![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) ![]() |
K i am having a bit trouble getting the side skirt to fit. I don't know what i'm doing wrong. Can someone please help me?
Here are some pics. ![]() ![]() ![]() ![]() ![]() ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
crap fitment as usual... try a heat gun.. and if that doesn't work u might have to cut and fill in areas. goodluck
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) ![]() |
the front of that looks broken, hope you get it fixed
haha cause your not putting it on right....
remove your kick panel (the plastic piece on the bottom of the door sill) and that lip of the sideskirt sits on that just push it in and you'll be fine |
Hey Dan i tried to do that. (aaron was telling me to try it) When i try to do that it wont even come close to go where the door sill plastic would be at. And that peice isn't broken. Thats how the skirt looks when its not on right.
![]() Enthusiast ![]() ![]() ![]() Joined Aug 20, '03 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
I dunno Matt, it looks like it's not even pushed up enough in the doors to me. Maybe take your door sill off and see how that works. If you're still having troubles, I think a heat gun should take care of the problem as dustin said. Good luck bro, can't wait to see the finished project.
your just trying to hard...step back don't think too much
and just sit it straight on down you might have to sand the inside a little though This post has been edited by playr158: Jan 30, 2006 - 10:43 PM |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) ![]() |
ya remove the door sill and then try to fit it up again, I thats where I put my holes and screws, seems 2 be fine for me. not a perfect fitment but nothing a little bondo cant fix.
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
![]() Enthusiast ![]() ![]() Joined Aug 21, '03 From UK Liverpool Currently Offline Reputation: 0 (0%) ![]() |
Ive got the same skirts and had the same problem.
First take your stills off, Trim the skirts at the front with a hacksaw, use a black marker to help mark where u need cutting. What i did was drill through the bit of the skirt tht goes in the door wings right through and temparaly put in a bolt, check your door can close. On my skirts i had to use all my streight and force it againest the door still then drill. This worked and the door could close. Then where the holes r add 2 layers of fiberglass. Pain and funny to use. Take off kit and sand, smooth or retrim down. Then paint and put on, someone on here told me to use reverts to hold in place. And drill at least 3 holes to make sure it doesnt come out. Also use double sided tape on the rear end of the skirt so there is no gap. -------------------- |
Lo-Fi Version | Time is now: February 22nd, 2025 - 11:49 PM |
