight This post has been edited by celicarus: Jan 10, 2006 - 2:31 PM |
in the process i tried painting the cluster panel but the paint didn't stick too well - maybe i need a different type of paint for plastic - but i thought the carpet and vinyl would do the job - or maybe the temperature was too cold - so i had to peel and wash off the paint -
fabric paint isn't goin to work for plastic......
use duplicolor paint works great |
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(celicarus @ Jan 9, 2006 - 7:45 PM) [snapback]376376[/snapback] I'm using duplicolor white spray cans. he said he is already using duplicolor white... great job man, everything looks good so far, and the gauges are very unique |
QUOTE but i thought the carpet and vinyl would do the job right in the post above mine |
yeah duplicolor has one for carpet and vinyl printed on the front of the can - but in the back of the can it also says for plastic too -
well i just checked out duplicolor website and this is what i found -------------------------------------------------------------------------------- Q. How do I get paint to stick to plastics? A. Clean plastic with a water and ammonia based detergent solution, rinse, and dry thoroughly. Next use Dupli-Color? Wax and Grease Remover (CM541) to remove any silicone. Dupli-Color? offers paints intended for plastic application such as our Bumper Coatings, Vinyl and Fabric Colors and Trim Paint. For maximum adhesion, some plastics may require Dupli-Color? Adhesion Promoter (CP199). so i may need to buy the Ahesion Promotor - luckily the cans at autozone only cost 4.99 each This post has been edited by celicarus: Jan 10, 2006 - 4:45 PM |
i used the truck and suv paint..
http://www.duplicolor.com/products/truckvansuv.html many colors, lay primer first, color, clear works great! |
Enthusiast ![]() Joined Apr 4, '05 Currently Offline Reputation: 0 (0%) ![]() |
I used regular paint for my plastic pieces all you need to do is spray a couple of mist coats over the plastic after you finish your cleaning steps.
Spray a couple of mist coats once each dries spray normally. |
thanks for the advice - i stopped by autozone on my lunch break to get Ahesion Promotor - and went home to test it out - it suggested 2-3 coats before color - so I did 2 coats - five minutes in between each - had the fan blowing at it to help speed things up - then a mist coat of white - 10 minutes later it actually held alot better - followed by the second - and i was amazed - this will surely help speed up the project with the other pieces - or maybe it was warmer outside than when i had tried it in the mornig -
i am using the Dupli-Color® High Performance Vinyl & Fabric Coating - which indicates Formulated with a maximum adhesion promoter so there’s no need for primer. It’s fast drying and won’t crack, peel or chip -- but still it was coming out bubbly and not sticking very well -- whether the weather had anything to do with it or not i still would use the Adhesion Promotor first This post has been edited by celicarus: Jan 10, 2006 - 6:06 PM |
lol, im not much of a fan of anime, but i still dig your cluster...id feel weird driving in the car with my mom or girlfriend, but other then that, its nice. Im anxious to see how all this turns out....
well i'm glad i don't have the problem with my mom ever being in my car - even if she is, she wouldn't say anything - as for my gf, she's open minded although she hasn't seen it yet . - i think i'm half way done with the pieces - sucks waiting for the pieces to dry after each coat - the worst part is the top clear coat - its a small can that cost the same as the color cans -
update of whats completed so far -
![]() ![]() need to get 2 more cans of clear coat This post has been edited by celicarus: Jan 11, 2006 - 6:06 PM |
damn that's alot of white. can't wait to see what it looks like when you put it back together
![]() Enthusiast ![]() Joined Jan 7, '06 From arizona Currently Offline Reputation: 0 (0%) ![]() |
how'd you do that to your gauges, with the pictures? thats hot.
using MS Word - printing out on blank transparencies - just gotta size the pictures to fit onto the gauges - and then cut them out and lay them over your gauges - got the idea from another member on here - but not sure how he/she did it - i just thought thats how it was done -- oh one more thing - gotta have laser jet color printer - inkjet won't do -
tip - print it out black and white on regular paper and resize until it fits - This post has been edited by celicarus: Jan 12, 2006 - 4:25 PM |
here is a pic of the gauges - i won't be able to finish by this weekend as I wanted too since I have to go out of town with the celica -- here comes another 1400+ miles --
![]() i think i'm also gonna paint the steering wheel hub part - haven't really taken a deep look about it - hopefully i don't have to remove the steering wheel This post has been edited by celicarus: Jan 12, 2006 - 8:57 PM |
Lo-Fi Version | Time is now: February 17th, 2025 - 4:29 AM |
