13 Pages V  « < 10 11 12 13 >
> The MR2T tranny "short axel" solution, For those that want to know...
post May 23, 2007 - 9:25 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Supersprynt @ May 23, 2007 - 3:11 PM) [snapback]560939[/snapback]
No, its pertty difficult for me to describe. I have one sound that sounds like the dust plate is scraping my rotor when I turn one direction, but can't find any evidence of it. The other constant one sounds like what I could only describe as ball bearings without lubrication. My first thought was CV joints but I packed that CV with grease after I took it apart and I don't think the bearings in the CV move like that.
IDK if anybody can relate to hearing noises you know aren't supposed to be there and not being able to locate. mad.gif
Did you torque the axle nuts to 159 ft. lbs. ???? Did you ever put the wheels on the ground without the axle torqued in the hub? Your wheel bearing may have got wiped out.
post May 23, 2007 - 9:28 PM
Putting the wheel on the ground without the hub bolted doesn't sound like something I'd do, but I can't say for sure.
If it was my wheel bearing, I'd actually be relieved its not the axle.
post May 23, 2007 - 9:37 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Supersprynt @ May 23, 2007 - 9:28 PM) [snapback]561041[/snapback]
If the sound gets louder while turning left, then the passenger wheel brg. is bad. If its the other way around, its the other wheel brg.
post May 24, 2007 - 7:20 AM
It sounds exclusive to the right side. Right front to be specific. But sometimes sounds play with your ears.
post Jun 5, 2007 - 9:15 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
Just a thought...
Could it be that some problems are related to the fact that there is a small "pocket" in the inner stub, in which a ball bearing can fit half way. Is it possible that blocking the bearing from going into the groove of the second spacer is limiting the maximum travel that the axle can make?
This post has been edited by K-ESD: Jun 5, 2007 - 9:15 PM
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 13, 2007 - 3:28 PM
K-ESD
Joined May 5, '05
here's my new spacer
Machined from a alltrac stub with a ring in behind to fill in the gap. It's so close you can hardly see it. Notice the two shades of metal at the back. The ring is machined to fit into the lip of the long MR2 inner stub.
The whole thing (w/o counting in the lip) is 1/2". Hopefully it is the right size. The idea was to keep the design exactly as it was before with the pocket in the inner axle but moved ahead 1/2". If I don't get tied up too much I should have it on this weekend. I'll let you know how it works out.
post Jun 13, 2007 - 6:05 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Thats pretty much what I did. Its worked out well so far. I used the factory spacer and cut a section 1/2" off the end. Then I put that on the brake lathe and machined it so it would fit into the hub of the mr2 inner. Good luck.
-toyotacrazy
post Jun 15, 2007 - 3:21 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(Supersprynt @ May 23, 2007 - 1:11 PM) [snapback]560939[/snapback]
http://www.6gc.net/forums/index.php?showtopic=47411
EXACTLY THE PROBLEM I HAD!!!!!!! its got to be your wheel bearing. I changed axle, the carrier bearing and finally the wheel bearing and it finally went away!!
Im in the middle of making a how too
post Jul 27, 2007 - 6:26 PM
Joined Jan 27, '03
From st.lucia
ok i used a 1 inch spacer and everything works well so far except a little vibration at high speeds. if i knew then what i know now, i would have never sold my gt gearbox and axles.
post Jul 28, 2007 - 12:50 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(1900 @ Jul 27, 2007 - 6:26 PM) [snapback]583067[/snapback]
cut the spacer down to 1/2 inch
post Aug 2, 2007 - 5:41 PM
Joined Jan 27, '03
From st.lucia
with the 1/2" spacer the camber is off and the tire wears badly on the inside and keep in mind that the car is lowered with eibach sportlines and running 18" wheels.
post Aug 2, 2007 - 7:37 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(1900 @ Aug 2, 2007 - 5:41 PM) [snapback]584778[/snapback]
The axle wont affect camber unless you are loosining everything and cramming the axle into the hub. With it lowered you may not need a spacer.
post Aug 10, 2007 - 2:56 AM
Alan
Joined Jan 23, '05
From Malta
HEY GUY THIS THREAD GOT EXTREMY LONG COULD SOME ONE SUMARISE THE BEST WAY TO DO THE E152/3SGTE AXLE SEPUP, I AM ABOUT TO DO IT WHAT SPACER ARE THE BEST TO USED WITH WHAT AXLES AND WITH WHCIH HUBS ECT.
I AM ABOUT TO BUY EVERTHING BRAND NEW SO DONT WANT TO BUY PARTS FOR NOTHING CAN ANYONE POST?
SO FAR THIS IS WHAT I GOT;
MR2 TURBO E153 LSD GEARBOX
ST205 SHIFT CABLE (DONT KNOW WHY)
ST205 REAR AND DRIVER SIDE MOTOR MOUNTS
MR2 INNER C.V JOINT
ST185 SHAFTS
ST185 OUTER C.V JOINT
IF ANYONE CAN INCLUDE PARTNUMBERS IT WOULD BE GREAT
THANKS ALAN
This post has been edited by Alan: Aug 10, 2007 - 3:23 AM
post Jul 25, 2009 - 2:24 PM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
Sorry to resurrect this thread.. but im just wondering.. is that above setup the final conclusion for the short axel? im currently working on on a 95 MR2 tranny on my 3sgte setup.. so im just confused as to which axels you need to buy.. inner mr2 axel CV joint St185 outer CV joint.. then st185 shafts.. and im just wondering if anyone wants to answer alan's question 2 years later about the spacer?.. and does anyone have part numbers to these items.. that would b lovely =)
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
post Jul 27, 2009 - 2:44 PM
SlvrCelica09
Joined Jan 10, '09
anyone?
post Jul 27, 2009 - 3:15 PM
at one point in time, someone on here mentioned just using the camry (or was it solara?) axles. wonder how much truth there was to it.
This post has been edited by lagos: Jul 27, 2009 - 3:55 PM
post Jul 27, 2009 - 3:23 PM
mr2 inner axles and CV's, alltrac outters.
post Jul 27, 2009 - 10:24 PM
SlvrCelica09
Joined Jan 10, '09
ok... thanks guys.. sorry if i seemed anal.. its just killing me at the moment.. ill go ahead and get those axels.. hopefully it leads to sucess =)
post Aug 19, 2009 - 10:17 PM
i just read 12 pages, should have just come to the end, lol./
post Aug 21, 2009 - 11:28 AM
SlvrCelica09
Joined Jan 10, '09
QUOTE (njccmd2002 @ Aug 19, 2009 - 10:17 PM) *
only because i forced an answer lol or u woulda probably asked also
Lo-Fi Version Time is now: November 24th, 2024 - 1:52 AM
