> 3SGTE Performance Street Engine Rebuild Kit
post Jan 30, 2006 - 3:33 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
Found something that some of you might be interested in that has the 3sgte.
Not sure if they still have the parts in stock or not, but i think its a fairly good price for an entire kit.
3SGTE Performance Street Engine Rebuild KitJE Forged pistons.. .020 over 8.5:1, Total-Seal Gapless Rings, Clevite77 Rod and Main Bearings and Thrust Washers, Full Engine Gasket Set with Steel Shim Head Gasket, ARP Head Studs, ARP Rod Bolts, (16 ) Stainless Steel Valves, Timing Belt, Tensioner bearing, Idler bearing, Water pump, ARP Flywheel bolts.
$1750.00
http://www.racetep.com/xmasspecials.html#toy
some may of already known about this
post Jan 30, 2006 - 3:36 PM
QUOTE(celicarus @ Jan 30, 2006 - 3:33 PM) [snapback]386478[/snapback]
$1750.00
thsi company is very well known to suck BIG time over on mr2oc.
i wouldnt let them wash my underwear, nevermind build an engine.
post Jan 30, 2006 - 3:39 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i was looking at this for a while. thanks manny for letting me know,
http://www.racetep.com/mr2tpart.htm
post Jan 30, 2006 - 3:42 PM
im a little confused at what they offer. it seems like its a "kit" full of parts, but you do your own rebuild?
i would only go with something from chrisk, ats, chicoraceworks if i decide to build up my block
celicarus
Joined Jul 5, '05
From Arlington, TX
wow good to know - but how bad can they screw up with parts
i was doing some surfing - looking for an all in one kit that way i don't have to search for parts here and there - but if they have the parts available brand new then why not consider it because after all its a do it yourself kit
i'll jump over to mr2oc to take a look at the comments
post Jan 30, 2006 - 3:44 PM
QUOTE(celicarus @ Jan 30, 2006 - 3:42 PM) [snapback]386487[/snapback]
if you know enough to assembly a whole motor from the ground up, then youll probably want to pick your own parts based on your own research
post Jan 30, 2006 - 3:54 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
QUOTE(lagos @ Jan 30, 2006 - 2:44 PM) [snapback]386488[/snapback]
i would prefer that - but so far the sites that i have seen says that the parts may take 6-8 wks for special order - if i can find some where that may have it available within 1-2 wks than that would be better - reason being is that i want to cut down as much down time as possible - though i will continue to search and contact places
"chrisk, ats, chicoraceworks if i decide to build up my block" -- thanks for the info
post Jan 30, 2006 - 4:14 PM
you can get a lot of stuff from ebay or ats with minumal wait. why do you need everything so soon?
post Jan 30, 2006 - 4:22 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
that's easy to answer - the longer i have to wait for parts to arrive - the longer the downtime - because this is my only car - i would have to walk, catch rides, or waste money on a 2nd car when i could use that money into the swap - though i'm not in any hurry right now - i'm just checking to see what i can get my hands on to purchase cause i'm afraid that other things may come up unexpectedly and i won't have the money then
This post has been edited by celicarus: Jan 30, 2006 - 4:22 PM
Lo-Fi Version Time is now: February 22nd, 2025 - 4:51 PM
