Wheel Offset Guide, Unsure about proper offset? Look here first. |
Jun 27, 2011 - 4:10 AM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
It doesn't really 'Cut' into it at all really. Theres no wear on the tires from the guards, more the Negative camber i have. When turning a corner more aggressively, the body of the car moves down more onto the side of the tire.
So, depending on your suspension setup, and negative camber, you shouldn't run into many problems with your tires getting sliced. -------------------- |
Jun 27, 2011 - 9:57 PM |
Enthusiast Joined Feb 9, '09 From Toronto Currently Offline Reputation: 2 (100%) |
Hmmm I just physically measured 40mm gap in front and 30mm in back from tires to fender? That's kind of weird i thought the back had more of a gap than the fronts
Jul 6, 2011 - 3:30 PM |
Enthusiast Joined Dec 23, '10 From PA, USA Currently Offline Reputation: 0 (0%) |
Hi guys, a speedy response would be amazing. I'm going to order 15x7" Diamond Racing Steelies I want them to stick out and be much more flush than the stockers, but I don't want any troubles or have to do anything extra. Wht would a good offset be? Maybe 25mm? |
Jul 15, 2011 - 10:57 AM |
Enthusiast Joined Nov 23, '07 From BC Currently Offline Reputation: 0 (0%) |
Any thoughts of spacers needed on 17x7 215/45/17? I believe offset is +45 on them and they're as sucked in as can be lol i have about 1mm clearance from coilover in the rear. What's a good spacer i could use? Disregarding ride height because that can be adjusted. Btw anna i got tein superstreets and love them, im sure megan's are about the same quality but a bit less expensive possibly 15mm spacer up front and 20mm spacer in the rear, but I'm not quite sure if your looking for flush look or not? so the teins run really good? i was thinkin of getting those but the cost quite a bit more than the megans! .... hey i was lookin at your pics... and how did u make all ur interior lights blue?!?! |
Sep 15, 2011 - 3:57 AM |
Enthusiast Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) |
ok soo looking at a set of motegi MR125 @ 17x7.5 et 42(only option they have for the 5x100) after reading this thread, it would seem that i will need a 10mm in the front and 15mm in the rear. the car has a 1" drop lowered on sprint springs. looking to perhaps put a set of 235 45 r17's on em..
any ideas if it will rub at all? -------------------- |
Sep 15, 2011 - 9:01 AM |
Enthusiast Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) |
Here's my mark. I have 17x8 +35 with 235-45-17 all around. In the rears, I'd need 25mm spacers for flush and fronts need 15mm spacers for flush. My 15mm spacers made a difference in the rear, 10mm more and i'd be flush. I'm dropped 3" in the front and 2" in the rear with megan coilovers. Front were "ghetto" rolled (psh new front end next spring) and rears unrolled. My rears rub quite a bit on bumps. I raised the front .5 and it still rubbed so I dropped it back down to 2". Oh well. Yes, fronts were rolled but they stuck in and rubbed my tires quite a bit. Going straight wont rub but turns are annoying as hell.
So in all, get something around 17x8 +10 rears and +20 fronts would've been flush as hell. But, the wheels make all the difference in the world! Check bore, etc, etc. 17x7.5 with a 10mm spacer isn't going to do jack to your car. if you have 17x7 with 40+ offset on up, do your homework as you need a huge chunk of spacer to cover that gap. Think about it, +35 is the magic number so think lower, NOT higher! This post has been edited by block: Sep 15, 2011 - 9:03 AM -------------------- |
Sep 15, 2011 - 9:07 AM |
perfect example of flush. there are going to be angles where it looks as if the wheels are sticking out. though, +10 & +15 makes a tiny difference. either way, it's as close to flush as possible. -------------------- |
Sep 15, 2011 - 2:13 PM |
Here's my mark. I have 17x8 +35 with 235-45-17 all around. In the rears, I'd need 25mm spacers for flush and fronts need 15mm spacers for flush. My 15mm spacers made a difference in the rear, 10mm more and i'd be flush. I'm dropped 3" in the front and 2" in the rear with megan coilovers. Front were "ghetto" rolled (psh new front end next spring) and rears unrolled. My rears rub quite a bit on bumps. I raised the front .5 and it still rubbed so I dropped it back down to 2". Oh well. Yes, fronts were rolled but they stuck in and rubbed my tires quite a bit. Going straight wont rub but turns are annoying as hell. So in all, get something around 17x8 +10 rears and +20 fronts would've been flush as hell. But, the wheels make all the difference in the world! Check bore, etc, etc. 17x7.5 with a 10mm spacer isn't going to do jack to your car. if you have 17x7 with 40+ offset on up, do your homework as you need a huge chunk of spacer to cover that gap. Think about it, +35 is the magic number so think lower, NOT higher! thanx block, yeah, if i could i would get a set @ 35mm ET.. the thing is that this set comes in at just over 16lbs per rim, for a 17" rim. And they are in the $155 range, making them one of the lightest and cheapest rims on the market.. and i auto-x ( but this will be my DD so mostly an ocational weekend worrior) so looking to stick as much meet as i can w/o rubbing.. sooo i should be ok right? even w/o the spacers? im not looking for hella flush or even a hard tuck, just dont want them to be too sucked in, and get a better stance to manage my center of gravety during a race. -------------------- |
Sep 19, 2011 - 10:43 AM |
Enthusiast Joined May 23, '11 From The Netherlands Currently Offline Reputation: 0 (0%) |
Is there a way I can make 18x9,5 +34 front fit without cutting fenders? I'm sure some negative camber will be needed. What tires will I need to prevent rubbing?
I know it's not to everyone's taste, but I'm trying to go for "hellaflush". This post has been edited by Ehrgeiz: Sep 19, 2011 - 10:43 AM |
Sep 21, 2011 - 1:38 AM |
Enthusiast Joined Sep 15, '10 From Levin, New Zealand Currently Offline Reputation: 0 (0%) |
I'm looking at a set of Work Emotion CR Kai's for my gt4, They are 17x7 with an offset of +47. What size spacers would you recommend ?
Sep 21, 2011 - 2:56 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
I'm looking at a set of Work Emotion CR Kai's for my gt4, They are 17x7 with an offset of +47. What size spacers would you recommend ? I recommend you visiting this thread..... http://www.6gc.net/forums/index.php?showto...;hl=flush+wheel -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Sep 22, 2011 - 4:24 PM |
Enthusiast Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
Alright, I've got a set of 18x8.5 +30 XXR 522s
I've also got a lead on some 25mm spacers for the rears for cheap. I was thinking that its going to put me at a 5mm poke in the rear and tucked 8mm in the front. Am I right in my calcs? -------------------- ~bloodMoney
Sep 22, 2011 - 9:43 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Alright, I've got a set of 18x8.5 +30 XXR 522s I've also got a lead on some 25mm spacers for the rears for cheap. I was thinking that its going to put me at a 5mm poke in the rear and tucked 8mm in the front. Am I right in my calcs? Right on the rears, but you're only going to be tucked 3mm in the front. Edit: Btw, you sure they'll fit? Because I looked up that wheel and it looks damn good, and while looking for prices, I found a 17x8 wheel, the ET48 one is 5x100, but the ET35 one is not. And just to check, I looked at the 18x8.5 ones and the ET30 ones are all 5x114.3/5x120. The ET48 ones are 5x100, which unless you did a lug conversion, is what you need. Just giving a heads up. This post has been edited by HectortheRican: Sep 22, 2011 - 9:52 PM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Sep 22, 2011 - 11:12 PM |
Enthusiast Joined Oct 2, '07 From Manitoba, Canada Currently Offline Reputation: 6 (100%) |
yea the 18x8.5 +48 would work with 15 mm spacer front and 25 mm spacer rear. here's a pic of that wheel with that size and offset.
Sep 23, 2011 - 11:44 AM |
I picked up a set that is ET30 with the 5x114/120.
I never told the guy what I drove, but when I asked for specs, he gave me 5x100 ET38 lol Like I said, I'm got got a buddy with conversion spacers for the rears and I was planning on doing the Rav4 hub conversion in the front. I just needed to make sure that the 25mm spacer isn't going to poke me too far out. -------------------- ~bloodMoney
Dec 26, 2011 - 8:53 AM |
I'm considering replacing my wheels since the tC things are heavy, and one of mine is apparently slightly oval. Still, I can play with spacer fantasies:
Only $120, not including shipping, cheaper than I thought quality spacers were. Now to decide between 15 or 20mm. I still feel like a 17x8 would be a much better base to start with. Also, not going for herraflush whatsoever, it's just that the tC wheels are fairly sucked in. This post has been edited by SwissFerdi: Dec 26, 2011 - 8:54 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Apr 9, 2012 - 10:16 AM |
Enthusiast Joined Nov 26, '11 From Jersey City, NJ Currently Offline Reputation: 0 (0%) |
Don't know if it's possible or if u guys will disagree with me but I just bought a set of Miro stp1 Rims, size-17x10- 5x100/112- offset 25, with falken ze-912 215/35zr17 Tires.... Which I hope I can some how put on.. I was told to do research on which will be the safest way to instal these.. I have stock suspension pretty much a stock 95 celica st liftback...I have seen a 7th gen with 18x10 and it looked really nice. Any help or ideas.. Sorry if this is a repost.
Apr 9, 2012 - 12:32 PM |
Enthusiast Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
If I wanted a deep lip on my rims (like in the pics below) and I decide to go to say discount tire or I order online, what numbers would I be wanting to write down so I could be sure the parts dealer knows what Im looking for? I already have a size for height 17x ?, 5X100 but as far as width and offset Im completely lost.
-------------------- From Japan to Texas my st202 follows me.
Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Apr 9, 2012 - 12:37 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Its hard to find a wheel with that deep of a lip without getting into the really wide widths, >9" wide.
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Apr 9, 2012 - 12:42 PM |
Ok say I want to go 9, 9.5, or even push the limit to ten. what would be my asking numbers then? I already know the modifications thats required and ready to do it. Just more concerned about my numbers. Say I wanna go 17x9-9.5 5x100. What would be my offset to get that kind of lip?
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:15 PM |
