18 Pages V  « < 4 5 6 7 8 > »
> Wheel Offset Guide, Unsure about proper offset? Look here first.
post Jan 20, 2008 - 3:39 AM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
QUOTE(6strngs @ Jan 19, 2008 - 1:43 PM) [snapback]632370[/snapback]
QUOTE(Penkka @ Jan 19, 2008 - 3:27 AM) [snapback]632319[/snapback]
QUOTE(Daftboy @ Jan 18, 2008 - 3:52 PM) [snapback]632075[/snapback]
What size spacers should i get to get my wheels flush ...i have 17x7JJ at a 42 offset....my ride is lowered 1.5 inches...any help would be great. The rear tires are really far in and would like too pull them out.
Why do you guys buy so narrow rims? Wider rims and tires always look better and makes the car better to handle.
more expensive, and also weighs a bit more so it'll negatively affect accelleration. there's also a much wider selection of 17x7 then there is 17x8.
My summer rims are 16x8.5 and I think the car handles awesome with them.
QUOTE(Culpable04 @ Jan 19, 2008 - 3:07 PM) [snapback]632400[/snapback]
and if you live where you get snow and your celi is a daily driven car, wide wheels / tires will make you the laugh of the road with the minimal sign of snow.
You think it doesn´t snow in Finland tongue.gif thats what studded tyres and winter rims are for!
This post has been edited by Penkka: Jan 20, 2008 - 3:41 AM
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
post Mar 26, 2008 - 9:05 PM
99GT
Joined Dec 14, '06
From MN, USA
8.0"-----40mm
If I get 17x8.0 with 42mm offset. That will be flush? No problems?
1.75 drop all around with Intrax springs.
42mm would be more sucked in after re-reading.
32mm would be too much and need spacer correct?
I don't really get this offset thing haha.
I'm planning on some Work Emotions.
This post has been edited by 99GT: Mar 26, 2008 - 9:24 PM
post Mar 27, 2008 - 1:17 AM
6strngs
Joined May 12, '06
From Wilmington, NC
99GT, I just installed some knock-offs of those wheels today. they were 17x8 with a 35mm offset. they are very flush in the front, but could stand to come out a couple mm more in the back. I think for a true flush look, we'd need to run staggered. perhaps 35 in the front and 25 in the back? I'm not sure yet.
btw, I'm lowered on teins and kybs.
post Apr 20, 2008 - 5:54 PM
chrisalphonsus
Joined Jun 21, '05
From toronto
doe any one know if a 18 inch mercedes rims ( leaxni ) will fit a celica it has a universal bolt pattern and has a 225/40/18 tire , please help it was on a 2000 mercedes e320
post Apr 21, 2008 - 12:25 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(chrisalphonsus @ Apr 20, 2008 - 3:54 PM) [snapback]666438[/snapback]
doubt it. german cars use different bolt patterns than japanese cars. universal 5-lug wheels for japanese cars usually have 5x100 and 5x114.3 bolt patterns, while a lot of mercedes and BMW use a 5x112 bolt pattern.
for the record, our cars have a 5x100 bolt pattern. and it'll be hard to fit anything wider than an 8" wheel without modification.
post Apr 27, 2008 - 6:44 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I'm looking at a set of wheels that are 17x7.5, and the offset on them is +35. I'm lowered 1.5", how well would these work?
They also offer +20 and +48 offsets as well, now I've heard that the rear need a bit of a higher offset, so could I get +35 in the front, and +20 in the back?
I do not want to have to run spacers. And I would like them to be flush.
-Matt
This post has been edited by GotToyota: Apr 28, 2008 - 11:34 AM
post Apr 28, 2008 - 11:34 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Anyone?
post Apr 28, 2008 - 3:48 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(GotToyota @ Apr 27, 2008 - 4:44 PM) [snapback]668706[/snapback]
-Matt
they'll fit. they are only 2mm more sucked in than the guide recommends. they'll look good
post Apr 29, 2008 - 8:11 AM
trdproven
Joined Aug 2, '05
From Guam
I'm running 17x7.5 with +32 offset, they are fine.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 30, 2008 - 6:51 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Sweet, looking into getting these wheels soon, along with a set of 225/45/17.
-Matt
post May 4, 2008 - 10:47 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Just to make sure before I order, the wheels at 17x7.5, and a +35 offset will be flush with the fender?
BTW, my car is lowered 1.5" all around.
-Matt
This post has been edited by GotToyota: May 4, 2008 - 10:52 AM
post May 4, 2008 - 12:52 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I've got 17x8 with a 35 offset. They sit super flush in the front, and sucked in about 5-10mm in the back. a 17x7.5 with a 35 offset is going to be 6mm more sucked in than mine. so, ideally you'd want a 17x7.5 with a 29mm offset for them to be really flush. but it's only a 1/4 of an inch that they'll be sucked in.
post May 4, 2008 - 2:12 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(6strngs @ May 4, 2008 - 12:52 PM) [snapback]670545[/snapback]
Awesome.
They also have +20 as well, would they be better for the rear, and then the +35 for the front?
-Matt
post May 4, 2008 - 7:07 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(GotToyota @ May 4, 2008 - 12:12 PM) [snapback]670560[/snapback]
Awesome.
-Matt
that's probably a little too much for the rear. it might stick out like 2-5 mm past the fender.
post Jul 15, 2008 - 12:53 AM
SoDo
Joined Dec 16, '07
From Chicago, IL
So if i had 17x7.5, would i want the offset to be 30 or 40? What would it need to be if the car was lowered 1.5"?
1999 Celica GT Hatchback
post Jul 15, 2008 - 9:20 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (SoDo @ Jul 14, 2008 - 10:53 PM) *
go with the 30 offset... read the last 4-5 posts above yours for someone who pretty much asked the same question.
BTW, I really wish they had a guide that was this easy to understand for the alltrac! They do for the ST185, but it seems that information is really hard to find for the ST165 frown.gif
This post has been edited by 6strngs: Jul 15, 2008 - 9:21 AM
post Jul 15, 2008 - 10:34 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
Nice. thanks for the info. i wanna put these on my car http://www.rotawheels.com/wheels.asp?wheelid=39 I wouldnt need to have a different offset for front and rear right?
post Jul 16, 2008 - 9:18 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (SoDo @ Jul 15, 2008 - 8:34 PM) *
you don't need a different offset for front and rear unless you're trying to get them super flush which isn't necessary. if anything you'd want a lower offset for the back and the lowest they have for that wheel is 30. Don't worry about it though, just get the 30 and it'll look good smile.gif
post Jul 16, 2008 - 11:47 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
I'm plannin on getting the silver ones, possibly the gunmetal. I need to find a local shop or website that can order these for me.
post Jul 17, 2008 - 9:23 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (SoDo @ Jul 16, 2008 - 9:47 PM) *
*cough* *cough* gunmetal *cough* *cough*
I didn't have great experience with rota... I ordered a set through my work (discount tire/america's tire) and they said there was a 6-8 week wait on them. so I waited, and waited, and waited, and after 9 weeks finally decided to call them to see where my wheels were... they told me that they had no record of the order! but that they had them in stock and would be there in a week. cool. so a week and a half later I call them and they said they had no record of the order again... so i said screw you and got a different brand.
Lo-Fi Version Time is now: November 30th, 2024 - 2:13 PM
