3 Pages V   1 2 3 >
> after swap, not turning over ?!!?!?!, advise
post Jan 23, 2006 - 12:21 AM
here is the situation...a 94 5s went into a 96. The 96 harness was used and everything matched up except a few things (they were then swapped over from the 96 motor to the 94, i.e. distributer, OBDII, ect. ). Now after everything is all hooked up and put together, it doesn't start up. It cranks, the starter is good, but no vroom.
anything that I should check for specifically ?
any ideas ?
wtf ?
thanks
post Jan 23, 2006 - 12:22 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Are you getting spark? Is the fuel pump running? Do you have fuel pressure?
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 23, 2006 - 12:36 AM
the problem is I am not at the engine to find out, just hearing about from a friend but i am gonna call him in the morn.
story...I sold my 94 (non cali) 5s (ran great) to a local guy who blew a hole in his block laugh.gif we (Manny and I) helped him pull his old 5s and he needed to use his 96 (cali) harness on the 94. He said he swapped everything he needed with his harness but had one problem with a sensor on the side of the TB. He said he rigged it and things should be fine.
I know this is limited info here but what would cause it to not turn over ?
post Jan 23, 2006 - 12:40 AM
Dr_Tweak
Joined Mar 31, '04
Well, first off, "turn over" = cranking, so don't use that term for not starting. The problem is it turns over, but doesn't start, right?
Which distributor is he using? There's a ton of things that could cause a no start, probably it's something very simple.
post Jan 23, 2006 - 12:43 AM
you are correct, turning over, yes, starting, no.
I think it has to be simple too. I told him to swap his 96 distributor, he should be using it.
post Jan 23, 2006 - 1:07 AM
Dr_Tweak
Joined Mar 31, '04
Yeap, that's probably his problem right there.
post Jan 23, 2006 - 9:16 AM
he prolly forgot somthing dustin, did he tell you about what he did with the crank sensor thingy?
post Jan 23, 2006 - 11:13 AM
he swaped the cover and his dad did the timing belt
post Jan 23, 2006 - 9:43 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
There are supposidly some differences between cali and fed distributors. Also make sure he uses the exhaust off the cali car. How does the coil look? I know that also has cali/fed issues.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Jan 24, 2006 - 12:17 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
ok guys, ill step forward, its my car.
alright...
I used the exaust from the other engine...
I changed over the distributor
I changed over the wire harness
I swapped over a crank sensor
I swapped the egr
Now, I am getting spark, the fuel pump is working, the fuses are fine, and there is fuel getting to the fuel filter. I tryed using some starter fluid, i got it to studder a little but didnt run. I am now going to take a look at the hoses and the fuel rail to see if there is maybe a blockage. This is the last thing i can think of. is there a way to see if the injectors are firing?
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Jan 24, 2006 - 1:19 PM
QUOTE(nightryder @ Jan 24, 2006 - 12:17 PM) [snapback]383429[/snapback]
alright...
I swapped the egr
if you got it to fire up with the starter fluid, then your problem must be fuel related, since you verified that the car and fire on its own.
post Jan 24, 2006 - 1:55 PM
nightryder
Joined Sep 29, '05
OK i have an update and an apology for my last post. I AM NOT GETTING SPARK. Thought i was, guess not, i checked again today. Distributor maybe?
post Jan 24, 2006 - 3:38 PM
Sr_Ric
Joined Dec 25, '05
From Sheffield, UK
i know on some cars if your using diffrent wiring you have to change keys/modules for the imobiliser?
post Jan 24, 2006 - 4:12 PM
QUOTE(nightryder @ Jan 24, 2006 - 1:55 PM) [snapback]383480[/snapback]
make sure you are using your coil, ignitor, distributor, harness and ecu from your old motor. you also have to make sure the iginitor and coil and grounded to the car, and that you didnt forget to hook up your tranny and chasis grounds from your battery .... its always something dumb like that that causes problems.
post Jan 24, 2006 - 6:23 PM
nightryder
Joined Sep 29, '05
Ive been doing some trouble shooting and i think it could be my ignitor coil. I have power going in the coil, and none coming out the ignitor. I figure this might be it, either that or a crossed wire somewhere. and yes i am using the harness ecu, distributor, ignitor and coil from the old engine.
This post has been edited by nightryder: Jan 24, 2006 - 6:24 PM
post Jan 24, 2006 - 7:33 PM
Agent21
Joined Sep 12, '05
Take a multimeter on the positive pole and the little loop on the side of the coil on near the bottom. If it is between 10K and 14K you are fine. anything else it is SHOT! My money is on it.
94 GT Liftback
post Jan 25, 2006 - 9:22 AM
nightryder
Joined Sep 29, '05
QUOTE(Agent21 @ Jan 24, 2006 - 7:33 PM) [snapback]383631[/snapback]
I got a hold of a multimeter, checked the power going into the coil-(12.45) then i checked it going from the coil to the ignitor-(0) then i checked the distributor cord from the coil and i got no power either, i think you are right on the money Agent. Im haveing a buddy who works at a local dealership as a diagnostic manager to come over and have a looksee, we will know later on today.
post Jan 25, 2006 - 3:26 PM
Agent21
Joined Sep 12, '05
I only know this because mine blew out of no where. Pulled the alternator and waited a week for the new one, put in the alternator and no spark at all.
94 GT Liftback
post Jan 27, 2006 - 2:42 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i now too have the same prob as doggy. i swapped from a 96 5sfe motor to a 98 5sfe motor cuz i blew the old one. and i have fuel but no spark. when i put my ear up to the coil it makes a whine sound very faint though even when the car is on the off position. i'm thinking this is draining my battery. i'm gonna check into it more tonight but i think my coil is shot. did you ever get yours to work doggy?
post Jan 27, 2006 - 7:43 PM
Agent21
Joined Sep 12, '05
Could be the ignition control module as well. It is on the firewall right above the master cylinder.
94 GT Liftback
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 23rd, 2024 - 10:29 AM
