Adjusting idle... |
Adjusting idle... |
Jan 10, 2006 - 9:29 PM |
Enthusiast Joined Dec 7, '04 From Antioch, Norcal Currently Offline Reputation: 0 (0%) |
I put on a throttle body spacer today and it is making the throttle cable extend, where do I adjust the slack on the cable?
Jan 10, 2006 - 10:37 PM |
right on the cable...you should see adjustment nuts that let u give the cable more or less slack
Jan 10, 2006 - 10:51 PM |
How does the car feel with the spacer?
Jan 11, 2006 - 1:24 AM |
Well it sounded good as it reved to 6k lol...
But to the the right of the cable you say? Is there anyway you can point it out in a general pic of a 5sfe for me? |
Jan 11, 2006 - 1:43 AM |
see that bracket that holds the cable... to the right of the 2200 sticker? there are 2 nuts there ... you can use those to adjust the slack of the cable. pay no attention to the coil circled in pink...dont know how that go on there This post has been edited by lagos: Jan 11, 2006 - 1:43 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 11, 2006 - 4:14 AM |
Well ill be damned...Thanks alot Legos, ill have pics tomorrow...
Edit: Before i take my intake apart again, do the bolts have any specific jobs, like top to tight bottom to loosen etc? Thanks again This post has been edited by Vibe: Jan 11, 2006 - 4:17 AM |
Jan 11, 2006 - 4:29 AM |
Enthusiast Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
is there a spacer available for the 7afe and... what exactly are the advantages to getting one?
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Jan 11, 2006 - 1:47 PM |
Okay got it on this morning and with alot of work got the idle back down to 1k ish(the black bolths on the actual cable are the proper ways to adjust ya?), thanks alot for your help Lego.
Jan 11, 2006 - 1:54 PM |
whats up with the breather filters? the pcv from the valve cover goes to the intake for a reason.
Jan 11, 2006 - 3:38 PM |
Oh my bad, I reconnected that hose right now, and the one of the top vacume hoses keeps popping off due to the added length it has to strecth, is there anything I can do? Like an adhiesive i can put on the pipe so the hose stays?
Jan 11, 2006 - 3:56 PM |
Just get some longer hose.
-------------------- Project ST204.5 99.88946% complete... |
Jan 11, 2006 - 8:28 PM |
Enthusiast Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) |
Um you are actually have one nut on each side of that bracket. Not both on one side.
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
Jan 11, 2006 - 9:09 PM |
yeah...it looks like your spacer made that bracket to be in the wrong place... you probably will have to figure out how to move it over or get rid of the spacer...
what is the point of it anyway? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 12, 2006 - 3:49 AM |
Yeah that was how I was able to adjust the idle, and driving it around for a little bit today I havent had any problems with it, and the way the spacer is designed its supposed to allow better air flow, Ive noticed a bit of a gain and its louder. Plus I havent really seen anyone else do this before so I thought Id try it out...
Jan 12, 2006 - 11:08 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(lagos @ Jan 11, 2006 - 6:54 PM) [snapback]377222[/snapback] whats up with the breather filters? the pcv from the valve cover goes to the intake for a reason. Yeah plus with the breather filter on it it makes like a metallic cricket noise from all the exposed valve clatter. My first intake did that with only 30K miles on the car. Get a peice of hose and set it up right. Since you are into the red stuff like me you can even get a red hose for a couple of bucks at a descent performance shop. -------------------- |
Jan 12, 2006 - 11:13 AM |
QUOTE(Vibe @ Jan 12, 2006 - 3:49 AM) [snapback]377536[/snapback] Yeah that was how I was able to adjust the idle, and driving it around for a little bit today I havent had any problems with it, and the way the spacer is designed its supposed to allow better air flow, Ive noticed a bit of a gain and its louder. Plus I havent really seen anyone else do this before so I thought Id try it out... Are you sure you really got gains with this? Were did you get it and how much did you pay? If it's not to expensive, it might be something I would do. -------------------- Live Free, Be Happy
Jan 12, 2006 - 1:32 PM |
http://cgi.ebay.com/ebaymotors/90-99-Toyot...64534QQtcZphoto
Thats what I got, its not that inexpensive but I think its worth it. I wish I had Dyno hook ups so I could get a reading. |
Jan 12, 2006 - 10:27 PM |
QUOTE(Vibe @ Jan 12, 2006 - 1:32 PM) [snapback]377643[/snapback] http://cgi.ebay.com/ebaymotors/90-99-Toyot...64534QQtcZphoto Thats what I got, its not that inexpensive but I think its worth it. I wish I had Dyno hook ups so I could get a reading. LOL. $80? You're joking. You had better of gotten some real gains from that thing. $80, shoot. -------------------- Live Free, Be Happy
Jan 13, 2006 - 7:37 PM |
Enthusiast Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) |
Do you know why you had to adjust the throttle cable? The reason is that this spacer is for the 97-99(5sfe) celicas with a different throttle body assembly and throttle cable placement. The way you have it hooked up with the cable that is not secured with bolts on both sides, is dangerous because if it falls off while your driving you can't accelerate anymore. I suggest to drill new hole on the bracket so you can give the cable more slack or sell it. I just don't want you to get hurt.
Jan 13, 2006 - 9:22 PM |
Hmm thats a good point, it seems pretty secure in the little holding area its in now, plus the first bolt is tighted up against the mounting thing...
Lo-Fi Version | Time is now: January 9th, 2025 - 10:13 PM |
