> MTX crossover machine?
post Feb 4, 2006 - 9:47 PM
lake1069
Joined Oct 3, '04
From NC
i got this for 20 bucks today, not sure whats its for and how to use it. can anyone tell me about this and how to hook it up. ita a MTX electronic crossover rt-x01a.
post Feb 4, 2006 - 11:13 PM
JFrost9
Joined Aug 27, '05
From Texas
arent external crossovers used for filtering out like lows and highs? i think its so that you only get the "best quality" sound for you subs... so you wire it like to your amp, and then to your sub or something... and its got some controls and what not. I could be totally wrong though.
post Feb 5, 2006 - 12:27 AM
lake1069
Joined Oct 3, '04
From NC
ok now i see what its for. does anyone know how to wire this thing or have a similar one?
post Feb 7, 2006 - 7:49 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
A crossover separates groups of frequencies and sends each group to the proper speaker that reproduces that frequency range the best, i.e. low frequencies to the sub(s), mid bass to the woofers and highs to the tweeters.
Obviously, you have to have these speakers in your setup to use this. Using a crossover will yield the best sound quality because you are sending ONLY the frequencies that that speaker is designed to handle. In other words, your sub isn't trying to reproduce 15000hz when it can't and your tweeter isn't trying to play 60hz sounds which it can't.
A crossover can be connected before or after the amp but separating the signals first and then amplifying them will yield the best results.
Lo-Fi Version Time is now: February 22nd, 2025 - 9:16 PM
