Exhaust Manifold on ebay |
Jan 16, 2006 - 8:36 PM |
Enthusiast Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
has any body bought a 7afe or 4afe Exhaust Manifold from shrk2thgrl on ebay? if so how is it. and dose it all fit?
Jan 16, 2006 - 9:17 PM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
i have a setup like that and really its sort of a hassle to get it all to fit, especially with the oil filter (you need to relocate it). it makes for a pretty clean install but its more difficult to install and to work on than a manifold that mounts the turbo higher up.
Jan 17, 2006 - 12:44 AM |
so the one you have you bought it from that guy? so that manifold has two extra holes? hows the clearance between the turbo and radiator?
Jan 17, 2006 - 12:56 AM |
Enthusiast Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
Im not sure if theres any alternative, but I do know the logg style isnt the best....
Jan 17, 2006 - 6:44 AM |
QUOTE(southwest2118 @ Jan 16, 2006 - 9:44 PM) [snapback]379717[/snapback] so the one you have you bought it from that guy? so that manifold has two extra holes? hows the clearance between the turbo and radiator? I didn't get mine from that guy, it's just the same style. I think the two other holes are probably the bolt pattern for a 4afe, in anycase you wouldn't use them. For me I have about 2 inches before the radiator, with the right fan taken out (you don't really need it). |
Jan 17, 2006 - 7:42 AM |
QUOTE I didn't get mine from that guy, it's just the same style. I think the two other holes are probably the bolt pattern for a 4afe, in anycase you wouldn't use them. For me I have about 2 inches before the radiator, with the right fan taken out (you don't really need it). i live in texas and it gets pretty hot here. in traffic or with the ac on i can hear the fan coming on to cool the engine. You don't think that will over heat my car? This post has been edited by southwest2118: Jan 17, 2006 - 7:43 AM |
Jan 17, 2006 - 9:12 AM |
if your looking for a manifold solution for the 7afTe then i could also suggest a HONDA B16 turbo manifold
you would need to cut off the flange and weld on the 7afe flange to make it work but it does work..... |
Jan 17, 2006 - 4:39 PM |
QUOTE(southwest2118 @ Jan 17, 2006 - 4:42 AM) [snapback]379772[/snapback] QUOTE I didn't get mine from that guy, it's just the same style. I think the two other holes are probably the bolt pattern for a 4afe, in anycase you wouldn't use them. For me I have about 2 inches before the radiator, with the right fan taken out (you don't really need it). i live in texas and it gets pretty hot here. in traffic or with the ac on i can hear the fan coming on to cool the engine. You don't think that will over heat my car? Well you still have the other fan; your thermostat should regulate engine temp fine. if you are worried about it you could get an aftermarket radiator thats a bit thinner. |
Jan 17, 2006 - 7:19 PM |
I'll see how temps are.
playr158 so i would have to buy a 75$ flange? do you know any where i can get it cheaper? This post has been edited by southwest2118: Jan 17, 2006 - 7:20 PM |
Jan 17, 2006 - 10:27 PM |
nope just jgstools.com/turbo
Jan 18, 2006 - 6:07 PM |
ya they want $75 or was i looking at the wrong thing?
Jan 19, 2006 - 3:22 PM |
Enthusiast Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
yup, ur lookin at the right thing
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Lo-Fi Version | Time is now: November 30th, 2024 - 3:57 PM |
