> 3SGTE Third ECU Plug, 22pin Connector
post Feb 3, 2006 - 5:20 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Just thought I'd let everyone know that the 22pin ECU connector from the either the ST or GT with automatic transmissions will work for your 3SGTE's third ECU plug. The connector will have to be repinned and some of the wire colors will not match, but it does plug directly into the 3SGTE ECU. I hope this information will help anyone in the future that is looking for this particular part to their swap.
Also, I'd assume any automatic 5SFE or 7AFE powered car from about 94-99 will probably have the same plug. Camry's, Corrolas and MR2s come to mind but I'm sure there are more.
post Feb 3, 2006 - 8:30 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Any 22-pin Toyota plug will work, FYI.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Feb 3, 2006 - 11:26 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(Dr_Tweak @ Feb 3, 2006 - 7:30 PM) [snapback]388689[/snapback]
-Doc
Thanks, I figured they would but didn't want to go making too many assumptions.
post Feb 4, 2006 - 4:13 PM
good to know, because this was alway an issue for those guys who didnt buy a clip
post Feb 4, 2006 - 11:41 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE(lagos @ Feb 4, 2006 - 9:13 PM) [snapback]388931[/snapback]
LOL
post May 11, 2006 - 12:30 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
man, lagos is always yelling at me for not buying a clip, and now I am running into this problem.
post May 11, 2006 - 2:52 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
My 3rd ecu plugged directly into the 185 ECU. Only one wire had to be repinned.
post May 11, 2006 - 3:17 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(lagos @ Feb 4, 2006 - 4:13 PM) [snapback]388931[/snapback]
any one know the part number for that? or the best place to get one...
you know.. for those guys who got the 3sgte and not the clip
cough cough....
post May 11, 2006 - 3:19 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
You've already got one since you're auto. Otherwise a salvage would be a good place to start.
This post has been edited by WannabeGT4: May 11, 2006 - 3:20 PM
post May 11, 2006 - 3:45 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(WannabeGT4 @ May 11, 2006 - 3:19 PM) [snapback]432935[/snapback]
im going to swap into my other celi, which is a 94 gt manual
post Dec 19, 2006 - 9:02 AM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
i have a question is there a how to: on the repinning the 5sfe plus with the 3sgte plug?
post Dec 19, 2006 - 4:10 PM
QUOTE(2slow2nervous @ Dec 19, 2006 - 9:02 AM) [snapback]511622[/snapback]
no. your best bet is to mail your harness to drtweak and have him do it for you.
post Dec 19, 2006 - 4:15 PM
actually thats just the cheap way out...
the best way (ie learn more about it yourself and how to do it)
go to toyota and buy the electrical books for both YOUR car and the motor and do it on your own smile.gif
yes it will be hard and tedious but what you learn is priceless
post Dec 19, 2006 - 4:53 PM
QUOTE(playr158 @ Dec 19, 2006 - 4:15 PM) [snapback]511711[/snapback]
yeah, thats true, but if you never did harness work before, then it will be a HUGE headache to try to do. its not a small wiring job, and you need to know what you are doing.
post Dec 19, 2006 - 5:04 PM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
alrite thank u guys....now if i sent the harness to dr tweak is it easy to install myself when i ge the harness back?
post Dec 19, 2006 - 5:06 PM
QUOTE(2slow2nervous @ Dec 19, 2006 - 5:04 PM) [snapback]511723[/snapback]
if you can swap your car, you can remove and reinstall your harness.
post Dec 19, 2006 - 5:14 PM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
now see the shop i had my car chopped my 5sfe harness to **** and really didnt kno wut they were doing. So now i have my car in my backyard not done..And i was going to get another 5sfe harness and use my 3sgte harness and send it out... but wen i get it back i would need to install myself
or if i could have some1 tell me or detailed pictures on how to wire the plugs i can have them do it..
installing a harness is pretty easy, but defenitly get a complete uncut 5sfe harness instead of trying to salvage yours
but most of the wiring harness pretty much lays itself out to where it goes and normally the plugs are pretty unique to where they go
post Dec 19, 2006 - 5:16 PM
good solution. Installing the harness on the engine is no big deal at all. Now buy my spare UNCUT PERPECT CONDITION 5s harness smile.gif and send it out with the 3s harness to get this car going again.
post Dec 19, 2006 - 5:22 PM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
i am working on that i need this car on the road!!!! as much help as i can wuld greatly be appreciated. And every1 hear is helping me out greatly! pmed u about the harness.... Now the ecu location will be were?
Lo-Fi Version Time is now: November 23rd, 2024 - 4:10 AM
