> storing cars
post Jan 20, 2006 - 6:35 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
er.. ok.. my celica might not be moving for a month or 2... so i'm wondering.. for those people that store their cars for long periods of time... is there anything you need to prep before leaving it standing still for so long? since i heard it oculd be bad if you just let it sit for too long
06 Civic EX
My For Sale Thread
post Jan 20, 2006 - 6:54 PM
When I parked mine I first drove around until I used up almost all of the gas. Other than that though, I didn't do anything else except disconnect the battery. Before I drive it again though, I'm going to change the oil.
post Jan 20, 2006 - 7:01 PM
elvasoshexai
Joined May 16, '05
hm dammit. too bad i have a full tank... i guess i'll just go disconnect the battery
06 Civic EX
My For Sale Thread
post Jan 20, 2006 - 7:05 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I left it at around 1/2 1/4 tank... and disconnected the battery but occasionally go over, hook everything up and start 'er up and just let it idle so things run smoothly
post Jan 20, 2006 - 7:36 PM
elvasoshexai
Joined May 16, '05
QUOTE(dustin15brown @ Jan 20, 2006 - 7:05 PM) [snapback]381635[/snapback]
o. hah i might not be home which is why it would be left sitting..
06 Civic EX
My For Sale Thread
post Jan 20, 2006 - 7:51 PM
celiracer
Joined Oct 5, '05
From NE
u should be fine just unplug the battery and let it site there. You could also put some of that stuff in your gas that makes the gas not get old. And when you get back just start her up and let her sit and idle for a bit then take her out wink.gif
post Jan 20, 2006 - 10:35 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
My car was sitting for nearly 3 months before I drove it again. I took the battery out and charged it on a battery charger. My gas was nearly full and it ran without a problem. Regular oil only really needs changed if it's been in the engine for 6 months, otherwise it should be fine as well. For the gas, I'd think the same thing, though you could throw in a bottle of stabilizer if you feel like it.
post Jan 21, 2006 - 2:10 AM
dont worry about the gas, it dosnt go bad for years
disconnect the battery and thats it.
the real tip is what you should do when you go to start it back up. remove your efi fuse and crank the car for about 20secons untill the oil light on your dash goes off. then put the efi fuse back in and start her up. this will make sure that the motor is not going to get any extra wear from being fired up with no oil presure from sitting for so long.
post Jan 21, 2006 - 3:16 AM
elvasoshexai
Joined May 16, '05
QUOTE(lagos @ Jan 21, 2006 - 2:10 AM) [snapback]381766[/snapback]
oh i'll have to remeber this one
06 Civic EX
My For Sale Thread
post Jan 21, 2006 - 6:56 PM
azian_advanced
Joined Apr 18, '05
From Calgary
you may want to start it every 2 weeks and leave it to idle for 20 mins or so... it's would be a good idea for cold climate cities
Lo-Fi Version Time is now: February 20th, 2025 - 8:32 AM
