> GT4 Calliper refurb, Time consuming horrible job....never again
post Feb 5, 2006 - 1:08 PM
Insanity-74
Joined Jan 9, '05
From Under the car
Not a job I ever want to do again...I`ve still got the back ones to do..Doh! Oh well...took me 9 hours to refurb the old brake callipers to their current standard, Took the old callipers off the car, lots of paint stripper to get the old paint off from my last attempt to make them look better, about 2 - 3 Hours of wire brushing to get the finish smooth and paint free...also there was a lot of disimilar metal corrosion around the back of the calliper which needed sorting out. Some heat resistant paint and a file later the results look pretty good, I also replaced all the seals and rubbers, and replaced the DOT4 brake fluid with DOT5.1...difference is amazing although had a siezed piston which wouldnt have helped.
The callipers went from this rather sorry looking thing.......
To this
Will do the back ones in about 40 years when I can be bothered again.
post Feb 5, 2006 - 1:23 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
wow... hah that seems like a lot of work... at least they look like 100x better now lol
i think i'm gonna need to do the same thing in the summer too... but mine are all rusted... ><
06 Civic EX
My For Sale Thread
post Feb 5, 2006 - 1:49 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
It's true they look amazing now... good work
post Feb 5, 2006 - 2:33 PM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
wow, good job!
post Feb 5, 2006 - 3:40 PM
Insanity-74
Joined Jan 9, '05
From Under the car
It wasnt such a bad job really...just hurt my arms after wire brushing for 3 hours....good job I had a few Buds to kill the pain smile.gif
Take care if its a job your gonna do yourself...take your time and get it right...you dont want to make a mistake on your brakes. smile.gif smile.gif smile.gif
post Feb 5, 2006 - 10:27 PM
lilsteeg
Joined Jan 16, '06
From Lima, ohio
off topic but arnt you on the automotive forums as well, if so didnt your engine break and what was wrong
post Feb 6, 2006 - 1:30 AM
Insanity-74
Joined Jan 9, '05
From Under the car
Yes I am on the automotive forums aswell, "nialusa". My engine did suffer a slight problem...didnt really break though..a water pump retaining bolt came loose and fell into the cam belt, chewing it up and generally making a mess...its all fixed now and running fine...smile.gif
post Feb 6, 2006 - 5:57 AM
4candles
Joined Jan 30, '06
From good old blighty
QUOTE(Insanity-74 @ Feb 6, 2006 - 1:30 AM) [snapback]389511[/snapback]
i go to brakes international... l
let them do the reburb, doesn't take too long to bolt on the new one.. dont miss too much rugby on the telly then, nice result for the men in white.. smile.gif thought Wales would put up a better fight than they did !
post Feb 6, 2006 - 6:18 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
i havent heard of Dot 5.1 or maybe they
aint available in Australia yet.
Can I use that in my car?
6GC 4 Life Baby!!!
post Feb 6, 2006 - 7:44 AM
Insanity-74
Joined Jan 9, '05
From Under the car
QUOTE(CelicaZR @ Feb 6, 2006 - 11:18 AM) [snapback]389554[/snapback]
Yes you can....DOT5.1 is cross compatable with DOT4 and DOT3 brake fluid as they all have the same base (mineral)....DOT5 is not compatable as its a sythetic base (DONT USE IT) it will react with the mineral brake fluid and eat its way through the brake lines.
post Feb 22, 2006 - 2:42 AM
Nampetch
Joined Apr 30, '04
From Thailand
QUOTE(Insanity-74 @ Feb 6, 2006 - 1:08 AM) [snapback]389187[/snapback]
To this
Nice work. I will get my GT4 brake this weekend and plan to refurbish them too. I wonder and appreciate if you can share, how do you sand the entire caliper so nice? Did you split caliper apart then sand it and painting? I am just thinking of get my caliper to the workshop where they have sand-spray service... wink.gif
post Feb 22, 2006 - 10:56 AM
rcww
Joined Feb 22, '06
From uk
QUOTE(Insanity-74 @ Feb 6, 2006 - 7:44 AM) [snapback]389560[/snapback]
You can now get super dot 4.1 which is better than dot5.1. Anyone used it?
post Feb 23, 2006 - 10:49 PM
dustin15brown
Joined Aug 17, '03
I really need to do my calipers
post Feb 24, 2006 - 7:40 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Will those calipers bolt on to my gt? I have a regular usdm gt and not a gt4
post Feb 24, 2006 - 10:39 AM
sugarfree
Joined Dec 21, '05
From dallas
Yea i want to know also. I know the caliper probably wont clear the wheel though. And the gt4 rotor looks thicker.
Maybe though, cus Maikl has them.
This post has been edited by sugarfree: Feb 24, 2006 - 6:14 PM
post Feb 25, 2006 - 12:23 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
They are the right spacing on the caliper bracket... but they bolt in differently (bolt onto the knuckle, not the bracket)... they're offset differently from the knuckle... they're designed for the superstrut spindles, which are vastly different... so there's some custom work needed to fir them. By that time... might as well pick up a front pair of calipers from a Toyota 4x4 truck... which are solid 4 pots also.
post Feb 25, 2006 - 4:05 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(Kwanza26 @ Feb 25, 2006 - 5:23 AM) [snapback]399366[/snapback]
Sweet, Im trying to fab a set of 4 piston brembo calipers on my car. man I wish I knew how to run a mill good so I could make the brackets. I lambo just now the basics from machine shop class. I saw a pair of 8 piston calipers on ebay yesterday. All I need is 6!!!
Lo-Fi Version Time is now: February 17th, 2025 - 10:13 AM
