Enthusiast Joined Mar 28, '05 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
All right, so i got an ST, automatic, and definitley want to get a front clip(3sgte). When looking at clips, a majority of them are RHD, and therefore the stick shift is mirrored of that of a LHD celica, so whats the solution?
Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) ![]() |
what are u trying to say...i'm misunderstanding you, but i dont comprehend what your trying to ask....u trying to see if u cna use the same shifter?
-------------------- ![]() Now SR powered |
well its probably no problem to use the same shifter, but think about sitting normally, on the left, and following the layout of the shifter for a RHD, what should be the gears closest to you would now be farthest from you
it is the same with LHD and RHD
QUOTE well its probably no problem to use the same shifter only if the clip is a 94-99 Celica -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
The only thing different is that the shifter is bent towards your leg (RHD) instead of away (LHD) so the feel will be a little different. But if you have not driven a Manual Celica before its nothing to worry about.
-------------------- JDM Powerplant installed, BPU coming very soon!
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:09 AM |
