> changing fog light bulbs, 94-95 OEM fog lights
post Jan 22, 2006 - 5:43 AM
trdproven
Joined Aug 2, '05
From Guam
Does anyone know how to replace oem fog light bulbs for the 94-95. I hope I don't need to take off the bumper. Also, H3 bulbs have that wire too. I dont think there is enough room for my hands to fit to replace them. Also replacing these bulbs should be easy for even regular people just like the rest of the bulbs on the car are easy to replace. Anybody know an easy way.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 22, 2006 - 1:44 PM
celiracer
Joined Oct 5, '05
From NE
Sorry, but i think you have to take the front bumper off. I had the front bumper off and found that i could only change the bulbs with it off, And on the projector headlights that little side light off the headlight, thats harder then crap to change also. But good luck man. I could be wrong tho. But i can't change mine without taking the bumper off.
post Jan 22, 2006 - 3:51 PM
trdproven
Joined Aug 2, '05
From Guam
What about taking the plastic cover off the bottom end of the front bumper or just sticking your hand between the front bumper and the radiator? There should be an easier way because factory replacement of just bulbs should be easy for even girls. Its a B**** taking off the bumper. I'm sure people who have installed the same fogs know.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 22, 2006 - 4:05 PM
celiracer
Joined Oct 5, '05
From NE
Well you might be able to take the bolts off under the car and move the plastic undercarrage and might be able to get to them.
post Jan 23, 2006 - 10:46 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Ummm well if you talking about the same OEM fogs I have, then I am pretty sure u dont have to take of the front bumper. My fogs are just held by 1 screw. Just un screw that screw and un-wedge it out of there. There should be a OEM clip in the back, then just un-clip it... the fog should be totaly off now.
post Jan 23, 2006 - 4:16 PM
trdproven
Joined Aug 2, '05
From Guam
Hmm, do you think its the same as the early model fogs? I know the 94 fogs have this wide metal bracket that surrounds almost the whole back of the fog. Lemme go take a look. Thanks for the help. Anyone else with ideas or who have done it before, Id appreciate any suggestions.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 23, 2006 - 5:01 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(trdproven @ Jan 23, 2006 - 4:16 PM) [snapback]382821[/snapback]
I'll send you some pics of my brackets. Mine are technically JDM... but I would think they would be the same. Ummm curious.
post Jan 24, 2006 - 12:48 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
It seems like your brackets are different. But here are some pics of mine.
Here you can see the screws in the inner sides of the fogs/brackets. I just unscrew these an whammy!
Here is a rear pic. The screws again are in the inner sides of the fogs.
The other (outter sides) are just kinda wedged/held in place by a notch in the brackets. This probably won't help, simply because if it was just a matter of one screw you would have done it by now. Anyways good luck.
Maybe mine are from a different year or something.
This post has been edited by UTSlickVic: Jan 24, 2006 - 12:49 AM
post Jan 24, 2006 - 4:22 PM
trdproven
Joined Aug 2, '05
From Guam
My fogs are exactly like yours. Not sure which screw off though.
wait a minute, on that first pic, is it the screw on the top corners...just 1 screw? take a look at my profile, same fogs as yours.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 24, 2006 - 9:28 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Hope this helps..again maybe your bracket is somehow different than mine. Your lights look like mine.
post Jan 25, 2006 - 5:27 PM
trdproven
Joined Aug 2, '05
From Guam
haha, I thought it was the screw at the top corners around the gray piece. I actually found them when I got home yesterday. In the earlier pic you put, those black screws aren't visible. Thanks again for your help.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 25, 2006 - 9:44 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(trdproven @ Jan 25, 2006 - 5:27 PM) [snapback]384235[/snapback]
Lo-Fi Version Time is now: February 25th, 2025 - 5:12 PM
