> Boot Release $hit Itself!!!!, help........
post May 21, 2003 - 5:40 AM
nigz
Joined May 18, '03
From Australia
My boot release recently died on me.....someone...anyone help me!!!! it aint working, it just makes a clicking noise!!! plz frown.gif
post May 21, 2003 - 12:26 PM
Rivo
Joined Apr 28, '03
Boot release? What be this?
post May 21, 2003 - 12:29 PM
Mynzeyes
From Franklin/Nashville, TN
trunk/hatch release...check the cables on the back panel of the car, under the black plastic cover...see if they are all intact and fastened right...otherwise, there is a problem somewhere in the cable itself, it may be up by the lever that you pull...check those 2 places and make sure everything is secure. smile.gif
-John-
AIM==Mynzeyes
post May 24, 2003 - 1:38 AM
nigz
Joined May 18, '03
From Australia
thanks bro will try that!
post May 24, 2003 - 3:42 PM
Joined Apr 24, '03
From NYC
check to see if your trunk lock cylinder is in the horizontal position like this (-)
If it is, then it's in the valet position, which disables the trunk release level.
Use the key and turn the lock clockwise back to the vertical position (|) and that'll re-enable the release level.
post May 24, 2003 - 7:54 PM
Guest_Matthew_*
ya that happened to me once...the guy at the valet was like we couldnt get your trunk open. i was like uhhhh why did you need to? then he just walked away. needless to say, his boss fired him on the spot.
post May 24, 2003 - 10:40 PM
zigy
Joined Nov 6, '02
From Chicago, IL
***well first of all, see if you can open your trunk with key,
if you can that means that cables are fine, but if you cannot,
then take the plastic cover off w/ 4 plastic screws, make sure
that the cables are hooked up (they tend to come out at turns
of 50 mph - mine did couple times)
*** If you can open with the key, that means that lock hook is busted,
the locking mechanism and lock-hook are one piece so in order to
replace it you are going to need new locking mechanism with a
special order from Toyota Dealer for your apropriate key....
Hardware $70 +tax
Labor 1 hour (usually $60/hour)
any certified toyota dealer
***expect delay of about 7 days.....
you can save couple $ and install it yourself...any info let me know....
post May 25, 2003 - 5:03 AM
nigz
Joined May 18, '03
From Australia
hey thanks everyone for the help, really appreciate it! the problem was that valet thingy with the key position horizontal!!!! now i can sleep in peace again!
once again thanks fellas!
Lo-Fi Version Time is now: November 24th, 2024 - 7:40 PM
