factory power cable, at least take a look |
Jan 14, 2006 - 12:48 AM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
There seems to be two wires coming off the positive terminal of the battery
I am assuming that the thing one goes to a fuse box and the thicker cable goes to the starter motor? Any chance the thicker cable can be rewired or should I just use a cable joiner to lengten the cable Just having problems with my Optima battery install due to the factory wire being too short |
Jan 14, 2006 - 8:59 PM |
Knew this would happen.
Anyway for others, it is a short run of 4gauge wire which has a terminal at the end. Easily replaced. |
Lo-Fi Version | Time is now: November 27th, 2024 - 2:13 PM |
