> knocking from rear wheel
post Jan 14, 2006 - 2:22 PM
daveo
Joined Jan 9, '06
From lincolnshire uk
driving back home today got a strange knocking coming from the drivers side back wheel only does it when going forward and on each full reveloution of the wheel any ideas anyone
cheers dave
post Jan 15, 2006 - 1:41 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
jack rear up, shake rear wheel, if it wobbles its the bearing, if not, check rotors, calipers, brakes, tires.
post Jan 15, 2006 - 5:44 AM
daveo
Joined Jan 9, '06
seems to be coming from the hand brake when driving if i use foot bake still knocking but if i put hand brake on a little it stops ?
post Jan 15, 2006 - 10:22 AM
LewFX
Joined Jan 28, '05
could be warped rotors, when you brake does it pull to one side?
post Jan 15, 2006 - 11:54 AM
daveo
Joined Jan 9, '06
no doesnt pull under braking, doesnt knock all the time but loud when it does
jacked it up spun the wheel spins free for a while then goes stiff on each turn of the wheel then frees up again strange think im going to have to strip it all the way and have a look cheers dave
post Jan 15, 2006 - 12:59 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
This could just be a loose pad. I had this. When you break, it will go "thunk." Just put spacers in on the sides of the brake pads. It's not overly common, but it still happens a good bit.
Live Free, Be Happy
post Jan 16, 2006 - 9:34 AM
daveo
Joined Jan 9, '06
sorted now but thanxs for all ur help,jacked the car up spun the wheel noise was coming from the floating handbrake so now all quiet and drives like adream cheers again dave
post Feb 8, 2006 - 1:46 PM
SiN_CeLi
Joined Apr 6, '03
From Las Vegas
QUOTE(Bigmeanbulldog55 @ Jan 15, 2006 - 11:59 AM) [snapback]378951[/snapback]
My car is doing that right now. I tighten the caliper as tight as I could then I rebled the system to make sure there was no air. But whenever I hit my brakes at low speeds the rear brakes make a loud clasping noise. where do I get these spacers from. and the pressure from the piston won't warp them?
This post has been edited by SiN_CeLi: Feb 8, 2006 - 7:57 PM
post Feb 8, 2006 - 10:14 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(SiN_CeLi @ Feb 8, 2006 - 1:46 PM) [snapback]390837[/snapback]
These spacers go on the sides. Not on the pad. Tightening won't do anything. I guess you can buy spaces from autozone or something. I prefer to make everything.
Live Free, Be Happy
post Feb 8, 2006 - 11:22 PM
LewFX
Joined Jan 28, '05
i noticed my akebono pads are too small, even spacers cant save em, exchanged them for a different part number hoping they gonna fit this time.
post Feb 10, 2006 - 12:30 AM
SiN_CeLi
Joined Apr 6, '03
From Las Vegas
QUOTE(Bigmeanbulldog55 @ Feb 8, 2006 - 9:14 PM) [snapback]391034[/snapback]
Well I said I tightened my caliper pin because on my rear driver side brake I have the caliper pin tighened all the way but when I grab the caliper I can move it up and down a little, where as the other calipers on the car don't budge.
This post has been edited by SiN_CeLi: Feb 10, 2006 - 12:31 AM
post Feb 10, 2006 - 9:34 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(SiN_CeLi @ Feb 10, 2006 - 12:30 AM) [snapback]391630[/snapback]
Oh, I missunderstood. I find it best to explain things as thoroughly as possible around here. I don't know much about you new guys, so I assume you know nothing, so I can completely answer your questions. I didn't mean to offend you. Good luck with fixing it.
Live Free, Be Happy
Lo-Fi Version Time is now: November 27th, 2024 - 7:52 PM
