> 2nd Alternator swap out A/C unit, Amp power
post Feb 2, 2006 - 7:45 AM
nightrider
Joined Apr 26, '04
From London
Hi, has anyone taken out the A/C unit and replaced it with an alternator? If so how difficult was this job and how much did it cost?
More Power to your BOOM BASS
post Feb 6, 2006 - 10:50 PM
lake1069
Joined Oct 3, '04
From NC
wait, what? u want two alternators? i dont believe u will benefit at all from this.
post Feb 7, 2006 - 8:28 AM
Cutrara
Joined May 6, '05
From PA
It would be beneficial if you had lots of electronics.
post Feb 7, 2006 - 7:16 PM
lake1069
Joined Oct 3, '04
From NC
never heard of such a thing done b4. but for the trouble ur going to go through i dont think its worth it.
post Feb 9, 2006 - 8:47 AM
nightrider
Joined Apr 26, '04
From London
I am running two alpine amps 1 at 1000 watts @ 2ohms and 1 at 4 X 100 watts at 4ohms. Alpine amps like most digital amps need to a 14Volt supply to run at full output. I have 2 caps and a heavy battery but with my neon’s and AV setup my voltage drops to 9V!! the cost of the extra alternator is about the same if not less than an up rated high output alt to replace the one I have.
I have seen a number of cars which have had a 2nd alt fitted to a completely separate power circuit just for the amps. The sound is just so much better, don’t get me wrong my sounds are good but I cannot sustain high volumes without the amps clipping after 10 minutes. With heaters and lights all the power gets used up and the sound clarity goes.
I am surprised that you guys have not heard of this as it is very common here?
post Feb 10, 2006 - 11:21 PM
Cutrara
Joined May 6, '05
From PA
I've heard of it and I know the benefits. I think an uprated alternator would be easier because then you wouldnt have to redo your wiring. Contact dustin15brown about them. I think they're 140Amp.
post Feb 10, 2006 - 11:35 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
What gauge wire are you running for your power?
Doesnt sound as though you need a second alternator. Heavy battery? Maybe change it to an optima or something.
post Feb 11, 2006 - 3:21 AM
dans_st
Joined May 24, '03
From Andrews TX
soven Posted Yesterday, 10:35 PM
Personally I HATE optima batteries, with the system I used to have I would go through them in 9-11 months.
I then switched to stinger batteries(one now) and it made a BIG difference, Also when I had the Optima batteries I had to replace the alternator as often as the batteries.
If you need that much more power I recommend a stinger battery especially if your amps are unregulated(more voltage=more watts) because with the stinger battery with my car off it still had a 15.?? float charge still.
I was running (2)RF T8002BD amps(power hungry) to (2)15's wired for 2-Ohm bridged on each amp with 1/0g wire (1)Stinger DB1000 Battery and (1) batcap 400 with a OEM replacement alternator at the time, and with everything on (screen,ps2,neons in hacth,A/c,ect..) my lights wouldn't even dim-And that is was hitting a USAC db'ed 152.4
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Feb 13, 2006 - 7:08 AM
nightrider
Joined Apr 26, '04
From London
I do need the extra power. I never use the AC so it is worth me taking it off for a 2nd alternator, I use all the right wire and fuse specs all the way through the car. I am told that its all down to OHMS law. more current equals more volts and more watts. I have changed the alternator but the volts do run down over time.
post Feb 13, 2006 - 8:45 AM
Cutrara
Joined May 6, '05
From PA
I'm telling you, it will be a pain to swap in another alternator. You'll most likely need a custom bracket. Contact dustin15brown about an upgraded alternator. I think they're 160AMPs. Thats like having 2 alternators.
post Feb 13, 2006 - 9:43 AM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
it will infact take a customn bracket. i have had it looked into. I was gonna run 2 of the 140amp alternators. i was tring to run 2 XS100 on 4 CVR 15s with each amp at 1/2 ohm. i ran out of money and the set up went into a astro van.
-Aaron-
post Feb 13, 2006 - 9:48 AM
i think i hi-amp alternator is a MUCH better, and in the end, cheaper option.
Lo-Fi Version Time is now: February 26th, 2025 - 11:40 AM
