FS:Full 3SGTE setup for sale, with harness, trans, clutch, etc |
Feb 14, 2006 - 11:48 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
Well, I've moved onto other things, and this isn't going to be going into another celica anytime soon.
You'll need a boost controller, or run stock, or I have one. You'll need to do some kind of intercooler. Mine was also damaged, as was most of my piping. I'm not sure about the AC lines, if yours will bolt up or not. Mine were damaged, as was the condensor. Entire engine has less than 1000 miles on it, since rebuilt in full by QMC. I drove it occasionally in October, but no later. It was more like 470-500 miles. -Clutch is a stage 3 centerforce. Same as engine -tranny included, standard s54. If you need shifter cables or axles, I've got those. -ECU was swapped from an MR2, and double checked by QMC. -Turbo is an upgraded ct26 or ct27, has been disputed. Either way, you can see which it is. -Plug wires are new, as are some of the ignition components. -Main and rod bearings were replaced, crank was machined to spec, pistons cleaned, rods machined to spec. Car ran great when I got it back. -Header and DP are both xsracing, but problems were repaired. New as of october Im located in Greencastle, PA, 17225. Southcentral PA. I dont want to ship, but I could meet someone probably up to 100 miles away. I will not part unless 1/2 the parts or the head is spoken for. Taking offers for price, I dont really have anything to base off of. I can include fuel pump, axles, etc. Also may have a BOV, radiator, some other parts. Just ask and we can work something out. This post has been edited by mark_426: Feb 14, 2006 - 11:49 PM -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 15, 2006 - 12:14 AM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
so wed need a boost controller and a intercooler but other than that this is everything needed for a swap?
Feb 15, 2006 - 12:22 AM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
I'll take that ct27 if you part out the engine.
-------------------- I will return one day. |
Feb 15, 2006 - 12:25 AM |
Yeah, you should be able to drop it all right into a GT.
Also, you'll need to modify your exhaust - or I can give you a midpipe that goes from DP to celica cat, but its extremely restrictive. DMC used it originally.. I wouldn't use it more than temporarily. -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 15, 2006 - 12:57 AM |
500$ no turbo picked up
hehe gotta start somewhere This post has been edited by playr158: Feb 15, 2006 - 12:57 AM |
Feb 15, 2006 - 2:07 AM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
any ballpark figures? you are within driving distance.
Feb 15, 2006 - 6:58 AM |
Just looking for offers.
I'd take about the normal price for a clip.. -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 15, 2006 - 9:40 AM |
Enthusiast Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
What do you mean by "fully rebuilt"? What was replaced/ repaired?
Thank for pointing that out Dustin. I even went back to read it and it didn't click... shame you are selling it with all that work done This post has been edited by Jeremy1210: Feb 15, 2006 - 1:56 PM |
Feb 15, 2006 - 10:14 AM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
QUOTE(mark_426 @ Feb 15, 2006 - 4:48 AM) [snapback]394103[/snapback] -ECU was swapped from an MR2, and double checked by QMC. -Turbo is an upgraded ct26 or ct27, has been disputed. Either way, you can see which it is. -Plug wires are new, as are some of the ignition components. -Main and rod bearings were replaced, crank was machined to spec, pistons cleaned, rods machined to spec. -Header and DP are both xsracing, but problems were repaired. New as of october QUOTE(Jeremy1210 @ Feb 15, 2006 - 2:40 PM) [snapback]394251[/snapback] What do you mean by "fully rebuilt"? What was replaced/ repaired? -------------------- |
Feb 15, 2006 - 11:13 AM |
QUOTE(mark_426 @ Feb 15, 2006 - 6:58 AM) [snapback]394224[/snapback] Just looking for offers. I'd take about the normal price for a clip.. you wont get anything near a clip cost... you don't have a clip and all it has to offer.. |
Feb 15, 2006 - 11:44 AM |
well ill start at something a little more reasonable than 500, ill give you 1000 provided like you said it is everything needed for the swap other than intercooler and boost gauge to complete.
Feb 15, 2006 - 12:02 PM |
I can't justify paying for an engine at 'clip price' that isn't a clip...there's too many things missing.
Feb 15, 2006 - 3:20 PM |
also i am currently 95 or so miles away from your zip, so no shipping required
Feb 15, 2006 - 3:28 PM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
pm sent.
~snapshotgt -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Feb 15, 2006 - 3:49 PM |
QUOTE(Akimbo @ Feb 15, 2006 - 5:02 PM) [snapback]394330[/snapback] I can't justify paying for an engine at 'clip price' that isn't a clip...there's too many things missing. well, aside from losing out on selling parts of the clip we dont need in our swap, this guy appears to be selling everything wed need for the swap. however, it is cheaper to buy the parts individually than buy a clip since theres so much in a clip you dont need, so it is fair to not expect clip worthy prices. |
Feb 15, 2006 - 4:01 PM |
Engine is also a fresh rebuild, tranny, clutch, and all the other parts. It was something like 2k+ that went into this, parts and labor.
If you want, I'll plasma the engine compartment off my celica, and it can be a total front clip. Want the body panels? I can do that too. Headlights are sold already though, if anyone was curious. Replied to both PM's This post has been edited by mark_426: Feb 15, 2006 - 4:02 PM -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 15, 2006 - 4:52 PM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Ok dude, I'm going to cut you a deal.
Check your PM please. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Feb 15, 2006 - 6:19 PM |
just for future refrence, the turbo on the left is NOT a ct-27, it has a clipped exhaust wheel which is somthing ATS will NOT do.
it does appear to be upgraded tho. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Feb 16, 2006 - 12:30 AM |
Have money down. Should be gone by the end of the week.
Thanks everyone, will post immediately if sometihng changes -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 16, 2006 - 9:23 AM |
Enthusiast Joined Sep 16, '04 From Hershey, PA Currently Offline Reputation: 7 (100%) |
...meant to pm srry
This post has been edited by pimped6gen: Feb 16, 2006 - 9:23 AM |
Lo-Fi Version | Time is now: December 4th, 2024 - 10:41 PM |
