![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) ![]() |
I want some 16x8s for my car.. would most likely be lowered.. what offset should I look for?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
40mm should fit just fine.
-------------------- ![]() Project ST204.5 99.88946% complete... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) ![]() |
i have 17x8 with a 32 mm offset and they rock
edit: didnt answer your question, id go with 32or 35mm offset This post has been edited by devilsden97: Jul 6, 2006 - 6:40 PM -------------------- ![]() Kawi Love |
QUOTE(devilsden97 @ Jul 6, 2006 - 6:39 PM) [snapback]452757[/snapback] i have 17x8 with a 32 mm offset and they rock edit: didnt answer your question, id go with 32or 35mm offset But how low are you? 32mm would probably be just fine on a car if it's not too low and not running too wide of a tire, but if you are really low and want to ride on comfortable tires my bet is on the 40mm offset. -------------------- ![]() Project ST204.5 99.88946% complete... |
im on sportline springs....and on 225/45/17 tires Falken 512 ziex's to be exact
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(devilsden97 @ Jul 6, 2006 - 6:50 PM) [snapback]452769[/snapback] im on sportline springs....and on 225/45/17 tires Falken 512 ziex's to be exact Those will fit a 7.5" rim fine. If you are going to go for an 8" rim, I would look for a slightly larger tire if traction is an issue. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
So 8in is too wide for 225/50s? what size tires would be good for 16x8 245/40?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) ![]() |
QUOTE(jdg371 @ Jul 7, 2006 - 9:08 PM) [snapback]453103[/snapback] So 8in is too wide for 225/50s? what size tires would be good for 16x8 245/40? No it's not. For 225/50s you can use 6.0 - 8.0 rims see topic here ("recommended combinations rim and tire widths" table) for more info ![]() -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
![]() Enthusiast ![]() ![]() Joined Feb 26, '05 From Sweden Currently Offline Reputation: 0 (0%) ![]() |
ok, so i'm totally retarded when it comes to rims and offsets. think i've got a 17" x 7.5 rim, how wide spacer will i need to make the wheel flush with the body?
edit: the car is lowered This post has been edited by Predator: Oct 24, 2006 - 4:21 PM -------------------- ![]() |
What is the offset of your current wheels?
i think it's 35
![]() Enthusiast ![]() ![]() Joined May 25, '06 From South Carolina Currently Offline Reputation: 3 (100%) ![]() |
I am going to upgrade to these Konig's
http://buywheelstoday.com/products/?id=2749 which ones should i get the 18' 7.5 with 45 offset or 8 with 40 i dont know how to roll fenders, and would rather just bolt these on, does anyone suggest one over the other, will i rub the wheel arch or anything? some help would be greatly appreciated. and all that offset stuff confused me, i would like to get the rim flush, as a bolt on (no spacers or w/e), and my car is lowered. Thanks! This post has been edited by Griff: Nov 14, 2006 - 7:14 AM -------------------- ![]() |
anyone?
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) ![]() |
18x8 +40 will be fine...
is the '...' , mean anything like...probbally? or you confident, id hate to screw up a 1000$
and i guess ill run 225's on 8? -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) ![]() |
ok so im installing 15mm spacers and id like a 17x8 wheel...what offset should i be looking at? my car is also lowered about 1.2"
40mm. No spacer.
QUOTE(WannabeGT4 @ Nov 27, 2006 - 12:09 PM) [snapback]505550[/snapback] 40mm. No spacer. ok, i figured i should have never bought the spacers. i can only seem to find 17x8 w/ a 35mm offset, i dont think it should be a problem though because my car is lowered on H&R springs that drop it about 1-1.2" I am also going for the same overall diameter. Correct me if im wrong. this topic rocks by the way, thanks man. This post has been edited by Jdog1385: Nov 27, 2006 - 1:36 PM |
![]() Enthusiast ![]() ![]() Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) ![]() |
Just had a blow out so need some help.
I took the alloy of & wondered if it is the correct offset etc. read through the post but im still confused. I'm running a 215/35/18 7.5j 48 offset according to numbers on the inside of the rim i assume are offset etc. thanks -------------------- My Celica Is Now For Sale
![]() Enthusiast ![]() ![]() Joined Oct 11, '06 From calgary Currently Offline Reputation: 5 (100%) ![]() |
some guy is selling his 7.5", + 45mm, 225/45/17 which I'm guessing won't be too well for a stock suspension celica since the off set is too high. Am I right?
Lo-Fi Version | Time is now: April 23rd, 2025 - 3:16 AM |
