sound suggestions |
sound suggestions |
May 19, 2003 - 11:04 PM |
Enthusiast Joined Apr 18, '03 From milwaukee, wisconsin Currently Offline Reputation: 0 (0%) |
well i got my car fixed finally costing me 400 which isnt too bad after having 153k on it, but anyway back to more important things. I have a 12 disc cd changer in the trunk and i need a better sound system to go with it, any suggestions for speakers that have good bass power to them because i need trunk space for other stuff so unless i cant my golf clubs in the trunk, there will be no subwoofer in the trunk or backseats.
May 20, 2003 - 12:07 AM |
If you're up for some work, you could put 8" subs in the doors and then put some 5.25" or 6.5" speakers somewhere else, such as in custom kick panels. If you just want to replace the speakers in the door, let us know and we can suggest some good speakers for that.
May 20, 2003 - 12:03 PM |
Enthusiast Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
just to warn you, don't mess w/ the 4" speakers in the door you pretty much can't put anything else there. The 6 1/2s in the rear are really simple to install and i installed midbass kickers in my front doors. good luck.
May 20, 2003 - 3:09 PM |
so is it even worth adding better speakers in the front then? if not would be possible to add an 8 inch subwoofer in the trunk that doesnt stick out that far like past those black panels on the sides, sorry i cant look at car im in school and im not sure exactly what it is called, but you get the idea or how about a pair of them if that cant happen what are some good 6 1/2 inch speakers with some pretty good bass action that i can go for? thanks for suggestions
May 22, 2003 - 8:09 AM |
u can buy a bass tube that doesn't take up much space. U can install free-air subs in your front doors if u want alittle bump.
May 22, 2003 - 5:42 PM |
what would i have to add in the doors for pretty good bumb? My idea for 6-1/2 are some sort of boston acoustics for the back seats.
May 22, 2003 - 6:39 PM |
Enthusiast Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) |
I have a coupe and fit a JL 10" powerwedge in the trunk and can still fit my golf clubs/bag. Replacing the rear speakers as mentioned with 6.75" isn't a problem. But unles you live in Europe or Australia, you will have to make do with 6.75" speakers with an adapter to replace the 8" door speakers. The corners where the mirrors are mounted make an excellent spot for tweeters though not the perfect place. Also be aware you might need an amp etc., so you could easily start spending some money. In the beginning I just wanted to replace my factory am/fm radio, now I have replaced all speakers, installed an amp, added a sub, and have a new headunit and 5 disc in dash player. I'm holding off adding a second amp, and upgrading my speakers again.
Lo-Fi Version | Time is now: November 28th, 2024 - 12:25 AM |
