> doing custom interior
post May 26, 2003 - 1:09 AM
DoodieHead
Joined Mar 31, '03
From Bowling Green, KY
i started painting my trim, i got like 6 pcs done, i still gotta do the side vent surrounding things, airbag, and the vent in front of windshield, and some other little things. its starting to look really good, looks professional. im using spray paint and clear coat
post May 26, 2003 - 4:20 AM
What color are you painting your dash pieces? And what kind of paint are you using?
post May 26, 2003 - 12:05 PM
mywhite94celicag...
Joined Oct 30, '02
From Nebraska
when i painted mine, i used a stuff product that was supposed to make pint adhere to plastic better, it was clear in color. then i used my white paint, and it looks great
94 celica GT
90 Civic Si
post May 26, 2003 - 9:29 PM
DoodieHead
Joined Mar 31, '03
ultramarine blue, its kinda metallic looking. it's spray paint for trim accesories that i got at autozone. 5 dollars a can. i will have pics in a little bit, once it gets done, i have 13 pieces done so far, going to do trim around gauge cluster and airbag cover for the last touch
This post has been edited by DoodieHead: May 26, 2003 - 9:31 PM
post May 26, 2003 - 9:33 PM
94TRDCeli
Joined Jan 29, '03
From Texas
damn 5 bucks a can? is it a big can cause the duplicolor i bought from walmart was like 2 bucks a can
post May 26, 2003 - 9:48 PM
DoodieHead
Joined Mar 31, '03
yea, its duplicolor, the actual price was something like $4.50. autozone is a rip, didn't think about going to wally world smile.gif
post May 26, 2003 - 9:50 PM
DoodieHead
Joined Mar 31, '03
does anybody know how to take off the airbag cover, that's the last thing i gotta paint, the part that's closest to windshield looks like its one solid plastic piece, i dont want to break it
post May 29, 2003 - 6:21 PM
exxtractor
Joined Mar 31, '03
From BC
dont touch the air bag cover! Now I might be over reacting, but I think you have to disconnect the battery, otherwise the airbag could set off and brake your nose, or worse. And it is very expensive to replace. I think your best bet it to have a dealership take the cover off (if it can be done) and then paint it. Noe obviously I bet the deale will say we are not responsbile if the air bag goes off or is damaged. Just my 2 cents.
post May 30, 2003 - 2:38 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
QUOTE (exxtractor @ May 29, 2003 - 3:35 PM)
is it expensive for the airbag or your nose?
post May 30, 2003 - 7:53 PM
Inferno
Joined Jan 30, '03
From Virginia
Well, think about something hitting your face full of air at like 100-200 MPH. Ouch! So, expensive for your nose. Then think about having to get a new airbag thing put in, I've heard that can be really expensive as well.
post May 31, 2003 - 11:28 PM
DoodieHead
Joined Mar 31, '03
that airbag will also break whole windshield if it inflates, i decided not to paint the airbag cover, i will have pics soon of the interior tho
post Jun 1, 2003 - 5:28 PM
Inferno
Joined Jan 30, '03
From Virginia
Awesome! I'm looking forward to seeing your pictures!
post Jun 12, 2003 - 4:12 PM
Tranceman
Joined Jun 12, '03
From Jersey
Hey what other products did you use besides paint? This is how I am going to do mine:
1. sand plastic
2. spray primer
3. spray duplicolor paint (2 or 3 coats)
4. spray clear coat
Is this what you are doing? If not, please let us know!
post Jun 12, 2003 - 6:04 PM
Charlie97L
From North Bethesda, MD
QUOTE (DoodieHead @ May 31, 2003 - 8:42 PM)
the airbag is vinyl too, you'd have to use vinyl dye, not spray paint, otherwise it will look awful. if you want to get it off:
unplug the battery
remove the airbag fuse
get a craftsman torx 60 bit from sears (i got 2 cheap ones at autozone and they broke)
pop the side covers off on the steering wheel (in between the spokes)
unscrew the torx bolts, they don't come all the way out
carefully!!! remove the airbag, you may need to pull the sides of the wheel case out to make sure the torx bolts are all the way out
unplug the harness
dye. don't clearcoat it, just dye it.
reverse to reinstall.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Jun 13, 2003 - 1:54 AM
Tranceman
Joined Jun 12, '03
From Jersey
Wow, that was so easy I feel stupid for not doing it earlier! I have black interior, and added a silver flavor to the joint. Pics up tomorrow. wink.gif
post Jun 13, 2003 - 12:31 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
If you're interested, my manual tells how to disconnect the airbag stuff. Let me know, and I could scan in the instuctions.
psalm 69
post Jun 13, 2003 - 3:17 PM
Tranceman
Joined Jun 12, '03
From Jersey
That would be extremely helpful. Anybody else have problems getting pass side vent off? Im afraid to crack it.
post Jun 13, 2003 - 4:16 PM
Tranceman
Joined Jun 12, '03
From Jersey
Pics are up, they look white, but are metallic silver and came out great. Working on the rest of the center console bottom and the doors are next.
That leads me to this question. On the doors, there is one screw by the hinge and 2 other circular thingy's on the side of the door holding the plastic on. How do i get those thingy's to release without busting them? biggrin.gif
post Jun 14, 2003 - 11:13 AM
Charlie97L
QUOTE (Tranceman @ Jun 13, 2003 - 1:30 PM)
you don't, unless you have the toyota tool... a lot of these little clips aren't designed to be taken on and off many times, maybe once or twice and they need to be replaced.
1994 Lexus ES300
1989 Supra Turbo
post Jun 17, 2003 - 12:12 PM
Tranceman
Joined Jun 12, '03
From Jersey
Thanks fo the info, I'm glad I didn't mess with it. I might just paint it right on the car. Hmmmm....... wink.gif
Lo-Fi Version Time is now: November 24th, 2024 - 12:51 PM
