Missin Gears |
Missin Gears |
Jan 18, 2006 - 11:03 AM |
Enthusiast Joined Jan 18, '06 From St.lucia Currently Offline Reputation: 0 (0%) |
when i launch my car @ 3500rpms when i try to get second it is not there ...., then when i shift i get third , but when then there is fourth neither is reverse !!. wat could lead to this ? and has anyone ever had that problem
Jan 18, 2006 - 12:48 PM |
Enthusiast Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
bad driver? lol just messin with ya
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... |
Jan 18, 2006 - 1:31 PM |
Enthusiast Joined Mar 29, '04 From Manchester, England Currently Offline Reputation: 0 (0%) |
Get some new clutch fluid and gearbox oil in there.
Jan 18, 2006 - 3:37 PM |
i jus checked it out today and the i discovered that the gear cable for 2nd, 4th, and reverse is sretched out ....so i am goin to buy a new one tomorrow see if that really is the problem.
Jan 18, 2006 - 4:01 PM |
I have problems with 1st, 3rd, and 5th. I could have a similar problem. I'm going to get a short shift kit to see if that doesn't at least help a little.
Jan 19, 2006 - 12:01 AM |
Enthusiast Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) |
QUOTE(Bigmeanbulldog55 @ Jan 18, 2006 - 4:01 PM) [snapback]380501[/snapback] I have problems with 1st, 3rd, and 5th. I could have a similar problem. I'm going to get a short shift kit to see if that doesn't at least help a little. Short shift kit will not solve your problem, when you are having problems with such arrangement of gears its most probably your gear cable clip being bent of broken and letting the cable slide a bit. Short shifter will only make it feel like your problem is fixed untill that clip totally falls off, making your way home possible on only second and fourth gear... I've been there -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Jan 19, 2006 - 11:30 PM |
QUOTE(CilverSeliST205 @ Jan 19, 2006 - 12:01 AM) [snapback]380742[/snapback] QUOTE(Bigmeanbulldog55 @ Jan 18, 2006 - 4:01 PM) [snapback]380501[/snapback] I have problems with 1st, 3rd, and 5th. I could have a similar problem. I'm going to get a short shift kit to see if that doesn't at least help a little. Short shift kit will not solve your problem, when you are having problems with such arrangement of gears its most probably your gear cable clip being bent of broken and letting the cable slide a bit. Short shifter will only make it feel like your problem is fixed untill that clip totally falls off, making your way home possible on only second and fourth gear... I've been there So you're saying it will feel fixed with the short shifter? Sounds good, I'm getting one. -------------------- Live Free, Be Happy
Jan 19, 2006 - 11:53 PM |
QUOTE(Bigmeanbulldog55 @ Jan 19, 2006 - 11:30 PM) [snapback]381300[/snapback] QUOTE(CilverSeliST205 @ Jan 19, 2006 - 12:01 AM) [snapback]380742[/snapback] QUOTE(Bigmeanbulldog55 @ Jan 18, 2006 - 4:01 PM) [snapback]380501[/snapback] I have problems with 1st, 3rd, and 5th. I could have a similar problem. I'm going to get a short shift kit to see if that doesn't at least help a little. Short shift kit will not solve your problem, when you are having problems with such arrangement of gears its most probably your gear cable clip being bent of broken and letting the cable slide a bit. Short shifter will only make it feel like your problem is fixed untill that clip totally falls off, making your way home possible on only second and fourth gear... I've been there So you're saying it will feel fixed with the short shifter? Sounds good, I'm getting one. actually i doubt that will make it "feel fixed", but it might feel "less broken" since you are gonna have shorter and stronger throw with brand new brushings that will make it smoother -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Jan 20, 2006 - 1:49 PM |
I know that it's just a temp fix and will only make it feel slightly better. I know your knew to this site, but people who know me know I don't just jump into things and haff way do stuff. I would rather fix whatever the problem is, but I just don't know how to fix it. I figured with the new shifter it would feel good enough that it would bother me so much. And maybe with the new parts, would fix it. It is a 94. I don't know what to bend, or what dirrection. Those little clamps that hold the shifter cabels in place on top of the transmition? If so, what dirrection? It's not like I feel like the car isn't going far enough to go into gear, it just doesn't feel as right going from 2-3 as 3-4. It's a lot smoother. I was worried about synro's actually. 3rd is the worse, and I hear it's a common problem on Celicas. Don't get me wrong, it's not bad, it's just not F1 smooth.
Jan 20, 2006 - 3:03 PM |
the shifter isn't the issue its your cables...don't be cheap do it right the first time
Jan 20, 2006 - 5:28 PM |
QUOTE(playr158 @ Jan 20, 2006 - 3:03 PM) [snapback]381563[/snapback] the shifter isn't the issue its your cables...don't be cheap do it right the first time So, what do I need to do? Get new cables? I don't want to cheap out, I never cheap out when it comes to my baby. I just want really smooth shifts. -------------------- Live Free, Be Happy
Jan 20, 2006 - 10:32 PM |
cables
Jan 21, 2006 - 2:12 PM |
Enthusiast Joined Jun 12, '05 From Box Springs, GA Currently Offline Reputation: 0 (0%) |
where do u go to get new cables? and how do you replace them?
Also, what would be a good mileage interval to do this? Better to prevent problems than having 2 or 3 gears outta commission. ~bob -------------------- |
Lo-Fi Version | Time is now: November 24th, 2024 - 6:51 AM |
