reset CPU. now what?, followed the tutorial... |
Feb 8, 2006 - 1:54 PM |
Enthusiast Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
ok i followed the tutorial on how to reset the cpu for it to recalculate the air/fuel ratio. now what? should i drive it easy? all i have put on is a catback with a 2.5in pipe and muffler.....its a US GT by the way
-------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Feb 8, 2006 - 3:31 PM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
Just drive the way you drive. You really didn't need to do it just for a cat-back though. I don't know if it's just the OBD-II cars or not but the ECU on my car will automatically update without resetting.
This post has been edited by Negative: Feb 8, 2006 - 3:31 PM -------------------- |
Feb 8, 2006 - 5:53 PM |
the "reset the ecu for mods" stuff you hear is a myth. the ecu is always learing and changing while its running.
just drive the car normally, dont need to do anything special -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 8, 2006 - 9:02 PM |
Getting the ECU reflashed to work with mods works better. They actually change the programing of the ECU. I'm not sure on OBD1s, if you can do it yourself by simply unhooking the battery. I don't think it will have the same effect. Bottem line, it couldn't hurt, so do whatever you feel.
Feb 9, 2006 - 2:08 PM |
actually i did both disconnect my battey for about 90min, then i got out of class and warmed it up and reset the ECU. i have noticed that before doing it i would be at about 3000rpm going 65 and after i am running about 3100-3200 at 65 mph...that and when i shift the car doesn't jerk....that or i just got as lil better at shifting
Feb 9, 2006 - 4:17 PM |
QUOTE(b1gr3d @ Feb 9, 2006 - 2:08 PM) [snapback]391319[/snapback] actually i did both disconnect my battey for about 90min, then i got out of class and warmed it up and reset the ECU. i have noticed that before doing it i would be at about 3000rpm going 65 and after i am running about 3100-3200 at 65 mph...that and when i shift the car doesn't jerk....that or i just got as lil better at shifting Rpm change is in your head. This would have no affect on it. The car could handle shifting better though. The reset could have caused it to cut out less. -------------------- Live Free, Be Happy
Lo-Fi Version | Time is now: November 27th, 2024 - 9:25 AM |
