> Coolant temp switch, sensor, Im confused
post Feb 1, 2006 - 9:54 PM
tceligt
Joined Sep 7, '05
From Ensenada, Baja California, Mexico
wink.gif Ok heres the problem i bought my celi and notice that the fans (2) are always on relays are ok, and i was thinking to replace the coolant temp switch, but surprise the the radiator dont have kindasad.gif , then i need one. My problem its because im confused with the coolant temperature sensor located in front of the dizzy, are the same part, someone have a picture of the temp switch conector, i just to solve the problem and dont bought something i dont really need.
I look at kragen site and the temp sensor and the switch looks to be the same.
Thanks in advance
post Feb 1, 2006 - 10:16 PM
do you have an ST or a GT?
the temp sensor should be on the bottom passengers side of your radiator. the "coolant temp sensor" next to the distributor is something different and will not change how your fans work.
post Feb 1, 2006 - 10:38 PM
tceligt
Joined Sep 7, '05
It's a GT Coupe
The first owner of this car change the radiator and i think this is not the one for the celi.
post Feb 1, 2006 - 10:39 PM
QUOTE(tceligt @ Feb 1, 2006 - 10:38 PM) [snapback]387843[/snapback]
It's a GT Coupe
yeah, that would explain your fan problem
post Feb 1, 2006 - 10:41 PM
tceligt
Joined Sep 7, '05
Well i guess i need to foun were to install this temp switch
Lo-Fi Version Time is now: December 1st, 2024 - 5:48 AM
