4 Pages V  « < 2 3 4
> What next, GT4 or Beams
post Feb 18, 2006 - 1:08 PM
popstar
Joined Nov 24, '04
From Moscow, russia
glad you got something in the end i was stsrting to think you'd fallen for a 'Honda" and were to ashamed to tell 'lol'
so what are you plans for your new baby now ?
any way take care, and have fun mate
Life is for living, and you don't get a second chance
Take care now !!
post Feb 18, 2006 - 3:46 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
QUOTE(magnum @ Feb 18, 2006 - 7:46 AM) [snapback]395827[/snapback]
I went for a gt4 the one i was after the 98 was sold so i went and got a 97 GT4 in white ,i will get up some pics when i get my new wheels and projectors fitted
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Feb 18, 2006 - 5:50 PM
magnum
Joined May 13, '05
From Tipperary Ireland
The main thing is to get used to the BOOST first. It already has an Apexi ECU with FC Commander also sports Exhaust...But one question i have to ask is what is this behind the front grill...
Its like a little jet with a rubber hose attached which goes down the side of the washer bottle reservoir...?
Cheer's
Mike (,")
www.Toyota-irl.com
post Feb 18, 2006 - 6:18 PM
GT4WRC
Joined Mar 17, '05
Water sprayer for the WAI pre-rad. Probably activated by the headlight washer switch on the dashboard.
Gary
GT-Four spec list
post Feb 18, 2006 - 6:25 PM
magnum
Joined May 13, '05
i was going to cut it off is it of any use ,it is only held on with cable ties,
where is it supposed to be mounted
Cheer's
Mike (,")
www.Toyota-irl.com
post Feb 18, 2006 - 6:52 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
i hate u guys...u guys get to have both the 4 and the beams and us US guys dont frown.gif
bboy
post Feb 18, 2006 - 7:02 PM
magnum
Joined May 13, '05
Cheer's
Mike (,")
www.Toyota-irl.com
post Feb 19, 2006 - 1:28 AM
GT4WRC
Joined Mar 17, '05
QUOTE(magnum @ Feb 18, 2006 - 6:25 PM) [snapback]395980[/snapback]
In its current state, it is probably not at all effective. A properly set up system will help reduce inlet temps but that won't do much IMHO.
Gary
GT-Four spec list
post Feb 19, 2006 - 1:35 AM
dlx742
Joined Oct 10, '05
From San Diego
QUOTE(GT4WRC @ Feb 19, 2006 - 1:28 AM) [snapback]396075[/snapback]
Gary
i dont know much about your's but my buddy with a turbo civic got 20ish hp (dyno proven) from his IC sprayer kit...
post Feb 19, 2006 - 4:54 AM
GT4WRC
Joined Mar 17, '05
Re-read my post and you'll notice that I said 'properly set-up' system will help reduce temps. The one magnum has there is not 'properly' set up.
I have a Cusco water spray controller currently on its way from Japland to use in conjunction witha custom set-up I'm going to be using.
And what do you mean by '20ish bhp'? Either it made 20hp or it didn't rolleyes.gif Assume that the test was done back-to-back at the same session with no break in between - ie run without spray and then run with? Otherwise it is meaningless.
Gary
GT-Four spec list
4 Pages V  « < 2 3 4
Lo-Fi Version Time is now: December 2nd, 2024 - 2:24 PM
