intercooler piping kit, where can i get them? |
Feb 15, 2006 - 4:37 PM |
Manny, i'm sure someone's done this, but i gotta make sure.
the route for the 5th gen alltrac is not feasible on the 6th gen? -------------------- |
Feb 15, 2006 - 6:20 PM |
idk steve, never ran the piping in a 5th gen.
id assume it'd be close tho.. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Feb 15, 2006 - 9:42 PM |
Enthusiast Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
QUOTE(tangcla @ Feb 9, 2006 - 9:38 PM) [snapback]391525[/snapback] Problem with the ST205 WTA cooler... true that the coolant doesn't get heat soak as easily, but once it's soaked, it stays soaked for ages. i know this sounds stupid but its there anyway to rig it up so u can have both fmic and wta and switch between them when one becomes heatsoaked? |
Feb 15, 2006 - 10:06 PM |
QUOTE(MonsterBOX @ Feb 15, 2006 - 9:42 PM) [snapback]394667[/snapback] QUOTE(tangcla @ Feb 9, 2006 - 9:38 PM) [snapback]391525[/snapback] Problem with the ST205 WTA cooler... true that the coolant doesn't get heat soak as easily, but once it's soaked, it stays soaked for ages. i know this sounds stupid but its there anyway to rig it up so u can have both fmic and wta and switch between them when one becomes heatsoaked? um, no -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 16, 2006 - 6:34 AM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
Direct quote from Jeff Fazio on the mr2 board
"I did not have the time or resources to put a full, good bead on the pipes. I merely had about 1/2" lines put on 4 spots on each of them. It seems to be holding up perfectly. This system is so tightly put together, there is not much room for anything to move" So he does have lips welded on the piping but not complete all the way around DG This post has been edited by DG_Performance: Feb 16, 2006 - 9:36 AM -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 5:49 PM |
