Dyno revisted after rebuild... |
Feb 13, 2006 - 9:17 PM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Following the arrival of the Apexi Power FC last Friday, it was 'installed' on Sunday and today was the day it was properly mapped.
While it did have base maps already 'on board' and the car was driveable, it certainly wasn't as good as the OE ECU - it did smooth out a couple of flat spots on trailing throttle, but it obviously wasn't good enough to be driven on for any period of time. This was immediately blatant on the dyno when at cruising revs, the ignition was being advanced to +50 degrees And that is not a typo. Anyway, a couple of hours later and the engine was running very sweetly indeed and was producing some decent figures. I'm still essentially running the motor in and as such, am keeping the boost down for another 3000ks just to make sure. Two boost settings have been set by the Profec B - 13.6psi and 10.5psi. Here is the 'High' setting... 236.5whp Pretty happy with that. Only 8kW (10.7whp) lower than the previous dyno before the work was done and running 16.2psi. The lower setting showed 164.3kW (220whp) - again with a beautifully flat torque curve. This chart has been overlaid with a mate's ST205 readout who is running an Apexi Power FC, high flow CT20B, full exhaust and K&N panel filter... An obvious difference in power delivery - especially at the top end of the rev range. Other engine is running out of puff below 6000 while mine is still pulling like a schoolboy at 7200 with a higher boost setting. A testimony to the balanced bottom end, HKS 264 cams and fully worked cylinder head. Things can only improve with a bigger turbo, exhaust and tubular exhaust manifold. Have to say I'm a happy chappy Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 13, 2006 - 9:37 PM |
Pics working now. Good numbers for low boost. I would consider keeping boost low and just running the crap out of the car. It's got to be bullet prove now. Very awsome. Like I said before, it would be nice to have all your stuff in a big right up. Clean it up with very little chit chat and what not. Insparation to us all.
This post has been edited by Bigmeanbulldog55: Feb 13, 2006 - 9:42 PM -------------------- Live Free, Be Happy
Feb 13, 2006 - 9:43 PM |
Enthusiast Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
wow that freakin' sweet cant wait 'til u unleash the beast
bboy -------------------- ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Feb 16, 2006 - 4:42 PM |
Enthusiast Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
nice.
i just hope your not tuning via the commander. -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Feb 16, 2006 - 8:03 PM |
QUOTE(recneps @ Feb 16, 2006 - 4:42 PM) [snapback]395117[/snapback] i just hope your not tuning via the commander. You think I'm that dumb? Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 16, 2006 - 8:49 PM |
QUOTE(GT4WRC @ Feb 17, 2006 - 1:03 AM) [snapback]395188[/snapback] QUOTE(recneps @ Feb 16, 2006 - 4:42 PM) [snapback]395117[/snapback] i just hope your not tuning via the commander. You think I'm that dumb? Gary hope not. -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:23 PM |
