> cant open hood!!!
post Jan 9, 2006 - 5:16 PM
LusciousLeftFoot
Joined Nov 13, '02
From Boston
hi,
the other day i tried to open the hood to change the oil and found out that the cable came loose or snapped, not sure which open but i cant open the hood using the pull switch.. i need some help, how else can i open it?
i looked underneath the car and i can see the other end of the cable close to the radiator..
also i am getting a gas smell coming from the front of the car and it becomes really strong when i am driving and when the vents are open pulling air from outside.
please hellpp
thank you..
any help is appreciated...
post Jan 9, 2006 - 5:49 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
hmmm... dont know about ur hood cable, but i wouldnt be pulling in air from the outside through your vents if it smells like gas. it's probably not something you're looking to breathe in, especially without your windows down. goodluck with the fix, sry to hear about that.
post Jan 9, 2006 - 9:23 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
Put the car up, find the hood cable and yank, make sure to buy a replacement before you close it.
DTE
I am a thief.
do not buy anything from me.
post Jan 9, 2006 - 9:33 PM
dont know whats cauing your gas smell...but dont drive it like that untill you figure it out, or it could cause a fire.
check the cable as it connects to the lever under the steering wheel and make sure that it didnt just come loose there. if thats fine..... jack up the car, undo the underbody plastics and try to access the latch from under there.
post Jan 9, 2006 - 9:51 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Sounds almost, like someone jacked your car. They probbaly disconnected a fuel line and was hoping that it blew up when your driving down the streets. Its a good idea to take a look at your enemies list and find out who wants your hide now. A disconnected cable is bad enough, but fuel leak? Soubnds like foul play to me.
post Jan 19, 2006 - 9:01 PM
LusciousLeftFoot
Joined Nov 13, '02
From Boston
no, the wire came loose from the latch on the hood, when i got underneath the car i can see the end of the wire, i tried yanking and pushing on the latch from the bottom but no luck, and i think the seals might need replacing but cant verify until i can get hood open...
any other ideas??
anyone that has opened the hood , can you check where the wire is attached and possibly snap a pic and post?
thanks..
Lo-Fi Version Time is now: November 28th, 2024 - 4:28 PM
