turbo problem |
turbo problem |
Jan 11, 2006 - 7:11 PM |
Enthusiast Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
ok so i have been running 7 psi for the past few months in my 7afte and every thing has been fine accept for a little oil burning off but its no big deal. so the other day i go to get in my car and pull out of my drive way and notice a HUGE difference. i look down at my boost guage and see that iam running 12 PSI. so i was like ok, this is kool and left it alone. that was two days ago and today i go to drive it after not touching anything and notice that iam running 0PSI. i checked the intercooler piping, waste gate and MBC and everything is fine. the turbo also sounds different, it has a more high pitched whistle to it and sounds more like a supercharger...weird... any idea whats going on??
Jan 11, 2006 - 7:54 PM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
bov? even though that wouldnt explain why the 12 all of a sudden. id just check all the vac tubes, maybe take out the mbc to see if that does anything. check the connection to the back of the boost guage (i assume you feel no boost as well?) i think that if you can hear your turbo spool you probably have a loose connection somewhere in either the ic piping or vac tube.
This post has been edited by CheesyLobster: Jan 11, 2006 - 8:02 PM |
Jan 11, 2006 - 8:04 PM |
the BOV goes off after i let off the gas but only after 4K after i start to here the turbo spool up. ill double chec the vaccume lines and intercooler piping later tonight.
Jan 12, 2006 - 2:34 PM |
i checked over eveything again and eveything is fine....i think my turbos haunted or something lol
Jan 12, 2006 - 9:12 PM |
you may need a rebuild or to have someone atleast take it apart and look at it.
Jan 12, 2006 - 10:52 PM |
There is a vacuum leak somewhere....might be simple and inexpensive....could be bad. Check out this thread for a way to find it:
$30 boost leak tester -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jan 12, 2006 - 10:59 PM |
ok, so the problem was that the screw to make the BOV harder and softer fell out so the BOV was fully open and was letting all the air out but i allso saw that one of the blades to the turbo has a major chip in it. the shaft isnt loose or anything but the chiped blade is bothering me.
Lo-Fi Version | Time is now: November 28th, 2024 - 11:49 AM |
