> Typical Starter Current Draw?
post Jan 22, 2006 - 12:13 PM
Yesterday I changed my oil, added some good gas into the tank, and attempted to crank the car for a while to get some oil circulated through the block before a cold(like 4 months cold) start up. The thing is, I kept popping my main fuse, because my battery is in the trunk, I used 4-gauge wire for the battery relocation, and I use AGU 80-amp fuses. How much current does a Toyota starter typically draw, in terms of amps? I'm wondering if I should do the upgrade to 1/0 gauge wiring from the battery.
I wouldn't mind doing it, except I have no idea where I'd run a wire that big, and it'd be expensive.
post Jan 22, 2006 - 5:15 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I believe it's something like 90 amps...
post Jan 22, 2006 - 7:28 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
My uncle was telling me that wire used for welding cables would be easy to use and it would be cheap. I was thinking about putting my batter in the trunk. I'd think you'd want to get it as big as you could.
Live Free, Be Happy
post Jan 24, 2006 - 6:27 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
i'm using 0g wire and 130amp fuse, never had a problem
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jan 25, 2006 - 8:17 AM
ive heard that as well, also jumper cables...
i think it was 2GA that i used for my relocation..
Lo-Fi Version Time is now: February 23rd, 2025 - 4:23 PM
