> brembo rotors, genuine or fake?
post Feb 6, 2006 - 11:35 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
uh is there a way to tell if they are truely brembo rotors or if somebody just put them in a brembo box?
06 Civic EX
My For Sale Thread
post Feb 7, 2006 - 9:37 AM
4candles
Joined Jan 30, '06
From good old blighty
No serial numbers to check out ??
failing that I'd go to a shop and look at Brembo rotors and then compare them with the ones in question.
post Feb 7, 2006 - 9:59 AM
Brembo rotors have the Brembo logo and name machined into them.
There's one of my ST184 rotors.
post Feb 7, 2006 - 10:06 AM
celiracer
Joined Oct 5, '05
From NE
Brembo also makes a cross drilled rotor. When coomer said that the brembo rotors have brembo on the side i looked at my cross drilled ones, and sure enough it does say brembo on them. But i can't get a pic i've ben trying to get a pic of the brembo on the sides. But it comes out blury.
post Feb 7, 2006 - 10:09 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
i dont believe brembo makes cross drilled rotors for the 6gc. i think someone else drills them.
- Ryan
aim: rkgreen04
post Feb 7, 2006 - 10:11 AM
celiracer
Joined Oct 5, '05
From NE
Nah brembo takes there stock replacement rotors and drills them..
post Feb 7, 2006 - 10:14 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
I want to see it in their product list then. I'm not saying you're wrong I've just never seen proof.
- Ryan
aim: rkgreen04
post Feb 7, 2006 - 10:15 AM
celiracer
Joined Oct 5, '05
From NE
ya understandable. But if someone tried to drill a rotor themself it would come out ruff as crap and would never work right. these holes are perfect. and not ruff at all. if you want i'll try and get a pic like coomers. and show they say brembo on them and show how smooth the holes are.
post Feb 7, 2006 - 10:27 AM
QUOTE(celiracer @ Feb 7, 2006 - 7:15 AM) [snapback]390124[/snapback]
You should...and make sure you get the part number in the picture. It's a five-digit number I believe.
post Feb 7, 2006 - 10:29 AM
celiracer
Joined Oct 5, '05
From NE
K. i'll try. so far everytime i take one it gets blury. but i'll keep trying wink.gif
But while im looking at yours coomer. Mine is a little diff. it says this.
12 02 A AA MINTH 26 MM and then says brembo. Doesn't have the numbers after brembo.??
Here is a pic. Not very good but u can see what it all says on the rotor.\
This post has been edited by celiracer: Feb 7, 2006 - 10:47 AM
post Feb 7, 2006 - 7:38 PM
RCTCelica
Joined Jul 2, '05
From NYC
brembo make drill rotors and slotted. they do not make cross drilled and slotted. when you see a brembo brake kit with both cross drilled and slotted. this means the owner got the rotors custom drilled.
post Feb 7, 2006 - 7:53 PM
celiracer
Joined Oct 5, '05
From NE
ya Mine in the pic above. Are there brembo cross drilled rotors.
post Feb 8, 2006 - 12:19 AM
elvasoshexai
Joined May 16, '05
thanks for the info! i'll check that out when i pick it up tmr night
06 Civic EX
My For Sale Thread
post Feb 9, 2006 - 7:19 PM
elvasoshexai
Joined May 16, '05
er.. on the side of one of my rear rotors it says:
02 04 D A MIN TH 9 MM... is that the right size for a 98 gt?
on the brembo site it says for the rear the min thickness is 8mm..
06 Civic EX
My For Sale Thread
post Feb 9, 2006 - 7:58 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(elvasoshexai @ Feb 9, 2006 - 7:19 PM) [snapback]391469[/snapback]
That's okay, 9mm is bigger than 8mm
Live Free, Be Happy
post Feb 9, 2006 - 9:21 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
A lot of people can cross-drill and slot rotors near OEM finish, it depends on the equipment. It's not necessarily cheap to get rotors slotted or cross-drilled.
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Feb 9, 2006 - 9:42 PM
RCTCelica
Joined Jul 2, '05
From NYC
keep in mind that cross drilled and slotted rotors are more abrasive then either or.
cross drilled and slotted-very abrasive
drilled- abrasive
slotted- not so abrasive
this just means that you feel more "friction" on the brake pedal.
post Feb 9, 2006 - 9:44 PM
tangcla
Joined Jan 22, '06
QUOTE(RCTCelica @ Feb 10, 2006 - 1:42 PM) [snapback]391529[/snapback]
drilled- abrasive
post Feb 9, 2006 - 9:48 PM
lilsteeg
Joined Jan 16, '06
From Lima, ohio
QUOTE(tangcla @ Feb 9, 2006 - 9:44 PM) [snapback]391532[/snapback]
drilled- abrasive
this is true, the reason is because the slots also clean the break pads when you press the brakes
This post has been edited by lilsteeg: Feb 11, 2006 - 9:37 PM
post Feb 9, 2006 - 9:53 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
but can they warp faster then normal rotors?
Lo-Fi Version Time is now: February 17th, 2025 - 10:17 AM
