Just a random idea...peltier TEC cooling on Water - Air intercoolers |
Jan 12, 2006 - 4:20 PM |
Enthusiast Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
I build custom computers as a part time job..sometimes these things involve watercooling with 1/2od piping and thermal electric cooling using a peltier unit and external powersupply...a peltier is a square wafer that comes in different wattages...when power is run through the peltier, it amplifies the difference in temperature between the two sides...so on a water cooling system u can place a waterblock on the hot side of the wafer apply wattage and the cold side will be DRASTICALLY colder than the waterblock normally under freezing temperatures...peltiers are common in drink machines and other industrial type machinary to cool water circuits as well (kind of like a radiator that runs off electricity)....check out this peltier from swiftech cooling this is basically the same idea except it actually cools the water that runs through it unlike a cpu application cooler.....now if this was applied to the 3rd generation 3sgte water - air intercooler what would the effects be?????
This post has been edited by MonsterBOX: Jan 12, 2006 - 4:22 PM |
Jan 12, 2006 - 5:08 PM |
Interesting idea - but how much pressure can these handle? The water pumps on the intercoolers might damage the peltier.
Jan 12, 2006 - 5:37 PM |
these peliter cooling systems arent just for average pcs...1/2inch piping that uses aquarium pumps up to 355gph at 50psi max..its pretty heavy duty stuffPump...when ran on a water circuit it can bring water temps down to below 30 degrees requiring antifreeze mixture..
This post has been edited by MonsterBOX: Jan 12, 2006 - 5:42 PM |
Jan 12, 2006 - 7:54 PM |
http://www.google.com/search?hl=en&lr=&q=p...ler&btnG=Search
General consensus is that it's not feasible due to the high current draw and heat exchanger requirements. -------------------- Project ST204.5 99.88946% complete... |
Jan 12, 2006 - 9:29 PM |
i donno...the results on that search were for spraying cold water through the intercooler thats a totally different deal then using a swiftech circuit cooler...its a waterblock with pelitiers facing backwards to actually cool its self so the freezing block cools water as it passes through which should be alot more effective than the method shown in the search...there is absolutely no way that it could not be effective in cooling power...there are industrial type peltiers as well that were developed by nasa for the exact same things which are cheap now for drink machines in such..if i had a water to air intercooler i would def try this...u could just attach it in the middle of a water return line and place the powersupply somewhere on the engine bay and run it off the battery..draws less power than a sub amp
Jan 12, 2006 - 9:42 PM |
There was more than that one idea in the search results. None of them showed any promise.
Jan 13, 2006 - 9:47 AM |
Enthusiast Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
its a cool idea but were not talking about a 3" 60 watt pelter anymore.
the current draw of the pelter would be insane, not something you could hook up to your fog lights. also the radiator for the thing would be huge. TEC is cool though dont get me wrong, it helped me get my little AMD 2500 barton to 2.56 ghz. -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Lo-Fi Version | Time is now: November 28th, 2024 - 3:41 PM |
