2 Pages V  < 1 2
> trunk space
post Feb 1, 2006 - 11:20 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(snapshotgt @ Jan 31, 2006 - 10:34 PM) [snapback]387343[/snapback]
sometimes, you might not have a "true" spare...it could be a normal wheel back there?...i have a normal wheel in the rear...but i have built a platform to counter the bump tongue.gif looks good too...i built it so it is level with the back seats too biggrin.gif
~snapshotgt
^^^If you have a full spare, i would recommend building a platform...like i did^^^ biggrin.gif
~snap
post Feb 2, 2006 - 1:58 AM
blu94gt
Joined Mar 23, '05
From Kansas City
wow I've never seen a 6th gen with a full size spare like that. I figure for as seldom as a mini spare is used and even if it's used it's not for very long I think it's do-able. I would much rather have more trunk space than a stupid hump in the trunk.
1999 Celica GT
post Feb 2, 2006 - 4:48 PM
kash1355
Joined Dec 21, '05
From Ontario
QUOTE(creis @ Feb 1, 2006 - 12:12 AM) [snapback]387397[/snapback]
mine is flat, but my spare is pretty thin, never heard of that spare tire hump in the truck, makes sence with the gt-4 but cant see why a fwd would need it? kash1355 could you post a pic of it with the carpet out and the spare off to the side.
Finally took pictures of my 95 gt trunk ... here it is .. now does anyone have any suggestions .. take out spare and put a donut ?
trunk with hump
size of my spare
post Feb 2, 2006 - 4:56 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Feb 2, 2006 - 5:03 PM
snapshotgt
Joined Oct 12, '05
From Texas
Kash...i'd keep the full spare, and do what i did (build a platform)...you can see pics of my trunk above^^...
just my 2 cents...
~snap
post Feb 2, 2006 - 5:09 PM
kash1355
Joined Dec 21, '05
From Ontario
QUOTE(snapshotgt @ Feb 2, 2006 - 5:03 PM) [snapback]388166[/snapback]
just my 2 cents...
~snap
I think ill have to do that ... so u jus traced the mat on some plywood .. lay that on the tire and cover it wit new carpet?
What kind of carpet did u use .. and where did u get it ..
post Feb 2, 2006 - 5:25 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(kash1355 @ Feb 2, 2006 - 5:09 PM) [snapback]388168[/snapback]
just my 2 cents...
~snap
You want to make it pro right? tongue.gif ...well, go to homedepot, get some thin durable wood (masonite is what I used), staples, carpet padding, and a 4x4 piece of wood. Then trace your carpet onto the wood, cut it, then staple the carpet padding to the bottom of your platform (to provide sound deadening). Then cut the 4x4 blocks of wood to the height you want the platform to stand up (i made them high enough to make my platform level with the rear seats)...(the blocks will brace the platform--you cannot just use the wheel to brace it)...and this is going stupid, but I secured the 4x4 blocks to the trunk bottom using caulk...mainly b/c it is not as harsh as glue or liquid nails, and it has held perfectly. then put it all together and waaaala! biggrin.gif
~snap
post Feb 2, 2006 - 10:48 PM
creis
Joined Jan 10, '04
From Shoreline, WA
well dang i want a full size spare, cant even use the little one because my car is so low, it would be very bad trying to drive with that thing, and I since I'm making a new fiberglass sub box anyway the hump is no problem just make it go around.
post Feb 2, 2006 - 11:24 PM
kash1355
Joined Dec 21, '05
From Ontario
post pics of the fiberglass enclosure when ur done makin it
post Feb 2, 2006 - 11:42 PM
creis
Joined Jan 10, '04
From Shoreline, WA
^ shure will, it will be my 2nd f/g enclose looking at it my first one might have cleard that indent but would have been close.
old pic of my first if people never saw it.
post Feb 5, 2006 - 2:03 PM
eliaz
Joined Dec 28, '05
From Norway
I custom made a subenclosure for my 12". And I still got plenty of room smile.gif
This post has been edited by eliaz: Feb 5, 2006 - 2:05 PM
post Feb 5, 2006 - 3:30 PM
kash1355
Joined Dec 21, '05
From Ontario
ok .. i was thinking of doing 1 12" sub, but my main concern is the type of bass. I was told that 2 10" subs would be much more crisp and tight sounding as opposed to 1 12" sub. Could you tell me if this is true or not, or possibly explain the difference in bass quality.
post Feb 5, 2006 - 4:03 PM
mikew04
Joined Feb 19, '04
From austin tx
QUOTE(kash1355 @ Feb 5, 2006 - 3:30 PM) [snapback]389225[/snapback]
Not true. Depends on the subwoofer, and more importantly the enclosure.
post Feb 5, 2006 - 4:13 PM
eliaz
Joined Dec 28, '05
From Norway
I custom made the enclosure from a program, bassbox 6 I think. I made a closed box with a resonace frequency of about 50hz I think. The bass is awsome! But it is a Rockford fosgate, very good brand. The salesman I spoke to said that what they sold most was 12". About 95% of what they sold of subs were 12". Well, my bass sounds great and I really care about good sound smile.gif
post Feb 6, 2006 - 2:28 PM
jspec3SGE
Joined Jan 25, '06
From Stafford, VA
Here are 2 pics from my 1994 ST coupe.
It was flat even with the spare tire in its factory spot.
-Ryan
post Feb 6, 2006 - 2:33 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
i asked the same question last summer when i was looking to buy a 6gc... i don't think it matters if it's a gt/st/gt-s...
i looked @ a gt-s and it had a full spare (bump) i now have a gt (usa) and it doesn't have a full spare... must've been an option/package thing back in the day? *shrugz*
06 Civic EX
My For Sale Thread
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 23rd, 2025 - 4:11 PM
