> RS Akimoto Intake Tubing, Will this work?
post May 24, 2003 - 10:23 PM
TRDDawg
Joined May 23, '03
From Illinois
RS Akimoto has spiral-flex intake tubing that can be used to create a custom intake. The sizes range from 3in to 4in and 2ft to 4ft and also insulated or non-insulated. I am thinking about making my own intake using this tubing (3in). Will this work?
post May 25, 2003 - 6:24 AM
post May 25, 2003 - 5:12 PM
Drolius
Joined Feb 15, '03
From Michigan
Yes, it should work without any problems. A cool thing about intakes is that you can let your imagination take over and custom build your own for a fraction of the price of leading manufacturers and see the same results. Let me know how things work out!
-Eddie-
post May 25, 2003 - 6:52 PM
TRDDawg
Joined May 23, '03
From Illinois
So should I use a K&N filter and buy a by-pass valve?
post May 26, 2003 - 2:10 PM
TRDDawg
Joined May 23, '03
From Illinois
What else do I need besides the filter and tubing?
post May 26, 2003 - 2:31 PM
ghostdog
From ny to philly
QUOTE (TRDDawg @ May 26, 2003 - 11:24 AM)
post May 26, 2003 - 2:51 PM
stelica85
Joined Jan 16, '03
From Wichita KS
where do you find this stuff
post May 26, 2003 - 5:36 PM
jumpinccv
Joined Nov 11, '02
From Ohio
hey trddawg...let us know how it turns out...I was thinking of doing the same thing...if you made a how-to that would be even better...
post May 26, 2003 - 9:33 PM
TRDDawg
Joined May 23, '03
From Illinois
Hmm I think it might be a while because I am still doing research and reading other diy intakes. I don't know if I should make it because I know that it would be more powerful than any other intake but it might be too difficult. But if I do decide to make it then I will definately create an How-To.
post May 26, 2003 - 11:21 PM
Drolius
Joined Feb 15, '03
From Michigan
Hey TRDDawg,
I think it would be cool to do your own intake that way you can feel pride in your own work and imagination. Never get discouraged about attempting w/ in your own capability. I think you should definitely give it a try. If you do let me know how it turned out. Take it easy!
post May 27, 2003 - 1:42 AM
KAMiX
Joined Mar 4, '03
Go for it buddy.
Absolute worst thing you could do is screw it up (although I don't really know how thats possible) and have to put your stock air box back on.
This is probably the cheapest mod you can do to your car, with the filter being the only cost more than pocketchange.
Why not?
btw.. go for the 3inch, because the filters are usually 3, but just to let you know, the connection on the throttle body is 2.5 inch.
post May 27, 2003 - 4:08 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
I read somewhere that if you make your intake too big or too long then you actually lose power. Now this might be wrong since the only people that post info on the net nowadays are rejects that don't know spit from oil.
post May 30, 2003 - 3:46 PM
TRDDawg
Joined May 23, '03
From Illinois
Where is a good place to buy hose clamps and a coupling hose?
post Jun 2, 2003 - 12:45 AM
KAMiX
Joined Mar 4, '03
Neip.. only way you're likely to lose power is if you give the engine less air than the crappy airbox does, which is unlikely.
post Jun 9, 2003 - 10:18 PM
TRDDawg
Joined May 23, '03
From Illinois
I am thinking of buying the 3" intake tubing (2'), hose clamps, and a step hose (ID 2.5" and ID 3.0"). Is this enough to make the intake?
post Jun 13, 2003 - 3:43 AM
CelicaSX
Joined May 1, '03
From Victoria, Australia
Here's a tip for you.....what ever you do don't fix or fasten the pipe to the engine or anything attached to engine(except for the intake manifold).
Try and fix it to the chasis or items bolted to the chasis, this is because the movement of the engine while driving will rip the pipe out.
post Jun 13, 2003 - 2:04 PM
TRDDawg
Joined May 23, '03
From Illinois
QUOTE (CelicaSX @ Jun 13, 2003 - 12:57 AM)
What will I need to bolt it on to the chassis? Also where is a good place for the air intake filter?
This post has been edited by TRDDawg: Jun 13, 2003 - 10:50 PM
post Jun 14, 2003 - 12:40 AM
FallenHero
Joined Dec 26, '02
From Alabama
I'm trying to get an Accel Kool flow system going, but the Bit#@s at autozone can't order it yet!!!
Jon
Lo-Fi Version Time is now: December 2nd, 2024 - 10:14 PM
