GB: Custom Made Cat-Backs, Guaging Interest |
Feb 15, 2006 - 7:38 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
ok here is the front part of my st which has a 3 inch on it its only tight on the over axel part ok now here is a shot of my old 2.25 inch pipe from the cat back thats where it gets tight with a 3 inch pipe -------------------- yea your 3sgte is cool but ill stick to my 7agte
Feb 15, 2006 - 8:14 PM |
Enthusiast Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
hm.. your setup looks different than manny's... but i guess that's just cause your's goes above rear suspension and his goes under... otherwise it seems the same... but yea it does seem tight in some areas... well, the actual routing will probably be decided when prototype is built and test fitted...
Feb 16, 2006 - 6:28 PM |
QUOTE(elvasoshexai @ Feb 15, 2006 - 7:14 PM) [snapback]394589[/snapback] hm.. your setup looks different than manny's... but i guess that's just cause your's goes above rear suspension and his goes under... otherwise it seems the same... but yea it does seem tight in some areas... well, the actual routing will probably be decided when prototype is built and test fitted... if its under or over that is big chose when will you know if under he should weld a guard on there for the lowest section just in case speed bumps etc im only a 1 lowered here is the pics from mannys car http://www.6gc.net/forums/index.php?showtopic=27942 This post has been edited by nik: Feb 16, 2006 - 6:38 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Feb 17, 2006 - 9:16 PM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Are you guys talking about making a full exhaust system from like the dp back? or are you talking about just a cat-back?
I may be interested in having a 2.5" or 3" system made for the gze. Lemme know what you guys are doing for this / when. -FAQ -------------------- AIM : FAQdaWorld
Feb 18, 2006 - 5:16 AM |
QUOTE(FAQdaWorld @ Feb 17, 2006 - 9:16 PM) [snapback]395677[/snapback] Are you guys talking about making a full exhaust system from like the dp back? or are you talking about just a cat-back? I may be interested in having a 2.5" or 3" system made for the gze. Lemme know what you guys are doing for this / when. -FAQ it's from the cat-back... and we still need quite a few more people for this to happen -------------------- |
Feb 18, 2006 - 11:25 AM |
1. ElvaSoShexai
2. lake1069 3. Valo666 (???Maybe???) 4. TheStreetzKing (Maybe) 5. Celica101 6. FAQdaWorld (Down for a 3" possibly 2.5) -------------------- AIM : FAQdaWorld
Feb 18, 2006 - 2:04 PM |
6th gens:
1. ElvaSoShexai (2.25 or 2.5") 2. lake1069 3. Valo666 (Maybe) 4. TheStreetzKing (Maybe) 5. Celica101 6. FAQdaWorld (Down for a 3" possibly 2.5) 7. Nik (maybe 3") 8. tovejas (maybe 2.5") 9. BLINKYxMUNKEY (maybe) 10. creis (2.5") 11. 5th gens: 1. 3sgte@daspeedof (2.5" or 3") 2. hm.. we have a lot of maybes. but if they all end up staying in we're almost there! still need some people to tell me what type of piping they are interested in tho! This post has been edited by elvasoshexai: Feb 19, 2006 - 1:00 PM -------------------- |
Feb 20, 2006 - 9:31 PM |
anyone else interested?
Feb 28, 2006 - 7:19 PM |
nobody else wants a quality custom cat-back?
Mar 1, 2006 - 2:47 PM |
Enthusiast Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) |
is this over or under the axle?
-------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Mar 1, 2006 - 4:15 PM |
QUOTE(bigal004321 @ Mar 1, 2006 - 2:47 PM) [snapback]401394[/snapback] is this over or under the axle? they haven't been made yet. but they could do either This post has been edited by elvasoshexai: Mar 1, 2006 - 4:15 PM -------------------- |
Mar 2, 2006 - 2:12 AM |
Enthusiast Joined Feb 1, '06 From Los Angeles Currently Offline Reputation: 1 (100%) |
any clue for the best pipe size for st yet?
if yes, then i am in |
Mar 2, 2006 - 9:29 AM |
QUOTE(zombie @ Mar 2, 2006 - 2:12 AM) [snapback]401713[/snapback] any clue for the best pipe size for st yet? if yes, then i am in 2.25" for stock 2.5"+ if you plan to do some performance mods (like FI) basically same goes for the 5SFE -------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 11:03 AM |
