> Wierd problem Hard shift, Hard shift
post Feb 11, 2006 - 8:31 PM
tceligt
Joined Sep 7, '05
From Ensenada, Baja California, Mexico
Ok, i change rear motor mount, check the oil clutch level.
The problem its to shift sometimes.
I can drive sometimes and meke the shift so smoth, whitout problems but some days, for a example i got a bump, well i reduce the speed, and need to start in 1st gear but i cant i need to wait some seconds and then 1st get so smooth and second and third and 4th all gears, feel like a bad engine position, but mounts are new.
Any clue wath could be?
Could be a syncro
post Feb 11, 2006 - 8:37 PM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
It sounds more like a gearbox problem.
My friend experience the same thing.
Not shifting smoothly between gears.
He change the gearbox oil to redline
and it was much better.
6GC 4 Life Baby!!!
post Feb 11, 2006 - 9:03 PM
tceligt
Joined Sep 7, '05
Also the clutch and pressure plate are news,
post Feb 12, 2006 - 4:07 AM
Sev408
Joined Dec 4, '03
ok, are you having issues shifting in all the gears or just going back to first.
i cant specify what is wrong if all your gears are having issues, it could be a number of things.
HOWEVER, if its just the bump going to first, its supposed to be like that. Its a safety to keep people from going into first above 5-10mph. First is used to start off and this it. You should not have to downshift to first.
user posted image hows it taste motha f*cka
post Feb 12, 2006 - 4:44 AM
tceligt
Joined Sep 7, '05
just in first gear at low speed like 2-3mph
post Feb 12, 2006 - 8:24 PM
Sev408
Joined Dec 4, '03
well its just your safety measures built into the transmission. its to keep from downshifting, like a moron.
yes its annoying as crap sometimes, but you will have to deal with it. no way to fix it.
Lo-Fi Version Time is now: April 22nd, 2025 - 7:15 PM
